travaglione
10 µW
I’m struggling with understanding the installation of the TDCM bottom bracket petal sensor installation.
I studied the instructions and videos from both Grin Teck and TCDM motor and endless sphere. To me, it seems like the crucial point is the alignment and orientation of the bottom bracket in the bottom bracket housing. I can see how you can make the two marks on the bottom bracket housing as it relates to the fork in the rear dropouts as instructed in the written instructions. It doesn’t seem that the bottom bracket sensor itself has any marks on it itself that can be seen externally. I understand that the orientated orientation has something to do with the notch on the bottom bracket that connects into the screw in cap. In the video that I got from TDCM motors which is in Chinese making it difficult to understand and expensive to translate. There is only one Mark on the bottom bracket housing that seems to relate to the bottom bracket sensor pin Bearing relationship line up. Any suggestions on how to learn how this bottom bracket is correctly installed
Paul
Paul
