flexy wrote:Could you find correct size bushes from another scooter manufacturer?
I could only get the logic controller to work that way,
It needs the 48V for it's main power and a 12 v signal on line 8 to fool it into working without the speed control unit
I can't find another way to power it.
yokneamcity wrote:By the way the quality of shock absorbers are not very high.
I've already changed the seals on the front fork. And changed the rear shock. Now I need to replace the silent blocks.
Where can I get parts?
I contacted the office in Germany. Shipping to Israel from 100 euros.![]()
Why logic unit need 48V and 12V together?
mizuh wrote:Nice job!! How much it costs?
flexy wrote:Sounds great, and thank you for the rack
flexy wrote:I recently got an E-max 110s 2008 model.
This comes with the stock 48V SLA battery and 4000W motor.
I would like to upgrade it to a 72V Lifepo4 pack.
I am getting an 18 fet controller from Lyen
I'm planning to build a pack from Headway 40152S cells, in 24s 5p configuration to give me a 60Ah pack.
The main problem I have is the existing 48V motor controller and the control box for the other scooter electrics are all in proprietary sealed circuits.
So my main concern is fitting the new controller without affecting the existing functions.
All the visible capacitors on the existing controller and DC/DC convertor are 63V so that rules out using them with higher voltage.
Should I leave the existing controller powered from a 72-48V dc-dc convertor and keep the electrics running off that, or completely remove it and attempt to rewire as a basic scooter wiring loom?
I have no schematics for this bike, if anyone has one it would be much appreciated.
rgody wrote:I didnt buy the MSU unit (http://www.proud-eagle.com/pro8.asp). I dont have the manual for it.
But here is the manual tha controller I have (looks like yours) :
good luck!!
Regards
flexy wrote:The Cycle Analyst seems to lose ability to read speed at 60mph, the pulses maybe too fast.(
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: No registered users and 3 guests
