StudEbiker wrote:
The top speed of a motor is a somewhat mis-leading statistic. The more volts you feed into a motor, the faster it will turn.....until it burns up.
For example:
The top speed is dependent on it's Kv, the number of volts you are feeding it, and the size of the wheel the motor is put in. In other words, a motor in a 20" wheel at 48v will not produce as much speed as the same motor in a 26" wheel using the same voltage. On the flipside though, the motor in the 20" wheel will have more torque.
Better to discuss in public... Many people here understand much better than I do. Arlo1 is one of those people. He is a GURU !nemo micro chip wrote:tyler send me in pm message your mail so i can send you the characteristics of the motor to check it. thanxs.
nemo micro chip wrote:are you sure? that is great news then. if i put a battery of 72v/50 ah then i will be al right i guess if your claims are true enough. show me efficient evidence to believe please.
nemo micro chip wrote:thanxs a lot all of you friends for your useful informations. i am so glad to be here in the forum with you. god bless you all.
i will post when i will receive the shipment of this 48v/3000w hub brushless drum brake rear motor and its 48v controller.
then i will buy the lifepo4 lithium battery of 48v/50 ah to complete the combination.
and then i will make tests and post them here. all this project i hope that it can not be worse than the existing one with the 1000w motor and the lead acid 48v/22 ah battery.....![]()
nemo micro chip wrote:WHAT DO YOU MEAN BIG? BIG FOR MY MOTOR OR BIG IN DIMENSIONS?
nemo micro chip wrote:the factory i bought it, send me the whole diagram specs for this motor but i cant get any meaning as they seem to me like chinese...i have no relation with electronics.
The faster you go, the less range (autonomy) you get.nemo micro chip wrote:WHAT ABOUT THE AUTONOMY? how many klm distance autonomy i will have with the 48v/50 ah lifepo4 battery? and at what optimal speed for me?
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: rodgah and 6 guests
