HP recalls 70,000 li-ion batteries
Postby needWheels » Tue May 19, 2009 11:55 am
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09221.html
I wonder if they will ever switch to safer lifepo4 for consumer devices?
needWheels
Re: HP recalls 70,000 li-ion batteries
Postby swbluto » Tue May 19, 2009 12:15 pm
The energy density of lifepo4 is nearly twice that of cobalt lithium (meaning consumer batteries would be nearly twice as heavy), its long life is a deterrent to programmed obsolescence that helps fuel a company's revenue stream and it has a higher market price for a given amount of energy capacity, so I doubt it'll happen anytime too soon in the consumer market. However, they've been using lifepo4 in the "$100 laptop program".
swbluto
Postby nutsandvolts » Tue May 19, 2009 12:27 pm
nutsandvolts
Postby needWheels » Tue May 19, 2009 12:31 pm
I hope we'll see another evolution of lifepo4 to reduce the weight in the next five years and maybe even the cost.
I did not know that li-ion has a shorter life than lifepo4.
I thought lifepo4 was only 10% larger in mass for the same capacity as lifepo4 but apparently I am very wrong.
:arrow: But this brings up a concern I've had for awhile - what if these cheap lifepo4 cells from China are cutting corners somehow and are not "pure" lifepo4 - somehow introducing a safety risk, especially as they age? Is this possible? There are claims around here of cheap 18650 lifepo4 cells exploding as people solder them, etc.
needWheels
Postby swbluto » Tue May 19, 2009 12:36 pm
nutsandvolts wrote:It's not about energy density, it's about volumetric size, LiFePO4 takes up way more space than LiPo.
Yes, that also matters, but I don't think size is the only consideration. I believe consumers do want their game boys and cell phones to be hand held if I'm not mistaken.
For volumetric energy density comparisons, see http://en.wikipedia.org/wiki/Lithium-io ... er_battery and http://en.wikipedia.org/wiki/Lifepo4 . 300/220 is only ~1.4 times as much volume per given capacity. Although, I do believe modern volatile lithium technology has a higher volumetric energy densities and those figures might be old.
swbluto
Postby nutsandvolts » Tue May 19, 2009 12:37 pm
Last edited by nutsandvolts on Fri Oct 16, 2009 12:51 pm, edited 3 times in total.
nutsandvolts
Postby needWheels » Tue May 19, 2009 12:51 pm
I would suspect at your skill level you could rebuild that HP battery much more cheaply by replacing the cells?
From what I have learned it might even be just one bad cell in that pack while the rest could go on much longer?
needWheels
Postby nutsandvolts » Tue May 19, 2009 1:01 pm
nutsandvolts
Postby needWheels » Tue May 19, 2009 1:29 pm
If you are going to use it on your bike, can't the ac adapter on the laptop convert the 48v output from a lifepo4 pack into what the laptop needs? I get this idea from people using the 5v cellphone chargers to run bike lights, it should be the same concept with just higher wattage?
needWheels
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 5 guests
