flexy wrote:I recently got an E-max 110s 2008 model.
This comes with the stock 48V SLA battery and 4000W motor.
I would like to upgrade it to a 72V Lifepo4 pack.
I am getting an 18 fet controller from Lyen
I'm planning to build a pack from Headway 40152S cells, in 24s 5p configuration to give me a 60Ah pack.
The main problem I have is the existing 48V motor controller and the control box for the other scooter electrics are all in proprietary sealed circuits.
So my main concern is fitting the new controller without affecting the existing functions.
All the visible capacitors on the existing controller and DC/DC convertor are 63V so that rules out using them with higher voltage.
Should I leave the existing controller powered from a 72-48V dc-dc convertor and keep the electrics running off that, or completely remove it and attempt to rewire as a basic scooter wiring loom?
I have no schematics for this bike, if anyone has one it would be much appreciated.
rgody wrote:I didnt buy the MSU unit (http://www.proud-eagle.com/pro8.asp). I dont have the manual for it.
But here is the manual tha controller I have (looks like yours) :
good luck!!
Regards
flexy wrote:The Cycle Analyst seems to lose ability to read speed at 60mph, the pulses maybe too fast.(
flexy wrote:I have road tested the bike with my ecrazyman 18fet contoller. motor was cogging at slow spped, it smoothed out as I sped up to 20mph, but there was an occasional bump like the motor was missing a beat.
It was drawing 5kw as I climbed a hill , the controller became quite hot and then fets must have blown.![]()
I think this motor needs a bigger controller, I don't want to risk blowing my Lyen 18fet, so I think I need something bigger.
Can anyone recommend a controller that would work, the Lyen 24fet looks promising, also Kelly controllers, but they have many different versions and I'm not sure which would be suitable.
ctirad wrote:flexy wrote:I have road tested the bike with my ecrazyman 18fet contoller. motor was cogging at slow spped, it smoothed out as I sped up to 20mph, but there was an occasional bump like the motor was missing a beat.
The stock 18fet ecrazyman is rated about 2kW, AFAIC. No surprise it blew. 18fet Lyen is a different beast. I would not afraid to use it.
The best would be some sine wave controller like sevcon or Lebowski controller with a suitable power stage.
BTW, vmoto offers upgrade kit for old e-max 90/110. It consists of sevcon controller and the needed cables. It is actually not cheap, however on the other side it is not much more expensive than some higher spec Kelly controller.
yokneamcity wrote:Hi Flexy!
Great job!!!![]()
Your experience is very valuable.
I ordered from Lyen 18 Mosfet Infineon controller Lyen Edition and cycle analist. I hope receive it in the next week.
When asked about his power, Lyen said: "I would 6500 to 6800 watts the most."
My battery has a configuration 16s/3p lithium phosphate cells 20 a / h. The first way is to raise the voltage-change configuration on 24s/2p. But then I have to open the battery and solder it. still need another BMS. Configure the charger to the correct voltage. (It's easy. Potentiometer voltage changes)
But there is another way.
I want to increase the voltage with a dc/dc converter,with the modules in the photo.
According to the scheme in the photo.
I took this scheme from the Russian forum. It works.
To activate the regeneration, it is necessary to disconnect modules.
Therefore, the circuit have a Mosfet and a button to brake.
Contact "active" activates the modules.
Turbo button normally closed, to turn off turbo mode.
flexy wrote:yokneamcity wrote:Hi Flexy!
Great job!!!![]()
Hi Yokneamcity, It has taken many hours for me to get this far.
That system you show is an interesting solution and simple! It seems to put the output of the DC\DC in series with your battery pack to give ~76V but How much current can it put out, is it limited by the 16A rating of the DC/DC?
flexy wrote:The ecrazyman controller I have has the IRFB4110 fets, reinforced traces and a modified shunt, it regularly pulls 5 - 7KW when climbing steep hills on my smaller scooter Is there any other reason why the Lyen could handle more power than this?
Do you know what the rating of that upgraded sevcon for the E-max ,is it 48V or 72V?
ctirad wrote:flexy wrote:The ecrazyman controller I have has the IRFB4110 fets, reinforced traces and a modified shunt, it regularly pulls 5 - 7KW when climbing steep hills on my smaller scooter Is there any other reason why the Lyen could handle more power than this?
I see. Then the controllers should be about the same.Do you know what the rating of that upgraded sevcon for the E-max ,is it 48V or 72V?
Good question. I have no idea, though. I only know that it can be easily programmed to speeds up tp 70km/h with the original 48V voltage.
yokneamcity wrote:Do you know what the rating of that upgraded sevcon for the E-max ,is it 48V or 72V?ctirad wrote:Good question. I have no idea, though. I only know that it can be easily programmed to speeds up tp 70km/h with the original 48V voltage.
How does it work? The speed depends on the voltage.
ctirad wrote:yokneamcity wrote:Do you know what the rating of that upgraded sevcon for the E-max ,is it 48V or 72V?ctirad wrote:Good question. I have no idea, though. I only know that it can be easily programmed to speeds up tp 70km/h with the original 48V voltage.
e-max has speed limiter to 45km/h, but the motor can actually spin faster. In addition, the new controller probably could use field weakening to push the speed even further.
Are you sure you found the right combination of wires connecting the controller to the motor?
Of the 36 combinations (3 phase and 3 Hall sensors), there are 4 options when the motor is spinning.
1) The motor rotates forward
2) The motor rotates back
3) The motor rotates quickly forward, but has no power.
4) The motor rotates quickly back, but has no power.
I think that your version No. 3. Please check it.
yokneamcity wrote:According to GPS it 42 km/h.
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: No registered users and 7 guests
