gwhy! wrote:This was the mk2 version, the bearing housings on the jackshaft give up on mk1 after only 500 meters of testing ! at least the mk2 have survived the initial testing of pulling wheelies and bunny hopping![]()
bzhwindtalker wrote:Damm this looks so strange! big bike, small motor... is that a 6374?
Just to know, how much does such a rolling frame cost?
I guess it weigths something between 40 and 60kg? it's still not too much considering you have a bombproof frame to bash around at 40kph with really good torque.
I'm waiting for videos
cyclesguff wrote:wow, I'm looking forward to seeing more, hopefully soon.
Is the chain from a bicycle?
deVries wrote:gwhy! wrote:This was the mk2 version, the bearing housings on the jackshaft give up on mk1 after only 500 meters of testing ! at least the mk2 have survived the initial testing of pulling wheelies and bunny hopping![]()
That bike looks like a monster with no engine.![]()
Is mk2 a different design than mk1 or just an upgrade to resolve the bearing issues?![]()
Plenty of room for lots more batts.![]()
Look'n good gwhy!
bzhwindtalker wrote:It does indeed look under-powered... considering it weigths that much. It looks like it needs x3 the power to me!
deVries wrote:Hey Gwhy! Look'n good.
That two piece mated vertical looking thing is giving me a "hard-on"...![]()
What is it??? The Big ?![]()
voicecoils wrote:deVries wrote:Hey Gwhy! Look'n good.
dude! it's the shock mount. See the threaded bolt just above it, with the shock disconnected?
gwhy! wrote:voicecoils wrote:deVries wrote:Hey Gwhy! Look'n good.
Its not the shock mount ( the top of the shock is slightly out of shot ) the 2 vertical pieces are the motor mounts, the jackshaft bearings are also not fitted in this pic, so it will become a bit clearer when its all together with the motors fitted..
p.s the threaded bolt just above the mount is a temp thing just to keep the rear brake res in a up right position.
billsy wrote:Kevin I can't believe I'm only seeing this thread now. I need to pop round for a catch up. Its looking good bud.
bzhwindtalker wrote:So how is the pocket bike tranny working out? did you get the clutch working? All I could do with one of those is relase 1800w of heat with the clutch stalled...
Jeremy Harris wrote:Neat. I'm looking forward to how this double motor setup works, as I have plans to fit two 80-100 motors to a common shaft for my motorcycle build. My layout would be pretty similar to this, with the motors tucked up where the old airbox was and the layshaft just in front of the swing arm bearings.
Return to E-Scooter and Motorcycle Photos & Videos
Users browsing this forum: No registered users and 6 guests
