After 5000km ride experience on my scooter i have some modifications done and planned for upcoming week.
First i noticed that after each work ride which is aprox 50km i use an average of 18 amps of power.
My pack consists of 24S4P lipo which is 110.8V at 20Ah
These packs were build as follow: 3 packs of each 4 turnigy 6S 5Ah 20C , 1 pack of 4 turnigy 4S 5Ah 20C and finally 4 pieces of 2S 5Ah 20C.
These last 4S and 2S packs were bought in time to go from 22S to 24S , and not having much budget left to do some Lipo shopping at HK
thats why i bought some 2S packages instead of 4 6S packages. I don't have any trouble with this setup and each pack keeps perfectly balanced within safety range. ( 0.05V max)
I'm very pleased with the meanwell charger setup. These consist of 2 48V 8A MW which are in series and one is limiting the current for 8.6A.
Both are also modified with the fan resistor. The chargers aren't get any hot during charging.
Ok..so to get back...i had 20Ah total and i use like 18A ..so i decided to buy 1P more for the total setup. so ordered at HK 3 6S packs ,one 4S and a 2S. each 5Ah 25C packs..
Now i'm busy with re-organizing the packs into my scooter. My first setup was a bit messy .
old setup
New setup * Coming soon this week *
INSTRUMENTS PANEL
I did an update for my instrument panel. i was irritated by my instruments and CA setup which were hold on my steering bar with tape etc.etc.
I just wanted a clean dash ! so i pulled of the old speedomeer and build in my CA together with some LEDs for turn signals and a temperature LCD meter whch sensor is located in the controller. If it's above 50C then i put on he blowers to get it arround 39 again.
My speakers consist of a Ipod logitech amp is temporarly. i will change this with a small booster and some real speakers on the lower side dashmount.
NEW DISPLAY SETUP
LED LIGHTING
I just ordered some LED lightstrips blue colored. hopefully they will arrive on friday..
I want to place them - under rear wheel - on bottom plate - on dashboard
Just to get a Sci-Fi looking scooter riding at nights...
These lights will be switched seperatly by remote...
My next gadget i want to build in is a servo motor controlled by a servo tester to adjust my headlight heigh.
Servo metal gear 2.5Kg
And servo tester
UBEC power from a seperate lipopack under my seat (4S4P) which i use for power all led lights,alarm,usb-power,remote receiver..etc etc
Pictures of this modification will follow after lip pack re-installation..
Well that's it for now...
I'm very hapy with my setup ! every day i hope it will not rain/storms so i can use my scooter! otherwise i will have the useuall traffic jams to get to work...
