Dual front brake disc?
rg12
Post by rg12 » Dec 04, 2017 11:08 am
Hey Guys,
I have this DNM fork that enable me to mount a caliper on the side I want, meaning I can mount two calipers, so I thought about the dream of the double disc thing.
The front hub with the double disc mount exist so I just need to look for it.
What I have left to solve is some kind of a Y adapter to split the hose to two calipers and also I need to know if I need some kind of a reversed caliper or I can just use a rear caliper in the front?
Mongoose EC-D 2007 (19" motocross wheels), 21s 10Ah LiPo, Greentime 72V 80A Controller, 12kg Hub Motor
Alan B
Re: Dual front brake disc?
Post by Alan B » Dec 04, 2017 12:17 pm
There are trike hydraulic brake setups that already come with all the right stuff. I have use a couple different ones on the Borg, described in that thread linked in my signature. It also uses DNM forks.
rg12
Post by rg12 » Dec 04, 2017 1:05 pm
Just looked for trike dual brakes or anything that may be close to that but no success.
I checked your borg thread and it didn't have any information about reversed second caliper or a way to control two calipers with one lever.
Alan B
Post by Alan B » Dec 04, 2017 3:28 pm
Really? As I said, and is covered in the thread (page 33 for the upgrade), I bought Trike brake sets, and they come with both front calipers, hoses with the Y already installed and already filled with fluid. Bolt on job. On the Volcano DNM Forks two mirrored calipers are required, so I purchased this type. One from Gatorbrakes, and later I replaced it with a set of Tektro Auriga trike Ebrakes, they have a parking lock and the switch to actuate the motor cutoff built into the handlebar lever.
rg12
Post by rg12 » Dec 05, 2017 10:45 am
Thanks alot, so the best bang for the buck (available from only one website) is the Auriga Twin for 200 euros.
Will check it out, thanks :)
Alan B
Post by Alan B » Dec 05, 2017 12:24 pm
It is hard to find dealers that carry the dual brakes, I don't recall the cost.
