Just got my Ping...Now what? EDITED
Postby mjp8081 » Mon Jun 01, 2009 12:58 pm
Just got my 36v 20Ah from PIng today. I have one question:
It's going to power a 800w motor, potentially high amp draw.
2) What should I do for a fuse?
are there leds on the bms board?
Thanx!
Altered/Exkate M6-800 36v/800w 2Gig Wireless AT Electric Skateboard
mjp8081
Re: Just got my Ping...Now what? EDITED
Postby heathyoung » Mon Jun 01, 2009 6:33 pm
The BMS on the ping packs will do some current limiting IIRC, your fuse (if you chose to use one, a lot of people dont seem to) needs to be the current limit of the controller + 50%. Your controller will also limit the maximum current you draw.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby mud2005 » Mon Jun 01, 2009 7:38 pm
my version 3 ping has leds on the bms, they all light up when fully charged and if you let it slowly discharge you get a light show.
Future's all yers ya lousy bicycle!
-Paul Newman
Butch Cassidy and the Sundance Kid
mud2005
Postby dogman » Tue Jun 02, 2009 6:11 am
Wow you are gonna have one loooong range skateboard! :mrgreen:
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby mjp8081 » Tue Jun 02, 2009 5:39 pm
I was told by Ping that I need at least 20Ah to handle the load of an 800w motor. I would have loved to save some money and get a 12 or 15Ah.
How do I determine the limit of the controller?
It does have LEDs, I found out this morning, for balancing/troubleshooting.
mjp8081
Postby mud2005 » Tue Jun 02, 2009 9:31 pm
I have a 4000 watt motor and a ping 24 volt 10 ah. all you need to do is get a watt meter and make sure you don't use too many amps. my battery does 30 amp continuous and most of the time I use about 10 amps.
when I'm cruising up a hill I keep an eye on the amps and pedal if they go too high. a 36 volt 20 ah on a skateboard? what happens when you need to bail off the board and it crashes into a curb or someones leg?
sorry to be negative just making sure you've thought of the danger of a heavy board :)
-Paul Newman
mud2005
Postby needWheels » Wed Jun 03, 2009 11:39 am
mjp8081 wrote:I was told by Ping that I need at least 20Ah to handle the load of an 800w motor. I would have loved to save some money and get a 12 or 15Ah.
The reason why you needed 20ah is because most low end packs can only do 2C max without self-destructing quickly, and the less you hit that max, the longer it will last.
This is probably the best deal in a lightweight 48V 10ah 5C pack:
http://www.evcomponents.com/ProductDeta ... Code=H4810
I'm almost considering reselling my 20ah 18650 pack and getting that instead.
needWheels
Postby dogman » Wed Jun 03, 2009 12:12 pm
That is a great deal on what should be a great battery. Never heard of the dealer though, so somebody needs to be a guinea pig and let us know if the vendor can be trusted. There have been too many characters involved in EV's for me to trust anyone right away. I wish ping would offer a 5c cell at a price like that.
You might have gotten away with a 15 ah pack ok, but you are going to have a better chance of having the thing last the bigger it is. You'll be pulling about 1c so that is still ideal for battery longevity.
dogman
Postby needWheels » Wed Jun 03, 2009 2:51 pm
evcomponents appears to be a group of three guys from around this forum who are out of seattle
(at least shipping returns back for exchange would be much cheaper!)
I am seriously considering getting that pack if I can get a refund from ebay/paypal but it might take a few weeks
5kg with 14 mile range would be just about perfect
needWheels
Postby mjp8081 » Thu Jun 04, 2009 11:23 pm
mud2005 wrote:I have a 4000 watt motor and a ping 24 volt 10 ah. all you need to do is get a watt meter and make sure you don't use too many amps. my battery does 30 amp continuous and most of the time I use about 10 amps.
This new battery actually lightens it up over the old 3x12Vx12Ah SLAs in it before. Once you jump off, it slows itself down fairly rapidly. Those EV guys make them to custom dimensions?
mjp8081
Postby mjp8081 » Fri Jun 05, 2009 12:08 pm
I wrote them, asking if they make a 36v pack--thanks for that.
I went ahead and got a 30A mini style fuse. Hopefully that will do it.
mjp8081
Return to General Discussion
Who is online
Users browsing this forum: swbluto and 4 guests
