Another RG250 with Colossus Motor
Re: Another RG250 with Colossus Motor
Postby Arlo1 » Wed Aug 17, 2011 8:51 am
markobetti wrote: And anyway i still dont think its that hard for controller ; 36 fet- working and tested , splinter kelly working, my kelly - working, new sinewave contrl - will work - i think well check it at saturday....
Yeh but its a shame to run with these little controllers. We need a 50kw controller for it. Then we can see the real power! We need epic phase amps! Im working on it buddy ;)
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby gwhy! » Wed Aug 17, 2011 10:20 am
:D I have worked on it but need a motor to test it :wink:
gwhy!
Postby Arlo1 » Wed Aug 17, 2011 3:12 pm
Gwhy. Post your controller build on my not simple diy controller thread.
Arlo1
Postby gwhy! » Wed Aug 17, 2011 4:54 pm
Arlo1 wrote:Gwhy. Post your controller build on my not simple diy controller thread.
I will post all details when Im happy with it.. :D
gwhy!
Postby Arlo1 » Wed Aug 17, 2011 11:41 pm
Can you pm me how its going and any details?
Arlo1
Postby Whiplash » Wed Aug 17, 2011 11:54 pm
Gwhy, this is the last thing you need! LOL! Your friggin little $50 motor does the same speed this big one does! If you get a hold of it you'll kill yourself! HAHA!
EPIC build here mate!! I would LOVE to do something like this, but I am barely on a bicycle budget, let alone a Motorcycle!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby Arlo1 » Wed Aug 17, 2011 11:56 pm
Please.... I will give you a good deal when I am a North american collossus dealer!
Arlo1
Postby SplinterOz » Sat Oct 15, 2011 2:54 am
Ok just a few tweaks. I put on the timing adjuster and have reduced the amp draw at full rpm. I have also changed the motor current settings and gained a little more acceleration and speed. Now uses about 100amps (battery) and gets up to about 85km/h. I should be getting the battery mounting gear soon. Then we should be cooking with gas :)
SplinterOz
In the Capital of Australia
http://rgelectric.wordpress.com
SplinterOz
Postby jonescg » Sat Oct 15, 2011 3:36 am
This will require a test ride tomorrow, you know :)
See you about 11 am or midday?
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby SplinterOz » Sat Oct 15, 2011 3:54 am
Any time and yes a ride is in order
SplinterOz
Postby SplinterOz » Tue Oct 18, 2011 6:49 pm
Here is the bike running.
Note the 1030 is the battery Amps multiplied by 10, using a neat gizmo from Zeva to drive the tacho.
So for the hard of seeing...
78km/h
67 Volts (boy these headways sag)
103 amps
This makes for 6.9Kw for 78Km/h not too bad.
SplinterOz
SplinterOz
Battery Mounts
Postby SplinterOz » Tue Oct 18, 2011 8:06 pm
The guy that has working with me on the design and fab work has given me the first draft of the battery layout.
I am going to be running 120 10Ah Headway cells in at 24S5P setup. Due to the constraints of the frame I will be building the pack as a "stepped" pack with a double width section and a single width section.
Four plates will be created to hold the cells. The inner plates will hold the ends of the single cells and support the middle of the double width cells.
Mounts
SplinterOz
SplinterOz
Re: Battery Mounts
Postby markobetti » Wed Oct 19, 2011 1:54 am
SplinterOz wrote:The guy that has working with me on the design and fab work has given me the first draft of the battery layout.
I like the idea for holding cells, and also the motor mount - i dont know if i said this before, but that cnc design is designed nicelly . Your design or tool-mans ?
markobetti
Postby SplinterOz » Wed Oct 19, 2011 4:34 am
markobetti wrote:I like the idea for holding cells, and also the motor mount - i dont know if i said this before, but that cnc design is designed nicelly . Your design or tool-mans ?
The fabrication work is being done by a local company Mobile Fabrications. Luke there has done all the design work and either at his shop or his contacts all the work is being done. Toolman2 is helping with all the motor and controller setup. Without them the whole build would be sh*t.
Luke has a great eye for the design and layout.
SplinterOz
SplinterOz
Postby markobetti » Wed Oct 19, 2011 4:37 am
REALLY ? well done Luke. If its open info ; what was the price for that piece of art ?
markobetti
Postby SplinterOz » Wed Oct 19, 2011 4:44 am
markobetti wrote:REALLY ? well done Luke. If its open info ; what was the price for that piece of art ?
Luke has been doing a lot of his time for free as he likes this stuff and doesn't get enough. Getting the 4 plates CNC'd out of the plastic and the material will be about $780AUD. Luke has spent about 5 hours or so at normally $100AUD an hour.
So far all the work Mobile Fabrications has done (Sand Blast and powder coat the wheels, design and build motor mount, design and build sprocket carrier, design and build rear disk carrier) has been about $1700AUD. Not cheap but much better quality than I can do.
SplinterOz
SplinterOz
Postby markobetti » Wed Oct 19, 2011 4:54 am
wow , more expensive than the motor...But i agreee quality seems great and the design also
markobetti
Postby voicecoils » Wed Oct 19, 2011 6:08 am
That motor mount is a work of art to see in person.
The headway cell holder design looks great too. Have you settled on a material to do them in?
Great progress Tony!
voicecoils
Postby Philistine » Wed Oct 19, 2011 7:05 am
I went over on the weekend and got to see it in person, also got to meet Chris and his bike. Only got to see Tony's bike in action though as Chris and Tony were de-agniing Chris's bike.
I was very impressed to see Tony's bike in action, it is going to turn heads around quiet old Canberra I dare say (amongst motorcycle enthusiasts anyway). The Colussus is an impressive motor.
I felt very emasculated by a Colussus and Twin Agni bikes with my 3kw frock Greyborg. Great stuff.
Phil.
Philistine
Postby Goped ESR750 » Wed Oct 19, 2011 6:17 pm
wow. Thats pricey. I love the motor mount though.
Do have the space for machine tools at home. You probably could a got a decent size lathe and mill and machined your own parts manually. I tried to manually make as much possible. Save so much money, I have access to huge lathes and mills though, which is a great bonus.
Goped ESR750
Postby SplinterOz » Wed Oct 19, 2011 8:15 pm
Thanks for the compliments on the work, I will pass them on to Luke.
I do have some room at home for tools, but I think buying a lathe, mill, drill press, 3d software etc to build one bike would not be economical. My machining skills are limited at best so I would probably use twice the materials and I will still have to seek help for the design work.
If my plan was to build multiple bikes or do continuous improvement on this bike then buying the gear might be worth it, however I want a nice electric bike to ride every day and other than the Zero none are on sale in Australia.
SplinterOz
SplinterOz
New front brakes - start of the final assembly
Postby SplinterOz » Sat Nov 05, 2011 1:26 am
Today I got my new front disc brakes from Metalgear up in Queensland. They take the mounts from mine and attach new rotors. They look good and make me feel a lot better about the braking setup.
New Discs by Splinter, on Flickr
I have also fitted a temp sensor into the motor that will work with the Kelly controller. Originally this prototype had a cheap thermistor that was wired incorrectly. The new sensor is amongst the coils and should detect the temperature very accurately. I have also recovered the wired coming out of the motor for all the sensor wires.
New Temp Sensor by Splinter, on Flickr
So far for this motor I have repositioned all the Hall sensors, replaced the temp sensor, rerun the sensor wires, and changed all the bearings. I will be re-assembling it for the last time over the next week (work permitting) and it will be mounted in the bike never to be removed again (unless I get a production version soon).
SplinterOz
SplinterOz
Postby Jay64 » Mon Nov 07, 2011 9:26 pm
Sorry, I must have missed it. Which Kelly controller are you using for the big colossus? I'm guessing that if it can handle that motor, it should definitely be able to handle my 7kw colossus motor.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby SplinterOz » Mon Nov 07, 2011 10:23 pm
I am using the KBL72501B controller from Kelly, 500amp peak 72 volts nominal. Seems to be handling things well. :)
NOTE: I did get the High Speed option.
SplinterOz
SplinterOz
Postby Arlo1 » Mon Nov 07, 2011 10:25 pm
SplinterOz wrote:I am using the KBL72501B controller from Kelly, 500amp peak 72 volts nominal. Seems to be handling things well. :)
Come on crank it up all ready! :mrgreen: I want to see someone make this motor rip!
Arlo1
PreviousNext
Return to E-Scooter and Motorcycle General Discussion
Who is online
Users browsing this forum: EdwardNY, jonescg and 6 guests
