Affordable drill press - can chuck column play be removed?
Re: Affordable drill press - can chuck column play be remove
Postby Miles » Tue May 01, 2012 7:25 am
Njay wrote:Some good ideas on that thread Miles, thanks. I kind of like more the idea of drilling some holes around the casing in the neck, tap them and put screws on them that will press against the moving neck. This, I imagine, besides being much easier for me to do than cutting the casing, seems to have the ability to adjust inclination of the drill, since several sides can be adjusted. For 60€ I can buy on and run some tests...
I think slitting the casing would be a better solution. This will take up all of the play. One cut and a suitably sized clamp would probably work :)
Old industrial drill presses were sometimes made with a split head. My vertical mill has a similar arrangement.
Here's a DIY drill with a split head:
Miles
Postby Njay » Tue May 01, 2012 7:40 am
I'm just not seeing me do a reasonable cut with a hand saw :), although I see there's a lot of tolerance on this cut.
I don't understand what do you mean by the side-side play; on what other play are you thinking, up-down? I'm more of thinking in let it slide up-down without play and not locking the chuck's neck and move the part.
Njay
Postby Miles » Tue May 01, 2012 7:51 am
If you slit the casing, you can have one bolt to change the fit. Easy to adjust. Screws bearing on the quill would be difficult to adjust. Why are you worried about the cut? It doesn't even matter if it's not straight...
You never know, the casting might close up after being cut.... :)
Miles
Postby Njay » Tue May 01, 2012 8:02 am
I've seen weirder things :D
I guess I'll give a go then :)
Njay
Postby Miles » Tue May 01, 2012 8:08 am
This pic shows the slit in the head casting of my mill/drill. It was just done with a hacksaw :)
Anyway, show us a picture first - it might not be suitable.
Miles
Postby Njay » Tue May 01, 2012 8:29 am
This is the cheapest one, I can get it for 60€
Next in price (~100€) is the one I show on the 1st post. The lack one above seems more appropriate, no buttons in the front.
Njay
Postby Miles » Tue May 01, 2012 9:16 am
Looks doable, to me. What do the others think?
Here's the pic from the link that I posted earlier. The hole at the end of the sawcut is important.
Pic of slitted drill casing.jpg (119.67 KiB) Viewed 211 times
Miles
Postby Miles » Tue May 01, 2012 9:39 am
Another slitted head casing on an industrial drill:
http://i.ebayimg.com/t/Clausing-15-Dril ... ~60_57.JPG
Miles
Postby TylerDurden » Tue May 01, 2012 10:21 am
Miles wrote:This pic shows the slit in the head casting of my mill/drill. It was just done with a hacksaw :)
Did you add a worm-drive to the pinion?
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby Miles » Tue May 01, 2012 10:27 am
It has a worm drive downfeed but that's standard on the kit. It's a Dore-Westbury MkII:
http://www.lathes.co.uk/dore%20westbury/
http://www.lathes.co.uk/dore%20westbury/page2.html
Miles
Postby dickselectrictoys » Wed May 02, 2012 6:18 pm
no...maybe 25 years ago. these r bought in lots of 10,000. figure your cost, then subtract 50-75%. the heavier something is that is painted & metal, w/different shapes/where it came from/who sells it to public & so on. i use to work for a company years ago, (cannot mention) & they tested thousands of metal parts for millions of different machines / machinery. now days anything is allowed in to the sell to sale franchises. bottom line....u make it ur self & it can be done. i do this all the time. a hack saw/grinder/file/paint/drill. u can do it."
dickselectrictoys
Next
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 2 guests
