When the design is finalized, I will describe the d.i.y. kit that may be available then. It will consist of laser cut plywood sheets an bent aluminum tubes. The rest is up to you.
La bicyclette " la souplette " 1895 Le cadre est composé de 3 partie en Bois, dont 2 cintré le tout joint avec des armatures métalliques , jante en bois également.
full-throttle wrote:Lock,
Thanks for starting this thread.
Return of the Crown Prince (A carriage for Haile Selassie)
Metal, oak and cherry wood, 23 kt gold leaf, vintage boomboxes and speakers, car audio, electronics, mirror, velvet, rubber, and Swarovski crystals.
FERNANDO PONCE
Argentinian designer Fernando Ponce’s all-electric trike is a wonderful vehicle with green features.
The beauty and charm of the tricycle lie in the wooden frame, which was carefully crafted and fitted to make the trike more appealing. Taking basic design cues from classic tricycles, Fernando Ponce has integrated his all-electric trike with the necessary components and features of a trike, making it both useful and stylish.
The trike features batteries placed between the wooden frames and derives power from a hub motor placed in the front wheel, enabling the tricycle to be controlled with a handle grip. Considering how the environment is often something to take into consideration while using any mode of transportation, this eco tricycle may provide a great alternative for those looking to be more eco-friendly.
Published: Apr 11, 11 • References: and ecofriend
