Tonytoka83
- Joined
- Jan 4, 2020
- Messages
- 1
I currently purchased a Tail G 48v 12ah 2 seat scooter,and I had to replace the ignition switch,which I did,but after installing and turning the key..The horn,and outline of the battery(in neon green) showed up on the cluster display,and I heard a screech noise from under the second seat! So to my surprise I see a small box under the 2nd little seat that says,"TailG Smart-Drive" and there is a flap that reveals another charger port. Is this a alarm system?? And if so what can be done to overide it? Im so new to E scooters that I purchased it from LetGo for $200 and The seller said He lost the key,but a new ignition switch(Which I ordered from ebay for $4 u.s),Was installed and it turned over like i said but the blinkers,lights etc wont work also I turn the throttle and nothing! Mind u its making a weird noise from a "Small black box" under the 2nd seat...Please anyone if u can help I hope this makes sense and is fixable..
