Back in the Saddle: Going to California: 2011
Re: Back in the Saddle: Going to California: 2011
Postby Kingfish » Wed Dec 28, 2011 9:46 pm
Haha! No worries… :lol:
I did check into fairings (ES Thread). For the speed at which I preferred to travel, the feeling was that there is not a single bicycle windshield able to safely withstand wind resistance for the duration of the trip, nor could one hold up to the wind shear of a semi-truck blasting by.
However – that should not block the intrepid & creative DIY eBike enthusiast from exploring options. I found myself gravitating towards motor scooter and moped fairings until one day I decided to craft one for myself out of high-density polyethylene (HDPE) from my local supplier (Tap Plastics).
The front fairing increased my top speed by about 2-3 mph because the pointed nose sliced through headwind and rain and gusts like a hot knife through butter. The trailer design and resulting fairing was intentionally formed to create a teardrop shape where the greatest drag was at the rear, so even in high-speed, the trailer is self-correcting – or rather self-inhibiting sway and oscillation. It was a real treat to get the bike up to 44 mph (downhill) and still maintain feather-touch control.
I didn’t bother with a windscreen per se because I had a ¾ full face-shield motorcycle helmet that protected my eyes from debris and rocks. (I’ll never forget my first bug-hit, and glad it was the shield that took it and not my face).
My Triangle also had a fairing built around it to protect the batteries and cabling within. This too was covered in HDPE which is self-lubricating/soapy-like feel; perfect for two legs pumping pedals.
Aside from the inherited slip-streaming effects, the fairings were eye-catching in an attractive way, and that perhaps is the best safety feature of the entire bike! :wink:
Wind and 18-wheelers:
Truly, the only time I was scared enough to brown my shorts was on the first day when I had the steering dampener set too high: Great stability at low speed, but when a truck would blast on by – the whole bike wobbled as one and nearly whipped me off. After Portland, I turned all dampening off and let the bike move freely with the wind: This made the bike difficult to maneuver at low speed, yet extremely responsive and nimble at high speed! Same type of truck would pass, yet this time the whole bike moved fluidly: It was a learning experience to resist the temptation of holding the reigns too tightly, and instead allow the bike & trailer to move with the wind. I call it “feather-touch control” because you’re hanging on lightly and allowing the bike do what it was designed to do. :)
Again, the fairings allow for the bike to slice through the wind. Crosswinds were not a problem due to the mass of bike and rider; I’m twice as heavy as a normal MtB bike and thrice of a svelte racing bike. The only time I had serious issue with wind was crossing the Pistol River in 35+ mph wind that was gusting even higher: The worst wind conditions that I’ve ever been in on a bike. It took full-throttle and extreme patience to plow forward across the bridge: I did not like it one bit, though admittedly it was the only time I was grateful to have a heavy bike. :?
Wind & Noise:
I wanted to wear my headphones when riding, but then it would have been a sensory distraction. Even with the helmet on, I could still hear quite well. I depended on my hearing to alert me when a vehicle (or some other object) approached from the blindside. The helmet made kind of a whistling noise if I had the shield part-way up; at times this was necessary to reduce fogging. The fairings themselves were essentially quieting: Their function is to slice through air, therefore the turbulence will be lessened, though not completely eliminated.
When yer On The Road, you have lots of time to think. A quiet bike with lots of quiet moments surely facilitates freedom of thought… as well as peaceful solitude.
Ohmmmm, KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9634 miles-to-date, 4144 as 2WD.
Kingfish
1.21 GW
1.21 GW
Postby dnmun » Mon Feb 13, 2012 6:43 pm
finally loaded the pictures of kingfish on my disk, more on my web album:
https://picasaweb.google.com/1131391565 ... 7814041602
on the way to eastern oregon
dnmun
Postby Kingfish » Mon Feb 13, 2012 10:17 pm
Remind me to ditch all my tight-fitting clothes :roll:
Thanks Dennis for the shots. I think you've captured the mad-dash of field repair well :)
Imagine: I left Portland at Noon and arrived at Farfle's near Bend about 8 PM after 163 miles. Heading up Mount Hood, I was getting a bit thirsty and concerned about my charge, but that's when I spotted that little lemonade stand, and it all came together: Quick top off right then and there :wink:
About 15-20 miles east of the Mount Hood summit past the edge of edge of the forest, it was a treeless route all the way to Bend. Went through all my water that day, and was nearly dehydrated by the time I got to Madras. That drop into and the climb out of Warm Springs was something else! Heck of a day though; pretty country, wouldn't trade it for the world!
Brief stats for that day.
Again, thanks for sharing Dennis! 8)
Cheers, KF
Kingfish
1.21 GW
1.21 GW
Postby dnmun » Mon Feb 13, 2012 11:00 pm
i left out the crotch shot, he carried a pair of lipo ladies too
he was the middle in a lipo ladie's sandwich
dnmun
Postby mikebikerad » Fri Jun 22, 2012 11:41 pm
If you are ever coming through Humboldt again on ebikes look me up 8)
mikebikerad
Postby pixelzpusher » Thu Apr 18, 2013 6:03 pm
KIngfish, great trip. Loved reading it.
I have a question about your bike motors. The e-bikekit motors are rated at 48v. How are you able to put 60+ volts on the motors without frying them? I also have 48v hub motors on two of my e-bikes and only run them on 12s lipos. Did you just upgrade the speed controller and throw on 60v cells? The hub motors are able to hold up?
My hub motors did not come from e-bikekit.com.
As for your lipos, give haiyinstore.com a try. I put over 350 cycles on my batteries over a year now, 4 sets of 12s with 7000 miles logged commuting back and forth to work. I've tried hobbyking Turnigys and Haiyinstore lipos perform much better. They also have a Las Vegas warehouse so you get them in 3 days.
Would greatly appreciate an answer on the hub motor question. Thanks a bunch and happy riding.
pixelzpusher
Postby Kingfish » Thu Apr 18, 2013 11:16 pm
@ mikebikerad
I loved Humboldt country! Will do my friend 8)
@ pixelzpusher
The E-BikeKit motors are - to the best of my knowledge – Nine Continent (9C) that are simply rebranded; they are 2806-equivalents. For the most part they can take any reasonable voltage… it’s the current and overall power that we need to be concerned about. From my reading, I believe they can take 5000 watts for a short duration. During my operations they never saw more than 1550 watts each… that’s well into the safe zone and they can take that all day long. 8)
From the basic power equation where P = I*V…
Higher voltage means less current, but as I said we’re gated by Power, we’re gated by resistance, and by load. 9C traditionally prints 48V and 500W on the side for perhaps legal reasons… as to why we can only guess.
The motor modifications that I made were to enable more power to flow to the motor, equal to the gauge of stranded wire used for windings from end-to-end, thereby reducing scant resistance and improving power-handling by 50% or more. After this cross-country event I applied a major upgrade in 2012 when the same motors rusted out.
Controllers were upgraded. Typical trace beefing, R12 mod, low ESR-Caps, power & phase wires. Later in the 2012 upgrade I eliminated all GND signal wires since GND is GND, and created a unified signal harness. The schematics and tricks are explained in this thread.
The battery pack is constructed of 5S1P 15/2C 5Ah Zippy FlightMax LiPo that I purchased from HobbyKing (20C here). They are presently arranged in 3-in-1 series to produce 15S approximately equal to 63V when hot off the charger. The Commuter Pack which is always affixed to the bike holds 18 batteries in a 15S6P (30Ah) configuration which is enough to take me about 50 Seattle miles; I don’t know what the distance would be for flat Kansas miles though. For this 2011 trek I had a total of 78 batteries in a 15S26P configuration spread over 4 battery bag-sets: Commuter (18), Saddlebags over the Commuter (12), Panniers (18 total), and Trailer (30 total).
I looked at haiyinstore.com and attempted to price out an equivalent – however the only one that came close was the 65C 5S1P battery for >3X the cost/unit I paid. Appreciate the link, however I don’t require high-C batteries; I’m not racing, and I have a plenty-large stash with an excellent battery harness to prevent sags under load. Though it’s nice to know there are alternatives out there. :)
Some of my LiPos are getting on in age; more than 3 years old. I need to get into a production mode and depuff the subset that has seen abuse. So far I’ve sent only 6 to the recycler, but more will follow as I go through and remove dead cells. Most of my lot only see use on road trips; the rest of the time I have them sitting at about 3.7V/Cell for storage, and connected in parallel.
I am thinking, scheming, and planning the next road trip. Didn’t do one last year because of the knee injury/quadriceps tendonitis. The knee is plenty strong this year, though I may not be able to get time off for a long trip. Still enjoy planning, regardless. The 2012 system-wide upgrade made serious improvements to the ebike and I am anxious to break 200-miles in a day, or get to up to 55 mph on a flat. :twisted:
It’s just amazing the things we can accomplish with a little engineering and ingenuity. :wink:
Safe travels, KF
Kingfish
1.21 GW
1.21 GW
Postby lbz5mc12 » Sat Apr 20, 2013 1:07 am
Can the e-bikekit controllers safely handle more than 48V or do you need a different controller? I have one and was wondering about upgrading in the future but if I can just pop a higher voltage battery on, without buying a whole new kit, that would be great.
lbz5mc12
Postby Kingfish » Sat Apr 20, 2013 12:48 pm
This is a very pregnant question… and I yam an engineer. :mrgreen:
Therefore I offer the short answer: No.
And then there’s the compete answer… which is perhaps driving wildly off topic… although I like a good yarn, so here it is.
To begin: I have used several controllers in the past provided by a handful of suppliers – and they are nearly all the same in terms of origin and design (though not of throughput). I am trying to think of the count that I have gone through… off-hand I’d estimate 8 since 2009. The majority have been Lyen 12-FET Controllers.
Sidebar & small disclaimer: As a curious person who likes to tinker and experiment, sometimes those experiments go awry – with sparks:shock: There’s nothing wrong with the controllers – I’m just trying to push the envelope with what I’ve learned on ES and share in discoveries – however well they went or not… And I wish not to take away from the value or quality that is provided by our good suppliers. I have personally met Edward Lyen and think of him most kindly and with great respect. He provides a product of which I understand with trusted familiarity to use as a base for modification.
For this 2011 Road Trip, the Lyen Extreme Modder 12FET controller was used. It is based upon a standard design that is well-documented by a cadre of ES-greybeards, with me chiming in late to the party. Every controller that I have owned before moving to Lyen-models required the “R1” mod to improve or upgrade the voltage-carrying capacity. Essentially – Battery Voltage (VBatt) comes into the controller and is divided by the MOSFETs into digital 3-Phase by the Microcomputer & associated discreet components. The “Voltage” going into the controller is gated by two factors: MOSFETs & the first Voltage Regulator managing the 15V rail before the 5V logic.
When you purchase a controller, it used to be that we had a choice between 75V and 100V maximum output, though today most common ebike controllers for BLDC direct drive motors are capable of 100V – gated by the MOSFETs, therefore we no longer have to concern ourselves with 50% of the challenge.
The other half of the problem is knocking down the VBatt coming into the primary Voltage Regulator. On most controllers this is managed by the resistor complex is called “R1”. Low-powered boards would have just one (relatively) big fat resistor coming off the +VBatt leg before going into the input of a LM317 VR. Off-the-shelf, most controllers can handle 36 to 48V because they use a variant of the LM317 component that can take +40V differential, although late models now are supplied with a +60V differential (or perhaps a different management circuit altogether) which enables them to handle up to 75 Battery Volts (or more). In the old days we would modify the value of R1 (et al) to allow the use of larger voltages, although as hinted this is no longer a problem if you purchase your controller from the right supplier. :wink:
Longwinded, it is now after explaining this that I can answer your question:
E-Bikekit does not make controllers, just like they do not make hub motors; they are a reseller and integrator. I do not know off-hand what type of controller they are selling; if you own an E-Bikekit controller I would search ES to find out more about that particular unit and how to modify the voltage capacity, though I’d wager it is an R1 mod of some sorts… don’t quote me.
IMO tinkering with R1 is passé; there are better models to choose from at a reasonable price that have better standard features. I tend to look for Ebrake, 3-Way, Cruise, CA, and the programming adapter on top of the mainstay list – and these can be found easy enough in the Marketplace on ES.
That said, no one makes a Kingfish model that is ready for bear. There is lots, Lots, LOTS of room for improvement!!! But we take what we can get and do the best we can with stone knives and bear skins.
One last thought: If you decide to replace your controller, take a close look at the connectors and try to match up one that will mate with your existing equipment, otherwise you’re in for another tedious mod… not that it ever stopped me. :)
From the PNW, safe travels down there in SoCal, KF
PS - let me know if you'd like to swap some sunshine for rain; gimme a reason to use sunglasses 8)
Kingfish
1.21 GW
1.21 GW
Postby lbz5mc12 » Sat Apr 20, 2013 2:50 pm
Thank you. The controller has 3 connections, motor, battery and throttle. They're the black socket style connectors. It's a black controller with no markings and it has an on/off switch.
lbz5mc12
Postby Rassy » Sat Apr 20, 2013 4:24 pm
That sounds like the controllers from Wilderness Energy a number of years ago for their brushed motors. I had several BD36's with that controller. Sold as part of a 36V SLA kit, but they worked fine on 48V LiFePO4 also. I think with help on this forum we determined they had a capacitor or something that was limited to a little over 60V, so would probably blow on a higher voltage system if it's the same controller.
A picture showing the connectors would help confirm this. Does it have 3 phase wires going to the motor or just a positive and negative wire? Does it have 5 wires going to the motor for the Halls?
-Rassy-
Two Tadpole Trikes, 6X10 9C mid drive, NuVinci CVT Auto Shift, 48V LiFePO4
viewtopic.php?f=28&t=18606
viewtopic.php?f=28&t=47043
Rassy
Postby lbz5mc12 » Sat Apr 20, 2013 6:21 pm
It's just a plug with 3 holes for the motor. No 5 wire connection. I have run it both at 36V and 48V and it worked fine.
lbz5mc12
PreviousNext
Return to General Discussion
Who is online
Users browsing this forum: salty9, wingtip and 2 guests
