Building a pocket bike with CA120-70 [8.6kW]
Show off your E-Scooter or Motorcycle creation here.
Postby olaf-lampe » Sun Sep 12, 2010 5:26 am
Hi guys,
a friend of mine is driving in the dutch mini bike race series for a few years now. He also builds his own frames:
65cc Puch motor w 15HP limited power
He was kind enough to sell me an old frame and helps me to convert it to electric. :D
It'll be driven by the turnigy CA120-70 running at 8s/53AH Kokam cells. Controller is still under investigation. I ordered the watercooled turnigy aquastar 240A. Another option is a (soon to be modded) 18 FET infineon controller I already have as spare for my recumbent.
Today I started to take some pictures to discuss the packaging of components:
The motor will drive an adjustable centrifugal clutch. I'll use a 4:1 - 8:1 single reduction with common mini bike chain and sprockets.
Target speed is 35-70km/h depending on the race track.
ca120 above the rear frame
(86.08 KiB) Downloaded 1745 times
The 8s battery will fit between the tubes of the frame. I have to cut off the Puch motor mounts to place the battery a bit lower and move it closer to the rear tire. I will also mount them with the connectors upwards. The controller will fit under the seat. Waterpump and other stuff will be placed under the fake tank. Radiator will be in front of the battery or also under the seat.
8s kokam 53ah between the tubes
(106.75 KiB) Downloaded 1745 times
To cover and protect things, I have Polini side covers. I have to modify them to suit the different airflow.
(86.33 KiB) Downloaded 1745 times
I hope to have the bike running in three weeks. Than there is a 2 hour endurance race comming up. I hope, we find some time to introduce the e-mini bike to the public.
BTW: I'm looking for a cool name for the pocket rocket... any suggestions?
-Olaf
olaf-lampe
Re: Building a pocket bike with CA120-70 [8.6kW]
Postby Arlo1 » Sun Sep 12, 2010 5:34 am
Well I named my bmx "bad Idea" so thats taken.
But good work great idea.
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby Jay64 » Sun Sep 12, 2010 7:35 pm
Looks like a cool project. Look forward to seeing the finished project.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby olaf-lampe » Mon Sep 13, 2010 9:14 am
A colleague of mine suggested: mean-e-bike
This is my favorite for now.
-Olaf
olaf-lampe
Postby vanilla ice » Mon Sep 13, 2010 11:09 am
Great! What is the projected run time? Are you going to swap batteries for the 2h race?
75# ebike, 190# scooter, 370# motorcycle, 1900# car, 4900# truck..
vanilla ice
1.21 GW
1.21 GW
Postby olaf-lampe » Tue Sep 14, 2010 1:18 am
vanilla ice wrote:Great! What is the projected run time? Are you going to swap batteries for the 2h race?
A usual heat is 15 minutes. I will not race with it in the 2h endurance race.
The battery has ~1.5kwh which is enough to deliver an average power of 6.5kW over 15 min. Than I have to recharge in 1h before the next heat starts.
-Olaf
olaf-lampe
Postby Gregory » Tue Sep 14, 2010 3:40 am
Looks great.
Paint it green and be the "Green Mean-E"
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
Gregory
Postby vanilla ice » Tue Sep 14, 2010 12:58 pm
That would be cool if you could charge in 15 minutes. Then you could do an endurance race with only two packs..
vanilla ice
1.21 GW
1.21 GW
Postby olaf-lampe » Wed Sep 15, 2010 1:27 am
vanilla ice wrote:That would be cool if you could charge in 15 minutes. Then you could do an endurance race with only two packs..
The only cells I know that can handle 4c charge rate are a123 pouches. Hard to get these days.
Actually I would like to try a 30Ah cell instead of 53Ah. For the same weight and space, I would then get a higher voltage and could reduce the gear ratio. But we only have these Kokams on stock now.
I received a new clutch housing. It comes with an extra support for the sprocket. The baseplate of the centrifugal arms will be threaded directly to the motor bell.
I'll add a picture later...
-Olaf
olaf-lampe
Postby Arlo1 » Wed Sep 15, 2010 1:49 am
-Olaf
Lipo??????????????????? Just used Lipo!!!!!!!!!! :mrgreen:
Arlo1
Postby Arlo1 » Wed Sep 15, 2010 1:51 am
Looks like he already has lipo lol!
Arlo1
Postby olaf-lampe » Wed Sep 15, 2010 9:33 am
Arlo1 wrote:Looks like he already has lipo lol!
Kokam cells have a bit different chemistry in that size. They don't catch fire like the LiCobalt cells for RC-purposes. IIRC it's LiNiCoMn...something.
Fast charge is rated 2C for them.
-Olaf
olaf-lampe
Postby olaf-lampe » Wed Sep 15, 2010 2:29 pm
Here are some pics of the radiator and the clutch(-es. They are available with 6,7,8,9,tooth ). Nothing spectecular, but they fit like a glove.
I also have a slightly larger aluminium radiator which is a lot lighter, but will not fit as easily.
(70.79 KiB) Downloaded 1534 times
(76.93 KiB) Downloaded 1534 times
I have a MES-DEA waterpump that runs on 12V but I don't know where to get 12V from?( maybe I put a separate 3s Zippy Lipo under the tank)
The other option is a mechanic waterpump driven by a belt from the rear wheel, but I want to cool the controller down, even when the bike isn't rolling anymore.
If the turnigy aquastar isn't up to the task, I consider a watercooling-mod for the 18FET infineon. That'd require a higher voltage and different batteries. I hope the aquastar does the trick... :(
-Olaf
olaf-lampe
Postby johnws6 » Sat Sep 18, 2010 8:44 pm
I think this may work for your application to drop down the voltage to 12 volts if you want to run the water cooling idea. I think if yo ucan find a surplus automotive washer pump motor it may work. Anyways here is what i saw on ebay.
http://cgi.ebay.com/Powerful-DC-24V-12V ... 53e2a36b37
I'm also wondering, where did you go about finding 53 ah kokam cells? Are these LiMn cells or lipo cells?
johnws6
Postby olaf-lampe » Sun Sep 19, 2010 9:47 am
Thanks John for the link.
I guess a common windscreenwasher-waterpump will do, My MES-Dea pump is way to big for the task.
I'm working at http://www.ececars.nl :D
Most of our cars are powered by these LiNiCoMN Kokam cells and some are not fulfilling our qualitytest and are therefor available for such fun projects. ( approx. 1-2% are slightly bent or have small marks in the pouches whereas the foil is stressed)
-Olaf
olaf-lampe
Postby scouser-nick:) » Thu Sep 23, 2010 2:56 pm
looks like fun to me :D wont water and lecy clash if something goes wrong....like a crash? :shock:
Live Fast
Die Young
Make A Pretty Corpse.
scouser-nick:)
Postby olaf-lampe » Fri Sep 24, 2010 2:10 am
scouser-nick:) wrote:looks like fun to me :D wont water and lecy clash if something goes wrong....like a crash? :shock:
Good question,
at hobbycity they claim the controller is waterproof, but several users have reported different stories of leaking water and fried controllers.
I'll take it apart and seal it before use.
The batteries will be mounted with the connectors up. I'll protect the connectors with 'conductive grease' that keeps the water from the battery tabs.
Even a rainy day or wet track shouldn't harm them.
Another issue is the motor sitting above the rear wheel. We have to protect it against any obstacles that may fly around.
-Olaf
olaf-lampe
Postby AussieJester » Fri Sep 24, 2010 2:36 am
Run Fluid XP instead of water then if it leaks it wont matter its non conductive fluid some use
when watercooling PCs ...
KiM
AussieJester
Postby olaf-lampe » Fri Sep 24, 2010 3:47 am
AussieJester wrote:Run Fluid XP instead of water then if it leaks it wont matter its non conductive fluid some use
KiM
Good advice, thanks KiM!
I used to use demineralized water in my overclocking days.
I flooded the cpu-socked and the graphic card several times with no problems.
-Olaf
olaf-lampe
Postby scouser-nick:) » Fri Sep 24, 2010 9:43 am
huh cool :) good luck should be interesting to see this!
Live Fast
Die Young
scouser-nick:)
Postby olaf-lampe » Sat Sep 25, 2010 2:04 pm
I had the chance to use our workshop for some private jobs today.
So I started to build the battery:
two copperstrips and a little conductive grease
(81.87 KiB) Downloaded 378 times
the first and last connectors are longer to attach cables
(88.2 KiB) Downloaded 378 times
I could fit 8 cells between the frame but without any room for protection covers.
So I decided to add another two cells to the pack and put six cells in the frame and two cells on each side.
Lots of room left for the radiator
(110.85 KiB) Downloaded 378 times
The outer cells 'spoon' nicely between the bends of the frame
(80.26 KiB) Downloaded 378 times
Now I have to develope a nice rack for the cells and a quicklock for the battery poles to be able to exchange the whole battery in less than 10sec. ( Mr. Shai Agassi will be proud of me :lol: )
-Olaf
olaf-lampe
Postby Bluefang » Wed Nov 03, 2010 9:10 pm
Hey mate, Have you made any progress on the bike recently? How well does the clutch fit with the motor, are you using a transmission from the pocket bike to gear it down abit or going direct drive? I have been looking at some pocket bikes and you can get some cheap ones with 3-4 speed sequential automatics, seeing as you know abit about the pocket bikes do you think that those gearboxes can be separated from the engine and adapted for use with a electric motor?
viewtopic.php?f=10&t=49912 Current build, Electric flat tracker
Bluefang
Postby olaf-lampe » Thu Nov 04, 2010 3:23 pm
Hi Bluefang,
thanks for reminding me to update the blog. :oops:
Things are going slow in the welding department and also the aquastar-controller is giving me a hard time to set the parameters right.
I already bought a nice PC watercooling radiator with integrated 12v pump and a big fan ( i won't need the fan )
(92.54 KiB) Downloaded 299 times
As backup plan I bought a 'naked' 12 FET infineon controller from ES member Lyen, which will have watercooled irfb3077 FETs and my homebrew 'overkill' massive copper power traces. ( more of that soon :twisted: )
In the meantime I made an adapter from nylon for the clutch. Unfortunately all clutches I got from my college aren't fitting in the clutch bells I had. So I have ordered another clutch, then finish the adapter.
(80.78 KiB) Downloaded 299 times
(81.48 KiB) Downloaded 299 times
(97.44 KiB) Downloaded 299 times
On sunday I will have my first practice session on a 49cc chinese pocket bike on an indoor kart-track. :shock:
Man, these things are weird to drive :D
-Olaf
olaf-lampe
Postby Bluefang » Sat Nov 06, 2010 7:45 pm
So you are attaching the clutch to the bell of the motor and not to the shaft on the other end where the motor mount is? I am looking to attach a CVT to a electric motor eventually like http://cgi.ebay.com.au/X-2-X-8-R-6-Pock ... 5ad3d49139. I have never worked on these and i was just going to buy one and see how to directly connect it to the motor, but i assume all i need to mount it to the motor properly with a clutch is make a adapter plate that mounts on to the motor that the CVT can bolt to with a clutch pack fixed to the motor shaft on the inside of that bronzy colored bell on the CVT. This will all be very useful if i use a CC controller on the motor
FYI these CVTs have been used on another forum http://motorbicycling.com/#motorized-bicycle a fair bit and seem to be able to handle some fair abuse when used as the primary reduction.
Bluefang
Postby olaf-lampe » Sun Nov 07, 2010 8:36 am
It's an interesting CVT box, but it would only be useful when the motortorque is too low. In my case I have to limit the torque with the clutch to keep the controller alive. If I'd use the CVT instead, it would imediately switch to the fastest gearing ( in my imagination at least) :?
I wouldn't suggest to use the motorshaft to drive something. The power of the motor comes from the bell. The shaft should only work as the guiding centerpoint.
Here in the Netherlands it's not allowed to have gearboxes with more than one gear. ( I'm talking about the dutch minibike challenge) Therefor I didn't look much into those semiautomatic or CVT gearboxes. There is also no room left in the engine department. Even less in an electric version...
Probably for dirt-bikes or midi-bikes?
Anyways, today I had a few nice laps on the karttrack. :mrgreen:
I had several technical problems with the carb and exhaustmounts. ( all solvable and not unexpected )
I twisted my left knee and ankle, when I cornered too hard. In other words a perfect racing day :twisted:
I spoke to the admin of the dutch minibike forum and he was interested to see some pictures. My workmate who sold his selfmade frame to me, will start a buildblog in the dutch forum and hopefully next spring we'll have something to show.
-Olaf
olaf-lampe
Next
Return to E-Scooter and Motorcycle Photos & Videos
Who is online
Users browsing this forum: No registered users and 3 guests
