Scooter "Fattie" multi-config
Postby McDesign » Mon Jul 11, 2011 9:36 am
This is a "mule" scoot made from mild steel and components I had, to experiment with different battery types and configurations, and controllers, and keep 'em all neat and under the floor (will be aluminum diamond plate). Normal 36" wheelbase; will lean 45°, but is 8" wide at the bottom. That wide rear axle may be a liability, but I have several, and my son's only a hundred pounds.
Fattie bare
Also made it wide enough to drop in any motor between the frame rails.
Fattie motor mount
Will hold (12) 6V SLAs for 72V / 12 Ah, or 60V / 14 AH of NiCad, plus space for a controller -
Fattie SLA
Fattie NiCad
Forrest
McDesign
Re: Scooter "Fattie" multi-config
Postby vanilla ice » Mon Jul 11, 2011 5:34 pm
Nice one. With the diamondplate would look similar to the old rad2go e36.
75# ebike, 190# scooter, 370# motorcycle, 1900# car, 4900# truck..
vanilla ice
1.21 GW
1.21 GW
Postby McDesign » Sun Jul 17, 2011 12:44 pm
Final pics - except for the aluminum diamond plate to replace the plywood deck - a buddy's got a sheet for me.
It's as simple as I could make it. A frame, a brake and brake lever, a throttle, and a charge port.
Rear - chain
Rear - brake side
I added some fairly dense foam all around to cushion and locate the batteries and controller -
Foam cushioning
Plywood deck for now -
Temporary deck
Side view
Forrest
McDesign
Postby McDesign » Sat Jul 23, 2011 12:50 pm
Power!
http://www.youtube.com/watch?v=9XzTr68cOo4
http://www.youtube.com/watch?v=sWSPwO4J2EE
Tire rubber
Forrest
McDesign
Postby wineboyrider » Thu Feb 16, 2012 10:37 am
Very cool. What kind of speed? Distance? It folds up right? LOl. :D :D :D
ES IS SAVED! THANK YOU JUSTIN.
wineboyrider
Return to E-Scooter and Motorcycle Photos & Videos
