SHiFT
This is the build thread for my new project, as yet unnamed. I'll be moving slowly, but will post progress here as I make it - mostly for the record-keeping.
GOAL
A lightweight urban commute vehicle with the speed and handling of a motorcycle, but the ease of use of a scooter.
Construction:
Custom frame.
Off-the-shelf components where possible for easy maintenance and repair/replace.
Semi-modular build philosophy so components can be upgraded or exchanged without re-engineering the frame.
Speed:
50 mph
Weight:
<150 pounds
Features:
Onboard charging (if feasible)
NHTSA-approved lighting
NHTSA-approved safety equipment
Motor:
[strike]Agni 95R[/strike]
Hubmonster by John in CR
Drivetrain:
Zero DS Belt drive - 98/25
http://www.zeromotorcycles.com/shop...ducts_id=181&zenid=adr2sa2di0vdcfjcpclktl0ld2
Controller:
Alltrax AXE 7245
Battery:
[strike]Not sure yet[/strike]
Leaf Modules?
Telsa 18650
Specifications:
28 degree rake
56.5 - 57.0" wheelbase
4" trail
[strike]33" seat height[/strike]
29-30" Seat Height
I will be basing my design on the frame from the Husqvarna E-Go concept bike.
http://www.gizmag.com/husqvarna-80kg-all-electric-concept-e-go/19809/
Thanks for looking!
SHiFT
Edit: This is the continuation of this exploratory thread - http://endless-sphere.com/forums/viewtopic.php?f=10&t=62093
GOAL
Construction:
Custom frame.
Speed:
50 mph
Weight:
<150 pounds
Features:
Motor:
Drivetrain:
Controller:
Alltrax AXE 7245
Battery:
Leaf Modules?
Telsa 18650
Specifications:
28 degree rake
4" trail
29-30" Seat Height
Thanks for looking!
SHiFT
