Welding Steel to CrMo 4130
Postby nechaus » Thu May 24, 2012 9:16 pm
Hello..
Im just wondering if you can MIG weld steel to 4130 ???
I plan on welding the drop outs and some of the tube of a bike, if i cant ill simply use a nuts and bolts + jb weld
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Re: Welding Steel to CrMo 4130
Postby iamsofunny » Thu May 24, 2012 10:14 pm
Jody said he uses er70s2 to weld 4130 because it flows better
I bet s6 would also work
iamsofunny
Postby Farfle » Thu May 24, 2012 10:20 pm
ER70S2 is what I use. Works well on chromoly and mild steel.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby nechaus » Thu May 24, 2012 10:24 pm
I just don't want to make anything weak from my welding inexperience, iv done a bit of welding but not alot.
The room im using wont have much air movement, i plan to let the weld cool as slow as possible.
I should have just got a cheap crapper steel bike to do this build but i got a new monogear mongoose. its a nice big frame
I should really look into doing some kind of welding class if they have such a thing.
Peak 6kw Air cooled
20s 16ah
60 kmh,
nechaus
Postby nechaus » Thu May 24, 2012 10:25 pm
ER70S2 for tig welder?
I only have a cheap $350 mig welder
Peak 6kw Air cooled
20s 16ah
60 kmh,
nechaus
Postby Farfle » Thu May 24, 2012 11:15 pm
http://www.wayfair.com/FirePower-Mig-Wi ... 49-FRP1041
The MIG wire seems to have a higher silicon content, should work just fine.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby nechaus » Thu May 24, 2012 11:20 pm
thanks, ill give it a shot!
i think ill weld it all up and then try some small jumps with out the motor powering me.. if it seems to be fine..
ill use it
Peak 6kw Air cooled
20s 16ah
60 kmh,
nechaus
Postby MidnightRider » Tue May 29, 2012 12:04 am
you may need to heat treat it after welding (Normalize it after welding) to make it all uniform strength (Normal). That may be difficult for larger parts and may distort it, which would require some kind of straightening after. Here's a link to a .pdf with some more info on the 4130 alloy...
http://www.uvm.edu/~dhitt/me124/TensileTestNotes-II.pdf
MidnightRider
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 2 guests
