DIY longtail -could it be this easy?
Postby gogo » Sun Apr 12, 2009 10:40 pm
Check out this guy's DIY longtail:
Although it won't allow for the same deck height over the back wheel, it might be more sturdy than an xtracycle. It should even be possible to replace the top struts with a long shock absorber to make a suspension longtail.
The rest of the pictures in full definition:
http://www.flickr.com/photos/7675758@N03/sets/72157611969221412/
gogo
Re: DIY longtail -could it be this easy?
Postby swbluto » Mon Apr 13, 2009 12:24 am
YES. I can totally see how this could work out. Place a suspension on the back attaching to the seat area, mount an R/C motor in the rear triangle like the "spoke monkey" and you have an extra handy, extra powerful comfortable bicycle. Perfect combination for hauling larger loads! Now only, if only, I had an area to do fabrication. :roll:
swbluto
Postby TylerDurden » Mon Apr 13, 2009 7:48 am
Nice... I would extend continuous struts past the seatposts: from over the wheel to the front of the original frame. That gets a strong rack and should reduce twist on the added section.
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby etard » Mon Apr 13, 2009 11:09 am
Right on TD, that's exactly what it needs. Also, it could be even easier to add a shock and extend a square bar through the bottom bracket as the pivot/ passenger pegs, if you wanted to add one.
etard
Postby dogman » Mon Apr 13, 2009 3:25 pm
Mabye just use a rear suspension bike for the rear part? Somehow, you could mount the downtube of the suspension frame so it aligns with the rear stays of the front bike. Hmm, I got lotsa frames laying around.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby Dee Jay » Mon Apr 13, 2009 10:41 pm
Hi dudes !
I love this idea. SO SIMPLE !
I found four abandoned bikes today, two 20" folders, and two 26" road bikes (?) I will see if I can legally acquire these puppies.
Check out my photochopped pic!
I may not have to build an extension for my Revive after all. And with junk bikes like these, I wouldn't feel too bad leaving it parked outdoors.
It won't be pedal forward.. but tandem enough to ride my son in the lower seat, baby girl in a child carrier at the rear, groceries at the front in large basket...
Since there won't be suspensions, I may build suspensions on both seat posts using fork suspension parts.
I'm still a bit fuzzy on how to connect steering linkages to the rear ... any ideas ? I would need to make the linkages detachable in order to fold the front for elevator rides as well as storage
This could hold me over till I get my monotube build (from scratch) done.
J
Dee Jay
Postby TylerDurden » Tue Apr 14, 2009 7:38 am
DJ, maybe make the back portion fold... fuji made a full-size folder in the eighties that you might copy:
pull the seatpost to fold
Have a Nice Day,
TD
TylerDurden
Postby Dee Jay » Tue Apr 14, 2009 10:03 pm
TylerDurden wrote:DJ, maybe make the back portion fold... fuji made a full-size folder in the eighties that you might copy:
Hi TD!
I'm not looking for a way to fold the 26" because the 20" is a folding bike.
What I'm trying to figure out is how to rig a handle bar under my saddle in such a way that would make it easy for me to mount the bike.. I'm not sure if having to turn the handle bar just so I get on the bike would be the best configuration or even safe.
The red line I drew is where I imagine the steering linkage would run, under my son's saddle, and possibly run further back under my saddle.
I was thinking of an ape-hanger rigged under his saddle but my concern of having the handle bar there is my son acting like a four year old *wink* and might interfere with the steering.
J
Dee Jay
Postby TylerDurden » Wed Apr 15, 2009 8:34 am
Dee Jay wrote:What I'm trying to figure out is how to rig a handle bar under my saddle in such a way that would make it easy for me to mount the bike.. I'm not sure if having to turn the handle bar just so I get on the bike would be the best configuration or even safe.
Maybe let the bar ends fold down, like motorcycle rear footpegs, inverted.
Have a Nice Day,
TD
TylerDurden
Postby vanilla ice » Wed Apr 15, 2009 1:12 pm
Check out the "home built xtracycle" thread here:
http://www.bikeforums.net/forumdisplay.php?f=261
Also, cheap old tandems are an easier way to get a longtail going..
75# ebike, 190# scooter, 370# motorcycle, 1900# car, 4900# truck..
vanilla ice
1.21 GW
1.21 GW
Postby Dee Jay » Fri Apr 17, 2009 10:21 pm
Great info Vanilla Ice, thanks!
Awesome builds on there. Very clean, solid, functional bikes!
My fave has to be this one with the M249 "SAW" ! :mrgreen:
J
Dee Jay
Postby Zoot Katz » Fri Apr 17, 2009 11:34 pm
Dee Jay wrote:Great info Vanilla Ice, thanks!
J
bah. A scabbard is only properly mounted on a front fork leg.
You've got enough seating for a tail gunner. Get one
Zoot Katz
Postby Mathurin » Sat Apr 18, 2009 6:57 pm
Yeah I built me one of these in spring two years ago, POS mtb + back end of a POS dual musher + old mtb handlebar + creative use of a drill, bolts & nuts, then two racks + a board on them + wood to make pegs and hand holder things, fenders, rear hub motor, lead batteries duck taped into nooks & crannies. Super easy and worked real good (frocking massive, musta weighed at least 40kgs, and handles like a truck...) Chopped it back into a shitty mtb last winter cause my legs sucked too much, still have most of the parts tho. Pretty sure Justin took a pic of it while we were on the plaines d'abraham. Super easy, just do it mang.
You have to know, not fear, that someday you are going to die. Until you know that and embrace that, you are useless. - Tyler Durden, Fight club. Ditch the fake identity you've created for yourself, walk your own way in a society of mindless drones to become real, you are not your social status.
Mathurin
Postby Dee Jay » Mon Apr 20, 2009 1:23 am
Zoot Katz wrote:bah. A scabbard is only properly mounted on a front fork leg.
On the fork leg ? That bike would handle like a pig!
Zoot Katz wrote:You've got enough seating for a tail gunner. Get one
Yeah, I can recruit my 4 year old as tail-gunner, like them congo militia do ... : lol :
Ok, bad joke. :(
J
Dee Jay
Postby Dee Jay » Mon Apr 20, 2009 1:27 am
Mathurin wrote:Super easy, just do it mang.
Hell ya, it's in the works.. made some calls to my peoples today. :D
J
Dee Jay
Postby dogman » Tue Apr 21, 2009 6:17 am
Hee hee, the one with the scabbard is a real New Mexico bike. I used to dove and quail hunt and had only a motorcycle for transport. Always my turn at a 4 way stop for some reason. :shock: :twisted: Hard to tell for sure, but that one looked like it had rear suspension.
dogman
Postby oldhaq » Tue Apr 21, 2009 9:29 am
My bike has added 24" mtb rear suspension. It wasn't too hard, welded up a bracket to bolt onto the rear triangle to take a shockie.
It feels great, takes a few corners to get used to the long wheelbase.
That allowed me to mount the batteries with a low centre of gravity, on the axis between the axles, and makes it easy to shift weight.
The hardest part was getting the chain clearance, the chain guide helps stop it swaying.
My bikes:
WCC Chopper longtail - viewtopic.php?f=6&t=235&start=360#p170594
Choppermeister and JJWCC - viewtopic.php?f=6&t=235&start=450#p246270
Huffy MTB viewtopic.php?f=6&t=235&start=450#p252774
BMC Super Trail viewtopic.php?t=42361#p619089
www.youtube.com/user/OLDHAQ
I thought of that while riding my bike.
Albert Einstein
on the Theory of Relativity.
oldhaq
Postby spinningmagnets » Wed Apr 22, 2009 11:32 am
oldhaq, thats a great idea! My personal taste is towards a different frame, but now I want one.
I haven't finished my first project, I'm still working on my second, and now I want to start this third...Endless Sphere is really starting to annoy my wife.
spinningmagnets
Postby dogman » Wed Apr 22, 2009 12:39 pm
I bet that rides real sweet. My mediumtail, that used to be the trike, is just about 4" longer than my MTB. Wow what a difference in the feel of the bike! It really corners nice to me. The seat on it is about 6" lower than the MTB. Unfortunately, it's just about 1" too long to fit on a bus bikerack. Might have to lower it some more, with 24" tires.
dogman
Postby spinningmagnets » Wed Apr 22, 2009 3:37 pm
Here's Justin on his "Cross-Canada" touring bike. One of the problems with a non-hub design is finding the space to mount the motor and possibly a 2-stage drive. Another problem is many people (especially older folks like me) prefer a seating position that is a little more laid-back.
I recently bought a MTB because it was the cheapest way to get fat tires, suspension, and a front disc brake. However, my first choice is not the standard handle-bar/seat geometry.
By using a hard-tail with a suspension A-frame added to the back, I can have all 3 things. Recumbent seat that is lower/farther-back than stock seat. Reversed handlebar head with laid-back "moustasche" bars. plenty of frame room for non-hub motor and gear-down. From my younger motorcycle days, I much prefer the Honda Rebel seating position (shown in pic) rather than the "sport-bike" seating geometry.
I now very much like the idea of a 26" front wheel (suspension/disc-brake) with 24" rear (dirt cheap at thrift stores) added to a hard-tail
"At what age do you tell a highway its adopted?" -Steven Wright
Last edited by spinningmagnets on Sun May 29, 2011 1:47 pm, edited 1 time in total.
spinningmagnets
Postby spinningmagnets » Thu May 14, 2009 11:23 am
The more I think about it...the next bike I would build might be a 26" hardtail with double disc brakes (I can add a rear V-brake, and use the rear disc wheel to make a left-side-sprocket for my wifes bike) and I add a 24" rear suspension arm from a $20 thrift-store MTB.
I had bought a 26" MTB from WM, for only $200 it had a front disc brake, but after converting it to a semi-recumbent ("beach cruiser" seating position) its a little tail-heavy/nose-light. When going uphill and hitting a small bump it almost pops a wheelie. I also noticed the front tire braking and steering isn't as solid as I would like because of the weight distribution.
Here's another longtail pic just for conversation. Its a "Madsen" saw one today, rear wheel is a 20", rear V-brake, no suspension. This is similar to what I think I might end up doing as far as size and layout...
[Edit: insert link] http://www.madsencycles.com/
Last edited by spinningmagnets on Mon Jun 01, 2009 10:36 am, edited 2 times in total.
spinningmagnets
Postby vanilla ice » Fri May 15, 2009 2:17 pm
I have a few old tandems, one a 60's frame with no rear BB installed. I guess that makes it a longtail. Great kid hauler, and was cheap also. I wouldn't trust the old frame with the weight of two adults anyway so it kind of works out.. I'm thinking of converting it to rear steer like Justin's (or double steer) with 4 heim joints and 2 linkages. Probly sucks to have my back blocking the nice view!
vanilla ice
1.21 GW
1.21 GW
Postby vanilla ice » Fri May 15, 2009 2:20 pm
dogman wrote: I used to dove and quail hunt and had only a motorcycle for transport. Always my turn at a 4 way stop for some reason.
Lolz. My buddy didn't own a four wheel vehicle until he was in his 50's. For a while he was wanting to take his gun to the shooting range on his motorcycle, and while technically legal, he was talked out of it by law enforcement. I don't think that would fly in socal.
vanilla ice
1.21 GW
1.21 GW
Postby spinningmagnets » Sat Aug 15, 2009 10:20 pm
Heres a DIY longtail build-log with pretty good pics:
http://www.velocide.com/cargo_bike.html
(58.76 KiB) Downloaded 378 times
spinningmagnets
Postby spinningmagnets » Thu Jan 14, 2010 9:23 pm
spinningmagnets
Next
Return to General Discussion
Who is online
Users browsing this forum: Icewrench and 4 guests
