Power calculator
Power calculator
This spreadsheet calculator was posted on the Power Assist list sometime ago. Credit for the program to Dave Everett. I've corrected one of the slope conversion formulas, that's all.
- Attachments
Ebike powercalc rev.1.zip
- (5.96 KiB) Downloaded 1266 times
Version 3 attached.
The expressions used for the formula in cell G7 were revised to enable the spreadsheet to function correctly on Google Spreadsheets.
You can now use this calculator without the need for Microsoft Excel.
Create an account with Google and upload the file to http://docs.google.com/
Please post any bugs/suggestions here.
Miles
P.S. I'm intending to append a table of "typical values" to the spreadsheet, so that people will be able to enter the value that most closely corresponds to their specific case.
Miles
- Attachments
Ebike powercalc rev. 3.zip
- (6.02 KiB) Downloaded 957 times
If you don't have spreadsheet software, you can also upload this program to: http://www.editgrid.com/site and use it online. Editgrid seems to be better than Google Docs.
As far as power calculations for climbing various grades, a while back I set up a spreadsheet so I could use the various slope hills in my area, along with a drag force calculation as a sort of poor-boy dynamometer test.
The spreadsheet is attached. It provided actual motor performance graphs for a hub-motored bike, or it could be modified easily for a chain or reduction gear.
It gives the calculation results and both metric and US units, but the raw data has to be in US units, sorry.
The numbers entered on it representing the actual performance on my e-max.
- 100 kW
I like this power calculator; thought I would share.
(It lets you easily swap out different bike frames with default setting)
http://www.kreuzotter.de/english/espeed.htm
Dick in colorado
Dick in colorado
- paultrafalgar
- 10 kW
Re:
That's a fascinating spreadsheet, PJD. What I find interesting is comparing Row 12 with Row 16.PJD wrote:As far as power calculations for climbing various grades, a while back I set up a spreadsheet so I could use the various slope hills in my area, along with a drag force calculation as a sort of poor-boy dynamometer test.
You have halved (approx) the speed and EVEN though it's doubled the slope, you use 60% of the power!!!
SLOWING DOWN ON THE CLIMB is the way to go.
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
- paultrafalgar
- 10 kW
Re: Power calculator
Not according to PJD's spreadsheet.
- paultrafalgar
- 10 kW
Re:
Just a little plug for OpenOffice. You don't need to be without a spreadsheet! OpenOffice is FREE for both Windows and Linux (probably Mac as well, I don't know).Miles wrote:If you don't have spreadsheet software, you can also upload this program to: http://www.editgrid.com/site and use it online. Editgrid seems to be better than Google Docs.
IMHO better than Microsoft Excel by far.
If you halve your speed you take twice as long to climb the hill.....
Sure, we know the power required to overcome air resistance goes up with the cube of the speed but if the power required to climb goes up linearly then slowing down on hills will have less effect on the total energy consumed than it would on the flat.
Re: Re:
I certainly wouldn't disagree with thispaultrafalgar wrote:Just a little plug for OpenOffice. You don't need to be without a spreadsheet! OpenOffice is FREE for both Windows and Linux (probably Mac as well, I don't know).Miles wrote:If you don't have spreadsheet software, you can also upload this program to: http://www.editgrid.com/site and use it online. Editgrid seems to be better than Google Docs.
I moved from Excel '98 to Open Office Calc after trying Microsofts' latest.......
Latest version, in ODS format:
- Attachments
Ebike powercalc Rev. 4.ods
- (25.32 KiB) Downloaded 745 times
Am I the only one who cannot open this due to its password protection? It probably works fine in other spreadsheets, but Xcel is having issues.
Eric
Eric
- paultrafalgar
- 10 kW
It's an open-source format that OpenOffice uses, I'm not sure if Microsoft recognises/tolerates importation of .ods, but if you ask Miles nicely, he will convert it using Openoffice to Microsoft .xls format! BTW IMHO Openoffice calc is vastly superior to Excel and it's a free download, so why not get a copy that runs on Winders (if you must use a c**p operating system.Eric wrote:Am I the only one who cannot open this due to its password protection? It probably works fine in other spreadsheets, but Xcel is having issues.
Eric
Hi Eric,
Here's an older version in Excel format and a conversion of the latest from .ods to .xls:
- Attachments
Ebike powercalc Development Excel.xls
- (83 KiB) Downloaded 771 times
Ebike powercalc Development1 Excel.xls
- (24.5 KiB) Downloaded 942 times
Revision 5.
- Added breakdown of torque at the wheel.
- Altered background colours of cells.
- Attachments
Ebike powercalc rev.5.ods
- (25.53 KiB) Downloaded 433 times
Revision 6. Simplified version.
- Removed battery characteristics; motor efficiency and torque inputs.
- Removed distance and amps outputs
- Added motor torque output.
OpenOffice format (for Excel format see 2 posts down).
- Attachments
Ebike Powercalc Rev. 6.ods
- (21.5 KiB) Downloaded 839 times
Reference for aerodynamic data: http://books.google.co.uk/books?id=0JJo ... on&f=false
Revision 6 as an Excel file:
- Attachments
Ebike Powercalc Rev. 6 (Excel).xls
- (24.5 KiB) Downloaded 874 times
- crossbreak
- 100 MW
- Contact:
thx so much, we should develop this further and add a motor simulator like PeakEff. Then we would have something like the ebikes.ca/simulator as stand alone Excel software
Feel free to take it in any direction you like CB..
I thought that this would be more useful to others than, in practice, it has been... For most people, the Kreuzotter calculator seems to be sufficient.
- crossbreak
- 100 MW
- Contact:
wasn't aware of this one.. use my own Matlab simulink Simulation which can do something with motor resistance, e-rpm, inductance and so on.... i like the ebikes.ca simulator for the variety of different motors. It's just not sufficient to input "Watts" if a motor is involved IMO. The ebikes.ca simulator shows this very good, but does not take eddy current etc into account. When my Simulink stuff is perfect i'll try to do something similar with Excel
