t3sla wrote:24s 8Ah nano-tech (the shame) think either side of the top of the frame,
H35 heyna shit edition...![]()
12fet lyen sensorless (for now)
the drop out situation makes it, sucks that about the lack of mounting options, but I just want a high torque short ride machine that i can top up quickly using 20Ah charges and them smash out some more fun while out.
next project will be a 1kw folder (I have a soft spot for mini folders, think they are super cool for short trips) and the one after that will be a cro motor in a stealth frame
its hard to tell but the swing arm may come up quite high under full compression, so you may be limited to how much you can fit beside the top tube... if your only having 24s 8ah then you could use two small packs... one on the handlebars and one on the frame. it means a bit more time needs to be spent on the build but should result in a very subtle look. lookin forward to seeing what you come up with!
make sure you get a HT... they hall ass on 24s. and get a sensored controller if you can... not essential but regen breaking is nice when you need a bit more juice.
