They seem to keep restocking these lately so figure I would make a thread about how I open them. It is quick and safe and takes just a few minutes a pack.
This is the bit you will need to do it safely. The saw is not against the grain when it spins so it won't dig into the plastic. Unfortunately I threw away the packaging so I don't know the number of it but should be at any hardware store that has dremel stuff. Wrap the stem in kapton tape until there is about 1mm of the saw exposed. The plastic is just over 1mm thick so this keeps it from going too far in.
Cut three corners then pry up with a small flat head screw driver breaking free any extra plastic.
It is assembled as 2x 2s1p(crimp welded together) packs so you can unsolder them making 2x 2s1p packs or just leave them together.
