Forum section: "Materials, techniques, processes and tools"?
Re: Forum section: "Materials, techniques, processes and too
Postby Miles » Sun Apr 29, 2012 4:09 pm
Dauntless wrote: Perhaps you feel something is being missed. Casting/Molding merely pops up from time to time, but since not much is said I don't see why it would have it's own group.
The idea is to have one extra forum for general technology - all the items in the list... This would help to keep techniques from getting lost in vehicle specific forums.
Miles
Postby MitchJi » Sun Apr 29, 2012 7:14 pm
Hi,
Miles wrote:Yes, when a clever technique, or some such, is disclosed in a build thread, a more detailed exposition and discussion might take place in the Materials, techniques, processes & tools forum. It would then be easier to access.
Excellent idea.
BTW how do you plan to restrict it to "clever techniques" :P :lol:?
Best Wishes!
Mitch
MitchJi
Postby Philistine » Sun Apr 29, 2012 7:32 pm
Great idea for a section. In many ways (speaking as a noob myself), it is the skills and knowledge in such a section that would allow you to take a build to anywhere interesting and satisfying. I think I would learn a lot from such a section. I tend to do everything in the hardest, most inefficient and frustrating way, and then often later I see a way how some guy took the elevator. Essential basics like fabbing torque arm solutions would even fit into such a section I would have thought (sorry to raise a subject primarily of interest to the hub-dresser).
Philistine
Postby fizzit » Sun Apr 29, 2012 7:43 pm
This looks like it would be useful! It would be really cool to have a section that covers the procceses that people have used to do things like oil cooling hub motors, attaching hall sensors to outrunners, modifying controllers, etc
-Colin
my first ebike, a freeride mountain bike, using a turnigy 80-85, castle hv160, and turnigy lipo:
viewtopic.php?f=28&t=21953&start=180#p607020
fizzit
Postby Farfle » Sun Apr 29, 2012 8:28 pm
I like it alot, lots of secrets hidden in build threads that would be best displayed where people can see it.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby Pure » Sun Apr 29, 2012 8:45 pm
But who would be responsible for moving those secrets to the right forum once they are revealed.
I personally think if we are going to add a new sub forum, one for trouble shooting/ help needed threads would serve a better purpose. As it is now it's a bit confusing where to post if your bike isn't functioning properly. I mean dose it go in the general bike forum cause its an e-bike, or does it go in the technical forum cause the answer to your problem in a technical one, or does it go in the battery forum because it might be battery related. Having one set place for problems would make the whole process a lot more stream lined.
Mongoose DH
X5304
60V20Ah LiFePO4
I'm polymerized tree sap and you're an inorganic adhesive, so whatever verbal projectile you launch in my direction is reflected off of me, returns to its original trajectory and adheres to you. So there!
Pure
Postby 999zip999 » Sun Apr 29, 2012 9:24 pm
1. Solder wick techique. Use a silicon wire and just pull some of the small wires as needed. The silicon gives you a handle.
999zip999
Postby amberwolf » Mon Apr 30, 2012 2:34 am
Drunkskunk wrote:I've woundered if we don't also need a Basic Electronics section, and a Basic trouble shooting guide.
Many of the people who come here don't know V/R=I or that I*V=W. And many don't know how to do basic troubleshooting.
Those don't need forums for them, they need Wiki sections and articles. Feel free to write or edit them, even just a teeny tiny starting bit is still a start. ;)
http://endless-sphere.com/w
House Fire Updates Thread
DayGlo Avenger, MkII
amberwolf
Postby Miles » Mon Apr 30, 2012 4:00 am
Pure wrote:But who would be responsible for moving those secrets to the right forum once they are revealed.
The OP, perhaps after prompting. Also, anyone could post a link with an amplification or request.
The question of where to post is sometimes tricky. It depends a bit on the depth of the problem. If you wanted to ask "which is the best hub motor for X?" you'd ask it on Ebikes General Discussion. If you want to ask "why is my hub motor making a noise?", you'd ask it on Ebikes Technical. If you wanted to ask about or detail a modification with theoretical considerations you might post in the Motor Technology section.
Miles
Postby Dauntless » Mon Apr 30, 2012 11:18 am
MitchJi wrote:Hi,
Excellent idea.
Well, clever is in the eye of the beholder, eh? My question is how do you PREVENT it from being restricted to someone's idea of clever? People separating themselves here has worked pretty well, you start doing the separating that probably won't be popular.
Miles wrote:It depends a bit on the depth of the problem. If you wanted to ask "which is the best hub motor for X?" you'd ask it on Ebikes General Discussion. If you want to ask "why is my hub motor making a noise?", you'd ask it on Ebikes Technical. If you wanted to ask about or detail a modification with theoretical considerations you might post in the Motor Technology section.
And it should say that way.
Any sufficiently advanced technology is INDISTINGUSHABLE FROM MAGIC!
- Arthur C. Clarke
Dauntless
Postby Miles » Mon Apr 30, 2012 11:38 am
It's just another option Dauntless. I haven't intended to imply anything beyond that. Where do you think the present categories came from?
Miles
Postby kevo » Mon Apr 30, 2012 11:54 am
Probably a dumb question, but can a single thread be cross referenced (without multiple copies) within different forum sections and look like it is posted in each :?: Just curious. Sorry to be OT w/ BBS detail.
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Postby MattyCiii » Mon Apr 30, 2012 3:41 pm
What about "and suppliers"?
I'd have been totally hosed with my ATS drive install if not for someone suggesting EBikesSF.com. I'd have messed up my first wheel build if not for advice from JRH. I bought my first motor from Methods, then went on to but some of his custom parts. I'm very happy with the service from all three, but I perhaps wouldn't know where to have looked were I not a long time ES reader.
I can see how such a category can create contention - even an appearance of conflict of interest in the case of the ES Forums owner - but I'd rather hear what people have to say about various suppliers than have to search the wide open Internet and hope for the best.
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike. Based on a common power module using a NuVinci left side freewheel.
MattyCiii
Postby Miles » Mon Apr 30, 2012 4:04 pm
MattyCiii wrote:What about "and suppliers"?
I thought this was covered here? viewforum.php?f=11
Miles
Postby e-bike-is-fun » Mon Apr 30, 2012 6:12 pm
liveforphysics wrote:Fantastic idea Miles!
Include a section on connector styles. I've got a killer rig to accurately test down to uOhm's right now. (yes, 1ohm/1,000,000)
Justin saved the forum at great personal expense!
What's the story on that.?
e-bike-is-fun
Postby deVries » Tue May 01, 2012 4:09 am
Miles wrote:The idea is to have one extra forum for general technology - all the items in the list... This would help to keep techniques from getting lost in vehicle specific forums.
+1 Another excellent idea by the genius Miles. 8)
When you start the subject area, I suggest you do the first post in each topic. Why? Because you can then go back in later in the future to reference build threads (newer build threads) or specific posts that appear that reveal the best ideas or techniques, etc. That first post of yours for each topic could/should provide links to the best threads or posts you know of. So, it becomes "the sticky" for the thread. Of course, others can add more info, etc. as time goes on doing new posts after that initial 1st post of yours. But at least you will have that reserved space to edit & change as time goes on. :wink:
Great idea, Miles. :D
deVries
Postby MitchJi » Sat May 05, 2012 7:00 pm
Hi,
What are we waiting for?
I could have used it (not a big deal) for this:
http://endless-sphere.com/forums/viewtopic.php?f=7&t=39447
heavy duty (50lb & 250lb) releasable-reusable nylon zip ties
Best Wishes!
Mitch
MitchJi
Postby TylerDurden » Tue May 08, 2012 12:14 pm
Let's kick off this new section with my self-serving question about cutting & machining aluminum:
I don't own a mill. I have a lathe, tablesaw, drillpress, bandsaw, jigsaws, routers, mitersaws and angle grinders.
I'd like to cut and dado 5/16" thick 6061 flat aluminum. One cut is 5/32" wide and one is 9/16".
I can send it to a shop or get a buddy to mill it... but if it can be done in a home shop, I'm game to try.
Doable?
p.s. I tried to upload a .stp file, but nogo. :(
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby Miles » Tue May 08, 2012 12:19 pm
TylerDurden wrote:p.s. I tried to upload a .stp file, but nogo. :(
Just rename the file as PDF or Zip it. :wink:
Miles
Postby Thud » Tue May 08, 2012 4:20 pm
TD,
Your table saw will make that part in short order.
I would use a triple chip low angle blade & take several passes to work out the rough channel, then you can make a pass on the router table with carbde tiped bit for a nice finish.
The challange will be the .062"w grooves.....I would look for a thin kerf skillsaw blade (again in the table saw) & take shallow passes till you reach desired depth.
I will also recomend making some good push blocks as the alloy will generate some heat while is being cut. Save yourself a tense moment of hot fingertips in the middle of a pass.
So when are we going to see this new section Miles?
get some......
Thud
Postby Miles » Tue May 08, 2012 4:33 pm
Thud wrote:So when are we going to see this new section Miles?
Good to see everyone's keen.. :)
Soon, hopefully... We're discussing it in the context of other changes.
Miles
Postby liveforphysics » Tue May 08, 2012 4:37 pm
I'm excited for the new section. :-)
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby Miles » Tue May 08, 2012 4:38 pm
Keep them coming. It's all useful ammo :)
Miles
Postby TylerDurden » Tue May 08, 2012 11:51 pm
Thanks for the tips gents. I am revising the plan and I will post it in the new section when all is ready.
Have a Nice Day,
TD
TylerDurden
Postby Miles » Wed May 09, 2012 2:52 am
I've requested that .stp and .dxf be added to the file types accepted for upload.
Miles
Next
Return to General Discussion
Who is online
Users browsing this forum: John Bozi and 3 guests
