I have also thought about a contactor exactly like the boost setting he has on his kart, but engaging it when you are headed for a main straight, like upon exiting a turn or something. could be deadly though
JUICED wrote:It is Called ENOS. Electric Nitrous. And it hits just like a Nitrous bottle on an ICE bike.
To make it consistent and controllable, we used a timer and had a second contactor. That way you can still use the controller
to ride up to the line and back and have a bunch of power for the run.
I have a schematic if you want.
EV Ed
AussieJester wrote:JUICED wrote:It is Called ENOS. Electric Nitrous. And it hits just like a Nitrous bottle on an ICE bike.
EV Ed
Would very much appreciate it yes Ed thanks in advance mate
@ChriS...i don't think i would be using it on a road racing bike buddy, need smooth power delivery not a BAM
when you exit the corner, think it would definately be deadly mate haha...BUT...by all means try it
just let me know which corner at Barbegello Raceway to sit and capture the aftermath on camera, for YouTube![]()
KiM
JUICED wrote:AussieJester wrote:JUICED wrote:It is Called ENOS. Electric Nitrous. And it hits just like a Nitrous bottle on an ICE bike.
EV Ed
KiM
I will send after I get home from work.
Hillhater wrote:AussieJester wrote:.... i freakin LOVE the idea of the boost switch!!! Can see that being implemented in the drag bike project Timma2500 & myself have in the works definitely!
..should not be necessary assuming you chose the right controller ?![]()
..but ....thinking "out of the box".. do you really need a controller on a brushed E drag bike ?
.. could you not just use progressive voltage switching..?? IE.. 10S, ..18S, ..24S or whatever suits.
could save some kilo's and $$$'s if it worked. ?
allen_okc wrote:To make it consistent and controllable, we used a timer and had a second contactor. That way you can still use the controller
EV Ed
allen_okc wrote:Unite motors - dont do it, you see how they end up
allen_okc wrote:a
i also found a wheel for it -
JUICED wrote:
Get the widest you can!
Carefull make sure it has the largets foot print on the ground you can get.
Simply going to the widest tire possible will cause the sidewall to roll under and cause more of a curve in the center of the tire giving you less contact patch with the pavement!!!
allen_okc wrote:- i believe i have to get eight of the 22.4 packs, or do i need more?...
Hillhater wrote: If you are still planning on the 48v class,
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: No registered users and 3 guests
