So, i bought this Extreme 500 used from a guy last month and since then my days and night have been disturbed,lol
so to begin to explain you the current situation of the scooter is , it is running but NOT from the controller. when i connect it directly it runs full speed. but it does not run from the controller...so the guy at extreme scooter told me i have to buy a new controller type 2 which has 4 wires of throttle and 6 cable connections in total so i bought it , yesterday i received it , i was so excited i thought i would finally ride my scooter but
when i turn the power switch on , it does becomes powerful red and response quickly. i check the fuse its okay , i checked the batteries its okay. i checked everything its okay.
so today the guy from the extreme scooter told me i have to have a multimeter to trouble shoot my connections so i went and bought a new multimeter and did the stuff he told me to do .. he was really confusing me...
The problem is there is no light on the throttle
i thought the throttle cable could have been broken from inside so i went ahead and found a point A in the throttle where i can see all the wires and point B where the connection connects to the controller.. i did test on all of the four wires. red , black, green and yellow .. a continuity test to see if the wires are broken or not... they all passed the test ... 0_0 .. so all the wires are okay in the throttle ? it has a new controller , batteries are charged and motor does run too .. then what is the problem
the weird thing i found in the throttle was it had 5 wires 0_0 ? ... when i looked through a the opening in the point A but at Point B it only showed 4 wires.... and this scooter supposed to have only 4 wire throttle ? ... so do i have the wrong throttle?
Please help....if you can , i will make you a delicious chocolate cookie ^__^ !
