E-bike Fall
E-bike Fall
Postby boppinbob » Wed Jun 06, 2012 6:17 pm
I knew it was going to happen at some point and it did. I went over the handle bars going to work the day before yesterday. It was totally my own doing and I wasn't wearing any safety gear. I had just gotten new handle bars with a 5.5 inch rise to combat the wrist fatigue the day before.(I find I don't rest so much weight on my hands and sit straighter on my mtn bike. To hell with watt/hr economy.) Anyway, I didn't have the handlebars wrenched down super tight because I wanted to make it easier to make final adjustments to get "the perfect position". I came off the road to get to a path with the goal of putting some distance from me and a car. I pulled on my front brake lever too hard and my momentum pushed the handle bars out and down...fast. I followed the handle bars out and down. The only damage to me was a raspberry hand and dirt on my bike. Lucky in some respects. I'm 55 and don't heal as fast as when I was 18. Life's a bitch that way.
PS I continued on to work and got there on time.
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
boppinbob
Re: E-bike Fall
Postby amberwolf » Wed Jun 06, 2012 6:27 pm
I sympathize. The bicycle that years later became DayGlo Avenger was orignally a Columbia Comfort Bike, and when it arrived in late 2005 I began riding it to work in place of walking. About a month after I got it, the weld on the stem just snapped while riding along, and I was left holding handlebars that no longer connected to my steering. :shock:
The results were likely similar to your own crash, though I hit the edge of a planter curb and flipped multiple times in the air before landing on the piont of my right shoulder. Nothing broke, but I felt like it had for the next few days or more, and wasn't very useful at work.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Re: E-bike Fall
Postby cal3thousand » Wed Jun 06, 2012 6:44 pm
First couple weeks of e-biking when I got my first raspberry. There was a street sweeper on the bike path and like an idiot, I decide to go around him instead of waiting for him to pull over. Went up on a bank and didn't turn back down fast enough. Heavy battery and laptop made my tires slide down the slope sideways.
I always where gloves now.
Glad you are OK, because it could have been worse in traffic. :shock:
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Re: E-bike Fall
Postby John in CR » Wed Jun 06, 2012 7:12 pm
Intentionally didn't tighten handlebars....really? Get that video rolling for every ride so we don't feel so left out. :mrgreen:
Stay, I mean get, safe.
John
John in CR
Re: E-bike Fall
Postby boppinbob » Wed Jun 06, 2012 7:41 pm
They were tight enough to stay in place under normal circumstances, but not with me doing a handstand on them because of an unexpected tire sliding stop downhill. They are cranked down tight enough now they will still be in place whether or not I go over them.
boppinbob
Re: E-bike Fall
Postby boppinbob » Wed Jun 06, 2012 7:49 pm
That would have made a great youtube clip. (I know I'm going to get negative karma for thinking that.)
boppinbob
Re: E-bike Fall
Postby amberwolf » Wed Jun 06, 2012 11:52 pm
Yes it would have. :lol: I probably could've gotten a million hits and be rich!
amberwolf
Re: E-bike Fall
Postby mauimart » Thu Jun 07, 2012 4:56 am
This is a timely post. I just had my first e-bike fall/crash today. Not a result of loose handle bars but rather a bit of complacency. From the video you see that I take a quick look behind me, then advance the throttle which causes the front wheel to lift off the ground and the rest is history. Oh well at least I had a camera running.
mauimart
Re: E-bike Fall
Postby dogman » Thu Jun 07, 2012 5:51 am
I've had similar experiences with newly installed handlebars that I thought I had tightened up good. Then while riding, they start to wiggling. Taught me to test stuff before going out on real rides.
Re the vid, good power, skinny tire, loose gravel. Part of why my dirt bike has the fattest rear tire that will fit. Laying er down is something to need to practice anyway.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Re: E-bike Fall
Postby leffex » Thu Nov 22, 2012 2:14 pm
Add me to the list.
Fell om my bike yesterday in a death bend that was going down hill as they do. When I just got to it I was at full speed braking so went down from 30 to about 10mph. Braked out of the bend and down in the grass, leaning it right and then continued with my body hitting right axle in the ground.
I think I missplaced my axle so needs a bit of healing.
Not fun so wear protection
Its more common to have an accident with a bike with an injury than a car so think about it. 40-60 percent is over-arm/axle injuries including head injuries.
Careful out there ES members. Take care of yourselves. :)
My old bike 300W. 2012-06- 2012-08
New bike Leaf 1000W, 54V,30A,10AH) commute 2012-11-
leffex
1 W
1 W
Re: E-bike Fall
Postby Kingfish » Thu Nov 22, 2012 7:45 pm
Definitely can sympathize with you! Last time I wrecked by my own accord I was cornering downhill and got mired on the inside into gravel and hit the brake too hard – faceplant into the gravel. :oops: I looked like I was beaten with an ugly stick for two weeks. That was about 4 or 5 years ago.
The last time I had a “mishap” - meaning I lost control and spilled but did not crash proper - so to speak was on the dirt road heading into the family farm in the forest on July 2nd 2010 when I was run off the road by 3 motocross bikes. That one hurt my pride more than anything cos the evil buggers got away! :evil:
Knock wood something worse has not happened. To that – I am thankful.
Happy Turkeygobble, KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9653 miles-to-date, 4163 as 2WD.
Kingfish
1.21 GW
1.21 GW
Re: E-bike Fall
Postby The fingers » Thu Nov 22, 2012 8:23 pm
I've hit two unexpected patches of sand with the same results over the years; lost a big patch of the skin on my big toe each time, because I was wearing only sandals. :oops:
Black Schwinn High Sierra
Blue Schwinn High Plains
Blue Schwinn Cruiser 5
Black Fiore Cruzer 5: Amped Warp Drive 26" Front DD/SLA kit
18 months, 3000 miles, 300 cycles
http://ghostbikes.org/
http://www.rideofsilence.org/main.php
Hebrews 9:27
The fingers
Return to General Discussion
Who is online
Users browsing this forum: mark5 and 2 guests
