Suzuki RF400 project, original gearbox, commuter, brushless
Show off your E-Scooter or Motorcycle creation here.
Postby marcexec » Thu Jan 19, 2012 4:12 pm
The time has come for my own project.
I am converting my old '93 RF400, my former commuter which I had to retire due to general wear and tear after a total of 76000km.
Estimated value: max. 300€, ICE specshttp://www.motorbikes.be/en/Suzuki_RF_400_R_1995.aspx
It has become possible as we moved within 15km of my work 8)
At the time of writing, the project has barely begun, with the bike disassembled and the gearbox/crankcase (finally*) stripped.
Minimum target specs:
top speed: 60km/h (~37mph)
minimum range: 15km (10 miles)
I know it's modest but it will be a commuter. For now.
I will keep the original gearbox and plan to attach a Turnigy 80-100 brushless outrunner with a belt drive and will even keep the clutch.
LYEN 12 FET controller.
POC with gel type LA from a UPS that became too small. Probably Hobbyking, Headway or GBS later on.
Already have a Gigavac GX11CA contactor and new handlebar mounted switches (no need for choke and mechanical throttle).
Biggest challenge is obviously the mechanics around the gearbox. Helpful comments welcome, but there will be no direct drive.
* the rotor of the alternator had to be drilled out and yes, I have the pulley tools
Why you should go metric: http://en.wikipedia.org/wiki/Mile
My Suzuki RF400 build: viewtopic.php?f=12&t=35865 with Lyen 12FET controller (viewtopic.php?f=31&t=17683) & Turnigy 80-100B
4x Headway 38120P for ICE bike - viewtopic.php?f=14&t=25846
Please post your builds on EVAlbum.com when they are done :) and help to build the wiki: http://endless-sphere.com/w
All the gear, all the time!
marcexec
The beast is out!
Postby marcexec » Mon Jan 30, 2012 4:22 pm
Finally commenced sawing off the rest of the crankshaft from the cog:
was a good piece of work, OD is 30mm
Put it on a scale as well, 880g, the Turnigy is not much heavier!
I'll consider it a flywheel from now on...
marcexec
Re: Suzuki RF400 project, original gearbox, commuter, brushl
Postby carl2.0 » Wed Feb 08, 2012 8:38 am
Never seen a RC motor run on a full sized motorcycle, this should be interesting :D
48v Kawaski zx600 :109 ft-lb, geared to 72KPH **
http://endless-sphere.com/forums/viewtopic.php?f=10&t=28479
Project PIWI- Vintage Styled Electric Bicycle
http://endless-sphere.com/forums/viewtopic.php?t=33720
carl2.0
Postby gwhy! » Wed Feb 08, 2012 9:08 am
carl2.0 wrote:Never seen a RC motor run on a full sized motorcycle, this should be interesting :D
:D Havent you, I have done it once, but not through the gearbox and seen it done once through the gear box :mrgreen:
If the mechanics work out and the gear ratios are ok, it should work well. I will be watching.
are you planning to just fit the motor in place of the crank ?
gwhy!
Postby Spacey » Wed Feb 08, 2012 11:26 am
Will a little RC motor be enough though to power the heavy steel framed bike? What would the performance be like?
Just asking as I am still toying with ideas for my Cagiva Mito 125 build
Spacey
Postby marcexec » Wed Feb 08, 2012 2:59 pm
Has this thread been hidden until now? :)
I plan to use a belt drive and a mounting plate for the motor:
+ additional flexibility with the gearing
+ possibility for other/additional motors
+ no space / heat / magnetic flux constraints, though I haven't measured (yet)
+ shaft on the cog I cut out will be 10mm, thus I can use the original bearing mounts with ball bearings with 30mm OD (like http://shop.marksman-ind.com/6200c3-10x ... 1742-p.asp)
- additional space and weight
I think the performance should be enough to meet the target.
10kW should be achievable on the Turnigy, how permanent we'll see with heat monitoring.
I have been thinking a lot about aluminum battery cage, mounts etc. mostly concerned about the proper sizes.
I think I settled for 3mm L and box type profiles and 5mm for the mounting plate. Input welcome there.
marcexec
Postby E-racer » Wed Feb 08, 2012 3:37 pm
If you want to sustain the 10kw I suggest you keep the 80-100 submerged in the crankase oil. Then you could retain the spur gear drive :-D
Kona Stinky: custom swing arm w/ batteries
-13s3p Turnigy Li-po
-Turnigy 80-100 rewound 130kv (Burtie's optical board)
-Kelly KBL 48201
-Nuvinci Dev Kit
http://endless-sphere.com/forums/viewtopic.php?f=28&t=35341
Goped ESR750
-12s2p Turnigy Li-po
-Turnigy 80-100 HXT w/halls
-Kelly KBL 48201
http://endless-sphere.com/forums/viewtopic.php?f=35&t=20732
E-racer
Postby gwhy! » Wed Feb 08, 2012 3:53 pm
10kw is achievable with the motor but only in very short bursts, its a good plan to be able to tweek the initial ratio using a belt. the gearbox looks like a real heavy mofo. I dont think you will need the 5 speeds so you maybe able to remove 2 or 3 of the gears to reduce the weight. The motorcycle ( only 60kg in running weight ) that I was playing with was running it on a 3.5kw current limit ( single speed and geared for 20mph ) this would accelerate reasonable well, if you aim for the first gear to be around 0-15/20mph and you have higher current limit then your motor should have no problem powering this bike but I think the real problem would be optimising the gear ratio's.
gwhy!
Postby marcexec » Thu Feb 09, 2012 4:15 am
Well, let's see if I can get the gears to turn first :)
Any suggestions on the belt drive size / type?
I was thinking about the timing belt type (with teeth) but I'm unsure about the width.
Initial reduction maybe 1:2 from the motor?
BTW, it's a 6-speed, the 600 and 900 have 5.
Edit: and yes, it's heavy - crankshaft alone (after I cut out the cog) about 6.5 kg - pistons removed already.
marcexec
Postby Burtie » Thu Feb 09, 2012 4:59 am
I have used the HTD 5M-15 series belts with my 80-100 motor projects, they seem well suited to this motors capabilities.
34 tooth pulley is the smallest you can get with a taperlock bush fitting (and the smallest size I have used)
Smaller diameter ones are available, but only with a pilot hole.
A good uk supplier here:
http://www.bearingboys.co.uk/5M_Taperlo ... ley-1806-c
I am particularly interested in your project, since I have an old, KX80 engine lined up waiting for a similar conversion.
I like the concept of retaining the motorcycle clutch and gears, just getting rid of the smoke and noise :)
Burtie
Burtie
Postby marcexec » Sat Feb 25, 2012 5:51 pm
Time for an update:
I have been spending some time cleaning the gears in the gearbox.
This was definitely necessary as I found quite a bit of debris which looks like what you produce when drilling plastic.
Image Image Image Image
I will follow Burtie's advice and will go with 5/15mm belts.
Next step is to do some metalworking to attach the motor and then measure possible diameter and length.
marcexec
Postby Jay64 » Sat Mar 03, 2012 3:47 pm
Damn, you guys have RF400s over there??? That is awesome. We were only able to get the 600 & 900 over here. The only 400 that ever came state side was the FZR, I've seen pics of all the other bikes in 400s and always wanted one. Do you still have all the plastics and stuff for it?
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby marcexec » Sat Mar 03, 2012 5:22 pm
I guess there are a lot of Japanese grey imports coming here in general.
Combination fits for cars: RHD plus metric speedo (unlike UK)
I do have the fairings - they will need a bit of work, though.
I have a second RF400 still with ICE... :)
marcexec
Postby marcexec » Thu Apr 12, 2012 2:54 pm
EVers Metalworks proudly presents - something else:
How to eliminate the oil sump (don't need the capacity, weight, space):
Image Image
designing for a possible two-motor belt drive, distance min. 30mm between motor/motor/metal:
yielding 110mm and 55mm pulley OD, 220mm max. center distance
ImageImage(mock up)
ImageImage(cutting and bending plate, 5mm aluminum)
ImageImageImageImage(fitting)
I am currently trying to source the belt drive components locally and will make the little plates to block off the oil next.
marcexec
Postby TerraRoot » Fri Apr 13, 2012 2:36 pm
are you planing to leave alot of the crank case there?
theres a lot there to cut out, doable i reckon with some devcon aluminium scraps and a lapping plate, also, you going dry clutch?
moar gearbox builds needed about the place :mrgreen:
TerraRoot
Postby marcexec » Sat Apr 14, 2012 6:10 am
Yes.
I intend to keep it simple at first. There is no point wasting half an hour to remove 100g of aluminium when I am putting in lead acid batteries elsewhere (for the moment).
The clutch will stay wet as it was that way before and leaves me with the old filler cap for oil inspection.
marcexec
Postby TerraRoot » Sat Apr 14, 2012 1:32 pm
i see what you mean about only a few grams saved, however i reckon there's more then that to be saved, wet clutches create drag and having it out in the open will cut that out and allow you to directly attach the motor via the belt to the clutch, which will save you that 880g worth of quartered crank, and with that gone there's no shell bearings left then and you can dump the oil pump. the gears will be fine in a oil bath. need a few bearings with seals tho.
it'd probably be ok, but i'd worry with only a few horses i'd want to cut out any drag/losses.
just noticed your from dublin, in my best tommy tiernan corkman accent "I'm from cork boi!"
TerraRoot
Postby marcexec » Sat May 19, 2012 6:07 pm
Well I'm halfway through the blanking/closing plates fitting.
It proves to be a tedious process as I have to cut a groove in the block, then saw and file a piece of sheet metal to fit tightly.
I rather do this properly as I can't have an electric bike leaking oil...
BTW, oil pump will stay out as well
In the meantime some goodies arrived, hope you like them :D
Anyone knows what that is?
Image :roll:
marcexec
Postby marcexec » Fri Jun 08, 2012 6:15 pm
Finally something to look at regarding the gearbox:
Before
and after
Still one cover and 4 blanking plates to do...
marcexec
Postby marcexec » Fri Jan 11, 2013 3:58 pm
The project is still alive - ordered the 3 12mm shafts to be made at an engineering shop.
Will be a little bit expensive as they are using the good, hardened stuff and have to add a finishing touch to the cog.
I made a little drawing for the order I'd like to share.
This had to wait until I was finished making all those blanking plates to keep the oil in the transmission - time consuming and tedious, especially as I want it done "right". I estimate an effort of 80-100 hours going in the transmission after it was pulled apart:
- cutting it open
- fabricating the motor mounting plate
- blanking and cover plates, and all those grooves
In retrospect, I would advise using a transmission that's sealed more easily like shaft drive or 2-stroke.
I will have more updates soon.
marcexec
Postby Mugge302 » Wed May 15, 2013 5:20 pm
Hello, sort for using your threath.
But i see you have taken a rf400 gearbox apart. Do you know Where to get a new/used gearbox, as mine is jumping out og 2. Gear. Or know how to replace it. What is needed When assembling it again? (Gaskets, seals, or so ón)
Thanks a lot and sorry again.
Best regards, Bjarne from Denmark.
(Suzuki rf400 1993)
Mugge302
Return to E-Scooter and Motorcycle Photos & Videos
Who is online
Users browsing this forum: No registered users and 1 guest
