LED bike lane laser tail light
Postby sk8norcal » Sun May 06, 2012 3:39 am
saw a guy with one,
he said he got it on ebay...
edit, probably a copy of this,
http://www.lightlanebike.com/
sk8norcal
Re: LED bike lane laser tail light
Postby dogman » Sun May 06, 2012 5:47 am
Unfortunately, only works if the car drivers are looking out the front window. Cool idea, but I question its effectivness on drivers in the USA.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby kfong » Sun May 06, 2012 10:18 am
Nice idea, but only useful if you use lasers with industrial outputs that can slice the cars if they get too close :mrgreen:
kfong
Postby oatnet » Sun May 06, 2012 10:50 am
Half price sale today, $18 shipped. I had to buy one.
http://www.ebay.com/itm/Cycling-Bicycle ... 898wt_1120
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby SamTexas » Sun May 06, 2012 11:01 am
Sounds like a good idea. I wonder if it actually helps in real life.
SamTexas
Postby cal3thousand » Mon May 07, 2012 4:32 pm
SamTexas wrote:Sounds like a good idea. I wonder if it actually helps in real life.
I saw a guy riding with one a few weeks ago, it seemed pretty cool. I definitely noticed, but I was pulling up on my bike. Not sure if everyone would see it, but it can't hurt right?
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby dodjob » Mon May 07, 2012 4:41 pm
Felt beer-cruiser MAC 8T lifepo4 36V12AH 12FETS4110 http://www.bavarian-ebikes.com
dodjob
Postby snellemin » Mon May 07, 2012 4:57 pm
I've seen it. It works when it's really dark. Other than that, it's useless. A bright flasher works better.
49.6mph EVG SX w/24S2P, 12fet Lyen sensorless ESC, Magic Pie II
32mph Fuji MTB w/14s1p 6fet Lyen sensorless ESC, GNG+LR kit, Zombie throttle interface
snellemin
Postby goinmobile » Tue May 08, 2012 1:55 pm
I got a contractor lazer, bought cheap from an auction house.This sat on a stand & finds its own level , has a spinning mirror that spreads the red light 360". It has a speed control, from a slow flash to solid appearance & beam width control. 1000 foot range. Still had some juice in the battery, rotates, but no light. SO I got to check if its because of low voltage. Its 12 or more year old, need to remove battery rather than jury rig a charge or fire.
These used to bother my eyes on construction sites, that was a narrow beam for a drop ceiling grid. The wide beam should be useful, flashing red will get a ticket, narrow beam might get me run over, "didn't see the bike, blinded by this red light". Wide beam should lightup everthing at 100 meters.
Then I got me some road line powder, them reflector beads spread on the fresh paint. Figure out how to glue on outside bike surfaces without wasting it. Catch the truck at night when the crews are working, bring your own container, you may snag a liter or two. Wait till one guy is running the machine, then hit the powder guy when he returns for another pail of beads. The spray guy is the crew boss. Its happenin" now.
Thanks for the reminder by your post. Anyone know technical on the laser used in the device?
goinmobile
1 W
1 W
Postby Ypedal » Tue May 08, 2012 2:51 pm
found one from hong kong 12$ shipping.. should be good for the trike..
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby Ypedal » Tue Jun 05, 2012 8:57 am
took almost a month, but it arrived this morning ! 8) ( taking pictures.. more in a bit )
Ypedal
Postby Ypedal » Tue Jun 05, 2012 2:26 pm
Nice box ! ( magnetized lid ) .. but was shipped in a brown bubble envelope so.. the corner has the expected crunch..
Uhm... :lol:
1- Pis ?... Please..
Should say " Please remove 3x screws from back cover
2- Pis put 2pcs AAA battery and lid the bicycle light
Should say " Please use 2x AAA batteries and reinstall rear cover
3- 2 " Buttons " lol...
A and B are just as badly translated... if i was going to spend this much money and time to make a product, the least i would do is insure proper translation.. this is hilarious on such a nice packaging.. i'd expect this on a photocopied piece of paper badly folded .. as sold on ebay.. but wow.
Enviromental Material ! lmao...
Ypedal
Postby Ypedal » Tue Jun 05, 2012 2:33 pm
fitted foam ..
Unit + 2 rubber shims + mounting ring for the seatpost.
Rubber gasket behind the cover. pretty good in general...
:lol:
Ypedal
Postby Ypedal » Tue Jun 05, 2012 2:48 pm
2 buttonS .. . you have to cycle thru all the modes to turn it off.. should be a " Hold button to turn off " or something like that.
the LED's are pretty bright,,. and you can combine laser or either one by itself ( LED and LASER )
The mounting bracket has a quick-release lever so you can remove the light from the bike, leaving the bracket behind. slide rail type..
Now if the weather can clear up i can give it a test... this week is nothing but cold temps and rain.. argh.. and i'm on vacation ( so .. well.. even if the weather sucks.. i'm home enjoying life ! )
Ypedal
Postby heathyoung » Tue Jun 05, 2012 6:01 pm
Now retrofit it with 2 10mW 632nm laser diodes :)
http://secure.oatleyelectronics.com//pr ... 92da6872b6
Hehe... :mrgreen:
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
FREAKIN LAAAAZER - Bicycle Lights
Postby BATFINK » Thu Jun 07, 2012 6:21 pm
Just seen this on ebay - quality does look a little crude but are they a good idea, looks good to me.
http://www.ebay.co.uk/itm/New-2012-Bicy ... 688wt_1315
BATFINK
Re: FREAKIN LAAAAZER - Bicycle Lights
Postby BATFINK » Thu Jun 07, 2012 6:22 pm
Oh and could the LED's be replaced by some really bright Cree led's?
BATFINK
Postby cal3thousand » Thu Jun 07, 2012 6:35 pm
I think there's a thread floating around here about those lights.
About the cree's ... anything can be retrofitted with the right knowledge. I don't think those things run a high enough voltage, out of the box. LiPo ftw
cal3thousand
Postby Ypedal » Thu Jun 07, 2012 7:05 pm
Ypedal
Postby Ypedal » Thu Jun 07, 2012 7:11 pm
heathyoung wrote:Now retrofit it with 2 10mW 632nm laser diodes :)
Hehe... :mrgreen:
So.. i'm ordering one of these... seriously... but do i need a driver for it ?.. or does the " module " include all i need to simply apply proper voltage ?
Ypedal
Postby John in CR » Thu Jun 07, 2012 10:09 pm
I heard blinkies hypnotize the drunks and bring them right into you, and while the lines are cute they are too thin to be seen by motorists. A strong rearward facing red with clear facing down to light up the road all around the rear of the bike, just like millions of motorcycle lights have, is the way to go. They've been at it for decades, so why not follow their lead? While you're doing lights don't forget the brake lights and turn signals, so you can signal your intent to the drivers behind instead of leaving them guessing.
John in CR
Postby amberwolf » Fri Jun 08, 2012 4:58 am
John in CR wrote:A strong rearward facing red with clear facing down to light up the road all around the rear of the bike, just like millions of motorcycle lights have, is the way to go.
Like this:
using pretty old (80s?) Honda motorcycle lights (and an '85 Ford LTD headlight)
Vs typical bike lights:
using pretty bright LEDs.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby SamTexas » Fri Jun 08, 2012 5:54 am
amberwolf wrote:Like this:
:) And what is the power requirement for that setup? 50W, 75W or 100W?
SamTexas
Postby amberwolf » Fri Jun 08, 2012 2:45 pm
With just the taillight and front markers it's 25.4W.
With headlight too (whcih is a highbeam cuz I can't find the other regular one), it's 86W.
With brakelight too, it's 105.1W. (that is as-pictured above)
With a signal going, it's 150.2W but that may be partly the surge current as the reading doesn't have time to stabilize before it turns the light off.
I find it acceptable, since this lighting makes a huge difference in how cars react to me on the road, even on this bike (even moreso on CrazyBike2).
If I were to do what I did on CrazyBike2 and replace the taillight bulb with the CFL, it'd be just as brigth as on full braking, all the time, with only a few percent of the power usage of the taillight. Then I'd use either a "3rd brake-light" bar like on CB2 or a separate LED motorcycle taillight for the brake light.
Same for the markers/signals, where on CB2 they are little LED MR16 units that Texaspyro sent me to play with, kinda shoved into the space inside the incandescent-lamp holders. (but I would have to build a bit of electronics for those, first to run an always-on stepped-down voltage to them for front markers, diode-or'd with the signal flasher, and second to build an electronic (non-thermal) flasher that would operate at the much much lower currents used).
Then I'd only have the huge power consumption of the headlight. But so far, I haven't found an optics solution for LEDs or CFLs that gives me the right (useful and safe) beam pattern for a headlight, so actual headlights are the only thing that really work for me.
DayGlo Avenger has a similar setup, except it's just a red LED motorcycle taillight, no white light for plate lighting, so it doesn't have nearly the "presence" these others do. I have been contemplating adding some white LED or CFL lighting underneath it so that it isn't visible from the rear (just like the others), only below.
CB2's is even more effective than either of these others, though, because the taillight is above the big white cargo pods and rear wheel, just behind the 'bent seat, so it lights up the whole back of the bike below the light, as well as the road around it.
amberwolf
Postby SamTexas » Fri Jun 08, 2012 6:54 pm
amberwolf wrote:With brakelight too, it's 105.1W. (that is as-pictured above)
That's about 20% less than my power requirement at 18mph on flat.
SamTexas
Next
Return to General Discussion
Who is online
Users browsing this forum: Bing [Bot], chvidgov.bc.ca, Rassy and 8 guests
