vwhammer
So late in 2015 I wrapped up version 1.0 of my 2wd electric bicycle.
This year I have decided to revamp that bike to make it a little more tidy.
I have about wrapped up that build.
Anyway I will be riding that bike around for a bit but I have decided that I want to build a new bike.
This time around I will pass on the pedals and make it strictly motor/battery powered.
This bike will be primarily for commuting around town and will see very little highway use.
I have been on this forum for a bit now and I generally do a bit of research before I start tossing questions out there.
However, this time around I can't quite sort out exactly what I need to accomplish what I want.
So, realistically I would like to to be able to travel about 20 miles on a charge.
The tiny town I live in is only 2 or 3 miles across depending on which direction you go.
I would like to be able to cruise around town for a day without too much worry about running short on the juice.
My current bike does this pretty easily and it works.
The only difference is that my current bike tops out about about 24mph.
Generally it does this with about 800 watts (I think? its been a few months since I have ridden it and monitored the power) and me pedaling at a non-exhaustive pace.
Ideally I would like to be able to do 45 or 50 mph.
Realistically it would spend most of its time in the 25 to 35 mph range.
While I do live in a hilly area, I typically do not hit to many serious hills while cruising around town.
There could be a couple of decent hills on the way to a couple of friends' houses but that's about it.
What I have in mind so far will be, for the sake of the conversation, a primarily bicycle based build.
I may end up building a frame and will probably use a dual crown down hill fork and an equally squishy rear suspension.
This will all roll on some 19 inch motorcycle wheels and tires laced up to some beefy down hill mountain bike hubs.
Of course there will be no pedals in this situation.
Hence the thread in the e-motorcycle section.
For motivation I have been looking at a mid-mounted Luna cycle's 3000 watt cyclone motor and controller.
https://lunacycle.com/cyclone-mid-drive-ebike-motor-with-freewheel-sprocket/
https://lunacycle.com/40-amp-36-72v-ebike-bluetooth-programmable-controller/
I will likely fab up a belt drive system so I can toy with the gearing.
This would all be powered by a 72 volt battery.
I have not sorted out whether I will build a battery or buy one but lets just assume 72 volts and I can build to get the range I want.
I weight 250lbs and my bike may tip the scales at 75-100 lbs fully dressed depending on how much "beef" I add.
The range I can work out and buy/build a battery accordingly.
My only real question is; can I hit 45-50mph with a 3000 watt motor given my total weight?
