Forum section: "Materials, techniques, processes and tools"?
Re: Forum section: "Materials, techniques, processes and too
Postby Thud » Wed May 09, 2012 7:35 pm
hehe,
very nice.
get some......
Thud
Postby MitchJi » Thu May 10, 2012 10:13 pm
Hi Tyler,
TylerDurden wrote:I don't own a mill. I have a lathe, tablesaw, drillpress, bandsaw, jigsaws, routers, mitersaws and angle grinders.
I'd like to cut and dado 5/16" thick 6061 flat aluminum. One cut is 5/32" wide and one is 9/16".
I can send it to a shop or get a buddy to mill it... but if it can be done in a home shop, I'm game to try.
Doable?
Definitely!
I think you could get good results using an Abrasive Saw Blade like this in a table saw or worm drive skill saw:
http://www.amazon.com/DEWALT-DW3511B5-Performance-Cutting-Abrasive/dp/B005B8LVUY/ref=sr_1_18?s=power-hand-tools&ie=UTF8&qid=1336704083&sr=1-18
DEWALT DW3511B5 7-Inch High Performance Metal Cutting Abrasive Saw Blades, 5-Pack
Price: $15.16
I got a pretty clean cut, using a blade like that with a worm drive skill saw. Two 6' cuts and one 4' cut.
Based on Thud's comments one of these should work even better (and cost a bit more):
http://www.lenoxtools.com/Pages/Product.aspx?productId=MetalCuttingCircularSawBlades
LENOX METAL CUTTING CIRCULAR SAW BLADES
A Faster Way to Cut Metal™
EXTENDED LIFE
Titanium carbide tipped
Resists material build-up on teeth
CLEAN, COOL CUTS
Less burr than abrasive blades
No need for secondary grinding
Reduces material burning
MODIFIED TRIPLE CHIP GRIND
For added durability
RESHARPENABLE
Aluminum - Copper - Brass
Code: Select all
Diameter
IN             MM    PROD NO          TOOTH COUNT    RPM
7-1/4        184    21882AL714060CT    60       5800
10            254    21887AL100080CT    80        5200
12            305    21889AL120080CT     80        4000
14            355    21892AL140080CT     80        3000
Some choices:
http://www.amazon.com/s?ie=UTF8&rh=n%3A552292%2Cp_n_feature_browse-bin%3A387631011%2Cp_n_feature_keywords_browse-bin%3A2801548011&page=1#/ref=nb_sb_noss?url=node%3D552292&field-keywords=aluminum&rh=n%3A228013%2Cn%3A!468240%2Cn%3A328182011%2Cn%3A552262%2Cn%3A552286%2Cn%3A552292%2Ck%3Aaluminum
Best Wishes!
Mitch
MitchJi
Postby TylerDurden » Sat May 12, 2012 6:14 am
Thanks, Mitch.
Testing .stp 214 upload...
"The extension stp is not allowed."
Still no joy. :(
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby TylerDurden » Sat May 12, 2012 6:16 am
On the subject of tools, a new place has opened in southern MI:
$100/mo. (or $900/yr) membership provides access to shop, training & tools.
http://maker-works.com/
Have a Nice Day,
TD
TylerDurden
Postby Miles » Sat May 12, 2012 6:35 am
Test
edit: DXF seems to work ok. We're investigating why .stp files are rejected......
9 spline dimensions.dxf
(46.84 KiB) Downloaded 8 times
Miles
Postby Miles » Sun May 20, 2012 1:23 pm
Miles
Postby MidnightRider » Tue May 29, 2012 12:18 am
maybe fixtures, or diy (best ones?)
MidnightRider
PreviousNext
Return to General Discussion
Who is online
Users browsing this forum: Bing [Bot] and 8 guests
