John Bozi
This is my build blog where I started by asking should I use my old heavy bike or new carbon bike for a cheap chinese kit.
What happened over the many pages was that I was convinced to go with the cheap bike with the cheap kit.
However that went to cheap el crapo land and then I paid some real money for a decent kit and a new Hasa bike. You can see it unfold or you could just jump to where my hasa FS 4065 road bike is by jumping ahead.
Keep cool and check out my channel of how my bike is running.
Also the electric bike is now for sale.
If I had to build this bike again (not taking shipping into account on most items)
This includes:
$580 AU 4065 motor http://www.crystalyte.com.au/ you can have the 26" rim and spokes/nipples and a couple of used hookworm tyres that have lots of life in them.
$36 Au 7 speed freewheel 11t-? cassette http://glowwormbicycles.com.au/store/e-bike-parts-and-accessories/freewheels/dnp-epoch-screw-freewheel-7-speed-11-34t-ebikes
$175 US 40 amp controller http://www.ebikes.ca/shop/ebike-parts/controllers/c7240-nc.html
$150 US cycle analyst v3 DP http://www.ebikes.ca/shop/ebike-parts/controllers/c7240-nc.html
$20 US throttle with regen button http://www.ebikes.ca/shop/ebike-parts/throttles/t-htwist-b.html
$40 main torque arm (heavy duty) http://www.evworkslab.com/products/rear-bolt-on-torque-arm
$50 drive side http://www.evworkslab.com/products/rear-bolt-on-torque-arm these are both quite heavy for shipping.
$1300 US for the bike http://www.cyclingdealusa.com/HASA-Mountain-Bike-p/xc1d11.htm = you can have all the parts to convert it back to a normal bicycle.
$65 AU zee short cage derailleur http://www.wiggle.com.au/shimano-zee-m640-shadow-plus-rear-derailleur/?lang=au&curr=AUD&dest=27&utm_source=pla&utm_medium=base&utm_campaign=au&kpid=5360535777
$85 dnm shock (save space without an oil reservoir) but you can have the original spring shock that came with the bike too if you don't need the space.
$230 race face chain ring custom shortened cranks and pedals
$50 dx32 19" rim
$80 black sapim spokes http://glowwormbicycles.com.au/wheelbuilding
$6 extension valve to pump up small wheels http://www.ebay.com.au/itm/MOTORBIKE-MOTORCYCLE-BIKE-TYRE-VALVE-ADAPTER-90-DEGREE-EXTENSION-NEW-/161235669721?pt=AU_Motorcycle_Parts_Accessories&hash=item258a6512d9&_uhb=1
$100 downhill or thick and tough tubes and tyres = high roller creepy crawler.
$65 wide downhill handle bar boo bar http://www.chainreactioncycles.com/au/en/truvativ-boobar-riser-bars/rp-prod67690?utm_source=Google&utm_medium=Shopping&utm_name=Australia&gs=1&gclid=CP61_Z__7b8CFdgRvQod510AGw&gclsrc=aw.ds
$3000
Negotiable - if needed:
Power supply $140 http://www.ebay.com.au/itm/SKYRC-eFuel-30A-540W-Switching-Dual-Output-DC-AC-DC-30-amp-Power-Supply-SK200013-/181263160222?pt=AU_Toys_Hobbies_Radio_Controlled_Vehicles&hash=item2a3420539e&_uhb=1
$170 2x ichargers 106b to balance charge safely
$700 6x6s & 2x3s 5.8AH turnigy http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14715
$50 2p harnesses
$1000
As you guessed it $4000 all up. Yes it isn't brand new but take into account all the false starts (stuff spent on things that didn't work) and all the shipping on individual items and all the work to customise all this to work together and I'd pay the same amount again.
For most of the above the shipping costs were not included.
This includes:
$50 dx32 19" rim
$3000
$50 2p harnesses
$1000
