Forum section: "Materials, techniques, processes and tools"?
Re: Forum section: "Materials, techniques, processes and too
Postby deVries » Tue May 01, 2012 4:09 am
Miles wrote:The idea is to have one extra forum for general technology - all the items in the list... This would help to keep techniques from getting lost in vehicle specific forums.
+1 Another excellent idea by the genius Miles. 8)
When you start the subject area, I suggest you do the first post in each topic. Why? Because you can then go back in later in the future to reference build threads (newer build threads) or specific posts that appear that reveal the best ideas or techniques, etc. That first post of yours for each topic could/should provide links to the best threads or posts you know of. So, it becomes "the sticky" for the thread. Of course, others can add more info, etc. as time goes on doing new posts after that initial 1st post of yours. But at least you will have that reserved space to edit & change as time goes on. :wink:
Great idea, Miles. :D
deVries
Postby MitchJi » Sat May 05, 2012 7:00 pm
Hi,
What are we waiting for?
I could have used it (not a big deal) for this:
http://endless-sphere.com/forums/viewtopic.php?f=7&t=39447
heavy duty (50lb & 250lb) releasable-reusable nylon zip ties
Best Wishes!
Mitch
MitchJi
Postby TylerDurden » Tue May 08, 2012 12:14 pm
Let's kick off this new section with my self-serving question about cutting & machining aluminum:
I don't own a mill. I have a lathe, tablesaw, drillpress, bandsaw, jigsaws, routers, mitersaws and angle grinders.
I'd like to cut and dado 5/16" thick 6061 flat aluminum. One cut is 5/32" wide and one is 9/16".
I can send it to a shop or get a buddy to mill it... but if it can be done in a home shop, I'm game to try.
Doable?
p.s. I tried to upload a .stp file, but nogo. :(
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby Miles » Tue May 08, 2012 12:19 pm
TylerDurden wrote:p.s. I tried to upload a .stp file, but nogo. :(
Just rename the file as PDF or Zip it. :wink:
Miles
Postby Thud » Tue May 08, 2012 4:20 pm
TD,
Your table saw will make that part in short order.
I would use a triple chip low angle blade & take several passes to work out the rough channel, then you can make a pass on the router table with carbde tiped bit for a nice finish.
The challange will be the .062"w grooves.....I would look for a thin kerf skillsaw blade (again in the table saw) & take shallow passes till you reach desired depth.
I will also recomend making some good push blocks as the alloy will generate some heat while is being cut. Save yourself a tense moment of hot fingertips in the middle of a pass.
So when are we going to see this new section Miles?
get some......
Thud
Postby Miles » Tue May 08, 2012 4:33 pm
Thud wrote:So when are we going to see this new section Miles?
Good to see everyone's keen.. :)
Soon, hopefully... We're discussing it in the context of other changes.
Miles
Postby liveforphysics » Tue May 08, 2012 4:37 pm
I'm excited for the new section. :-)
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby Miles » Tue May 08, 2012 4:38 pm
Keep them coming. It's all useful ammo :)
Miles
Postby TylerDurden » Tue May 08, 2012 11:51 pm
Thanks for the tips gents. I am revising the plan and I will post it in the new section when all is ready.
Have a Nice Day,
TD
TylerDurden
Postby Miles » Wed May 09, 2012 2:52 am
I've requested that .stp and .dxf be added to the file types accepted for upload.
Miles
Postby Miles » Wed May 09, 2012 8:48 am
.dxf and .stp file types now enabled for upload.
Miles
Postby TylerDurden » Wed May 09, 2012 5:26 pm
Testing...
"The extension stp is not allowed."
Have a Nice Day,
TD
TylerDurden
Postby RWP » Wed May 09, 2012 6:20 pm
Thank you Miles! I like this idea a lot.
Thud and I were recently reminiscing about the lost foam casting process. I think casting and casting processes are underrated here at ES and would love to see these and other areas Miles and others mentioned above get some airplay in a section of their own.
I have been around ES for several years now and have watched our evolution, with great interest. I noticed that something happened after the great betrayal and Justin's saving ES; some of us took a break. My break was around computer and health issues. No judgement here at all. So ideas and suggestions along these lines seem to me to be a good way to keep ES moving forward into it's next evolution.
Long live ES!
Roy
My electric vehicle projects Home of the eTownie & eCortina
Cortina V3 Turnigy 80x - HV 160 - 48v 15Ah
Cortina Revisited Turnigy 80x - HV 160 - 48v 15Ah
Cortina Hard Tail Build Cortina Triton DS - eFlite 160 - 36v 10Ah LiPo - TURNIGY K-Force 120A-HV - Nexus 3 speed internal hub
RWP
Postby Ypedal » Wed May 09, 2012 6:52 pm
posted an update on the mod forum regarding the .stp files, it got added but something must not be set just right.. ( to anyone who's ever worked with phpbb ACP.. you know what i'm refering to.. :lol: )
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby TylerDurden » Wed May 09, 2012 6:58 pm
Testing...
EStrusion1.dxf
(772.89 KiB) Downloaded 22 times
:mrgreen:
Have a Nice Day,
TD
TylerDurden
Postby Thud » Wed May 09, 2012 7:35 pm
hehe,
very nice.
get some......
Thud
Postby MitchJi » Thu May 10, 2012 10:13 pm
Hi Tyler,
TylerDurden wrote:I don't own a mill. I have a lathe, tablesaw, drillpress, bandsaw, jigsaws, routers, mitersaws and angle grinders.
Doable?
Definitely!
I think you could get good results using an Abrasive Saw Blade like this in a table saw or worm drive skill saw:
http://www.amazon.com/DEWALT-DW3511B5-Performance-Cutting-Abrasive/dp/B005B8LVUY/ref=sr_1_18?s=power-hand-tools&ie=UTF8&qid=1336704083&sr=1-18
DEWALT DW3511B5 7-Inch High Performance Metal Cutting Abrasive Saw Blades, 5-Pack
Price: $15.16
I got a pretty clean cut, using a blade like that with a worm drive skill saw. Two 6' cuts and one 4' cut.
Based on Thud's comments one of these should work even better (and cost a bit more):
http://www.lenoxtools.com/Pages/Product.aspx?productId=MetalCuttingCircularSawBlades
LENOX METAL CUTTING CIRCULAR SAW BLADES
A Faster Way to Cut Metal™
EXTENDED LIFE
Titanium carbide tipped
Resists material build-up on teeth
CLEAN, COOL CUTS
Less burr than abrasive blades
No need for secondary grinding
Reduces material burning
MODIFIED TRIPLE CHIP GRIND
For added durability
RESHARPENABLE
Aluminum - Copper - Brass
Code: Select all
Diameter
IN             MM    PROD NO          TOOTH COUNT    RPM
7-1/4        184    21882AL714060CT    60       5800
10            254    21887AL100080CT    80        5200
12            305    21889AL120080CT     80        4000
14            355    21892AL140080CT     80        3000
Some choices:
http://www.amazon.com/s?ie=UTF8&rh=n%3A552292%2Cp_n_feature_browse-bin%3A387631011%2Cp_n_feature_keywords_browse-bin%3A2801548011&page=1#/ref=nb_sb_noss?url=node%3D552292&field-keywords=aluminum&rh=n%3A228013%2Cn%3A!468240%2Cn%3A328182011%2Cn%3A552262%2Cn%3A552286%2Cn%3A552292%2Ck%3Aaluminum
Best Wishes!
Mitch
MitchJi
Postby TylerDurden » Sat May 12, 2012 6:14 am
Thanks, Mitch.
Testing .stp 214 upload...
Still no joy. :(
Have a Nice Day,
TD
TylerDurden
Postby TylerDurden » Sat May 12, 2012 6:16 am
On the subject of tools, a new place has opened in southern MI:
$100/mo. (or $900/yr) membership provides access to shop, training & tools.
http://maker-works.com/
Have a Nice Day,
TD
TylerDurden
Postby Miles » Sat May 12, 2012 6:35 am
Test
edit: DXF seems to work ok. We're investigating why .stp files are rejected......
9 spline dimensions.dxf
(46.84 KiB) Downloaded 8 times
Miles
Postby Miles » Sun May 20, 2012 1:23 pm
Miles
Postby MidnightRider » Tue May 29, 2012 12:18 am
maybe fixtures, or diy (best ones?)
MidnightRider
PreviousNext
Return to General Discussion
Who is online
Users browsing this forum: mediumrare and 7 guests
