1) Remove the black brush holder stamped steel Cover by unscrewing the 4 Phillips Head bolts. You may need to "tap" the cover with flat blade screw driver to get it go come off the aluminum case.
2) Once the cover is removed, you will see that the top aluminum endbell is attached to the output endbell by 4 bolts. These 4 bolts are in slots. The cover is probably rotated in the CCW direction if you look at the motor from the Brush end.
3) Mark the two aluminum case halves with a scribe or a black marker where they come together as a timing mark.
4) Loosen the 4 bolts and rotate the cover in the CW direction so that it is the same amount of rotation in the opposite direction. In other words, the middle of the slot is Neutral timing.
5) Once rotated, you can re-tighten the bolts (M10) with a open end box wrench. The torque is supposed to be 5 Nm.
6) Check that all 8 springs are still in place on the brush holder. Put the cover back on the motor.
inspiredvoltfreak wrote:Got them to drop the price of the motor $65 US Dollars because I found it elsewhere cheaper.
I'm going to strip the bike down this week so I can get my frame into work to cut off motor mounts and try to weld in battery supports.
nak25 wrote:inspiredvoltfreak wrote:Got them to drop the price of the motor $65 US Dollars because I found it elsewhere cheaper.
Where did you find the motor cheaper at?
-i'll rather pay anything under $300 for the motor.
What type of welder are you using?
my max amp is 125 and i'm still getting used to welding
I just bought a 120v welder, I'll probably get a 220 when I turn 18yrs.old.
Gordo wrote:I see the value of this tread and have a suggestion for the next fellow who tries to build outside of the box. Look carefully in to the box, which is ES. As your starting point select your distance and speed. Then look here for builds that have accomplished your goals. Check the weight of the bike, your weight and your route. If you can do much better, than the many examples here on ES, I will be amazed! The laws of physics can be very hard to beat.
Mistake number one (not the case in this tread), for me, is a newbee starting with a "budget." The budget is item #10 on the smart persons list. Lay out the goal first, look for previous ebike builds that can meet this goal and then add up the costs. This is the BUDGET![]()
Any budget of a dollar less, is just pissing on the collective wisdom, that is ES. I don't think anyone, especially a first time builder, will built a $1200 ebike for a $1000, unless they find a low cost source for cells and build their own pack.
As they say in racing - how fast do you want to go, how much do you want to
spend? This basic rule still applies. Even to electrics.![]()
Gordo wrote:1. You need a small pulley on the e-motor and large pulley on the crank. 2:1, 3:1![]()
2. You need a good belt to handle 20HP.
Return to E-Scooter and Motorcycle Photos & Videos
Users browsing this forum: No registered users and 3 guests
