Lipo-powered E300 does not start
Postby jotto » Thu Mar 29, 2012 2:13 pm
Sorry for cross-posting this, but I got no reply on the stand-up forum.
I have a new Razor E300. I'd like to see better hill climbing, so I'm experimenting with various lipos. Apart from the batteries, everything is stock.
6S works fine (but with no additional power). With 8S or 9S, however, the motor does not start. I can just hear a click from the controller when I twist the throttle.
What can cause this? According to various forums, the stock controller should handle 36V without problem.
jotto
Re: Lipo-powered E300 does not start
Postby kfong » Thu Mar 29, 2012 3:00 pm
Not sure, I replaced the original controllers on two e300 with ones that had real throttle control. If you burned out the controller I can send you mine, just send $7 for shipping. PM me for details.
kfong
Postby jotto » Thu Mar 29, 2012 3:27 pm
kfong wrote:Not sure, I replaced the original controllers on two e300 with ones that had real throttle control. If you burned out the controller I can send you mine, just send $7 for shipping. PM me for details.
Thanks for your kind offer! I don't think the controller is fried though -- it still works with the SLA batteries and with 6S lipos. Which controller did you replace it with?
jotto
Postby kfong » Thu Mar 29, 2012 3:46 pm
http://tncscooters.com/index.php?route= ... uct_id=177
You will have to replace the throttle if you go this route.
kfong
Postby jotto » Thu Mar 29, 2012 3:58 pm
Thanks! Price is not too bad. Then I just need to find a throttle that fits the E300, too.
jotto
Postby kfong » Thu Mar 29, 2012 4:04 pm
Any of the hall throttles will work since the handle is the same as a bike. Much better control vs. the on-off of the original.
kfong
Postby jotto » Thu Mar 29, 2012 4:18 pm
jotto
Postby kfong » Thu Mar 29, 2012 4:26 pm
http://tncscooters.com/index.php?route= ... duct_id=82
This was the one I used. But I believe they all operate off the 5 volts.
kfong
Postby jotto » Thu Mar 29, 2012 4:47 pm
Did you use the stock motor? What battery configuration?
jotto
Postby kfong » Thu Mar 29, 2012 5:24 pm
I kept the stock motor. The voltage I kept at 24volts because both scooters were for my nieces, ages 11 and 13. I really did not want them to go fast. I also found these scooters to be very unstable at high speeds due to the short coupled steering. I also made a custom fuel gauge so they could tell how much capacity was left using my smart switch. It also does a power down if they forget as well as protect the batteries.
Some info on the fuel gauge here
viewtopic.php?f=2&t=22675&p=525604&hilit=+Jeremy+fuel+gauge#p525604
kfong
Postby jotto » Fri Mar 30, 2012 12:53 am
Cool, thanks (again)
jotto
Postby buzzfirst » Fri Mar 30, 2012 10:43 am
Hello, I would recheck the polarity of the 8s and 9s packs. If the controller sees reverse voltage it will shut down. Dont ask how I know.
buzzfirst
Postby jotto » Fri Mar 30, 2012 1:39 pm
buzzfirst wrote:Hello, I would recheck the polarity of the 8s and 9s packs. If the controller sees reverse voltage it will shut down. Dont ask how I know.
It's checked and double checked, but thanks :)
jotto
Postby SamTexas » Fri Mar 30, 2012 3:32 pm
jotto wrote: I don't think the controller is fried though -- it still works with the SLA batteries and with 6S lipos.
Have you tried 7S?
It sounds like your controller can detect too high voltage and prevent power from going to the motor. I have seen this behavior with two wheelchair controllers. They both run on 24V SLA. I swap the SLA with a 6S (25.2V max) and they work fine. Also worked fine with 7S (29.4V max), but would not work with 8S (33.6V max). So I partially discharged the 8S pack until the voltage hit 30.0V and it worked.
SamTexas
Postby jotto » Sat Mar 31, 2012 3:48 pm
Have you tried 7S?
No, I haven't tried 7S. I don't have the batteries to make that configuration. The overvoltage detection theory makes sense, though. This is a brand new E300, so perhaps they started adding overvoltage detection in the newer revisions.
Seems like a 36V controller is the way to go. Can the tnc scooter throttle controls be used on a brusless controller? I'm planning to convert to brushless some time in the future. For this season, I will stick to the stock motor.
jotto
Postby jotto » Wed Apr 18, 2012 8:44 am
Ok, I just placed an order on a 36V controller and a throttle. Looking forward to testing it! =)
jotto
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: jonescg and 4 guests
