controller wiring
77giampiero
controller wiring
Post by 77giampiero » Nov 26, 2017 9:23 am
hello to everyone, thanks for the hospitality!
I have this controller and I want to use it only using the accelerator (throttle)
I only have a problem since I do not have the wiring connection draw, which of these wires do I use to "turn on" the controller?
thank you
Giampiero
IMG_20171126_150513.pdf
(4.49 MiB) Downloaded 23 times
marty
Re: controller wiring
Post by marty » Nov 26, 2017 10:34 am
Change image from PDF to JPG.
Might be helpful if you tell us manufacturer, model or where did you buy this controller. Any instructions?
MARTY
Volt Electric Vehicles
http://www.voltev.com
Hwy89
Post by Hwy89 » Nov 26, 2017 11:06 am
In many cases it is a single red wire (possibly the wire with no terminal in your photo) that can be connected to battery positive through a switch that will turn the controller on.
markz
Post by markz » Nov 26, 2017 1:47 pm
Try the red wire with its end stripped showing bare wire near the middle, then try the red wire to the far left with the lug (or loop) connector.
What is the green wire, with the green connector housing, I have similar on my hksunwin controller.
77giampiero
Post by 77giampiero » Nov 26, 2017 4:51 pm
Ok I try doing some attempts, I'll let you know just done.
meanwhile, thank you very much
77giampiero
Post by 77giampiero » Nov 26, 2017 4:53 pm
thanks also to you, I will try doing some attempts, I'll let you know just done.
many thanks
Giampiero
