Green Galaxy DC-DC converter inside
Postby Njay » Sat May 14, 2011 8:46 pm
Got my hands on a cheap "Green Galaxy" (also known by other names) DC-DC converters" spec'd
Input voltage range: 30V - 60V
Output: 12V, 10A
to use on a converter motorcycle and did some tests. The purpose was to see how much power could I take from it and to change its output voltage to around 13.8V to charge a small on-board 12V battery. I ended up reverse-engineering the schematics to see exactly what it does. So here's the study result:
Output impedance: ~ 0.035 Ohm
Output voltage, no load: 11.84V
Tested up to 8A output for a few seconds; voltage falls linearly according to output impedance.
Almost complete schematics (sorry for old-school hand drawing :)):
Then I soldered a 5K6 5% in parallel with the 1K2 bottom output divider resistor to get the output voltage up to around 13.8V:
Tested the converter @ 23ºC ambient temperature for one hour running at 70W output load, and the box gets finger burning hot (over 60ºC), so I won't recommend using it continuously for higher power than this without "active" cooling.
Update:
Typical output ripple:
I haven't tried yet, but it seems that these converters, being "current mode" converters, can have their outputs connected in parallel and will share the load.
Njay
Re: Green Galaxy DC-DC converter inside
Postby TonyReynolds » Wed Mar 21, 2012 9:58 am
I wonder if it would produce as much heat for me going from 52V to 12V?
Third Build: 2012 Marin Muirwoods 4130 Cromoly, 7 speed 11/32 with 500/1000W MAC geared rear motor, 48V System, 52V, 11.5Ah 16s5p A123 lifepo4 triangle battery, DP CA; 20-30+ MPH... GRIN! Build Thread: http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=33819
cell_man... Supplier of A123 Cells and MAC Hub Motors: http://www.emissions-free.com/id47.html
TonyReynolds
Postby Njay » Fri Mar 23, 2012 5:25 am
Heating depends mostly on the output current... These converters can be found for $25 in some places, last time I saw.
Njay
Return to E-Scooter and Motorcycle General Discussion
Who is online
Users browsing this forum: No registered users and 4 guests
