I've been working on a Ninja 250 conversion:
This is the bike I started with. The guy I bought it from said the engine lost power and it made him crash. It now cranks like it has no compression. Perfect! The windshield is broken off and some other cosmetic damage, but it's a nice platform to start from.
- Before.jpg (66.26 KiB) Viewed 5629 times
This is my pot box for the throttle (pull-pull) and regenerative braking. I used the clutch lever for the brakes. The clutch already had a switch on it to keep you from starting in gear. I cut some off the actuator so the switch energizes when the clutch is first activated rather than when it's pulled all the way in. I then wired it through an ice-cube type relay so that it triggers my brake light as well as the regenerative braking.
- Throttle and Brake.jpg (45.15 KiB) Viewed 5625 times
- relay.jpg (64.03 KiB) Viewed 5606 times
I built a new windsheld and instrument panel. The instrument panel is covered with a sheet of lexan. The blank spot to the right is where my electronic display will eventually go.
- Windshield and Dash.jpg (48.29 KiB) Viewed 5617 times
This motor mount will eventually hold a Perm 132 motor (I hope to get it in a week or so). It is designed to bolt to the existing motor mounts.
- Motor Mount.jpg (59.68 KiB) Viewed 5611 times
The Perm motor prefers to rotate clockwise, so I had to flip the rear wheel. This meant I had to move the rear brake to the opposite side. I got a new rear tire since I had to flip the rear tire on the rim to get it to spin in the proper direction and it was dry rotted.
- Rear Brake.jpg (56.02 KiB) Viewed 5603 times
I built a battery shelf using some 2" x 2" x 1/4" fiberglass angle. I screwed some 1/4" plexi-glass to the angles.
- Battery Shelf.jpg (57.1 KiB) Viewed 5581 times
Here are the batteries. I'm using (80) 10 amp hour LifePO4 cells from Headway. I got them shipped directly from China. This will give me a 40 amp hour, 64 volt pack that's capable of 200 amps continuous, 400 amps peak.
This is half of the cells after initial soldering:
- Soldered Cells.jpg (63.99 KiB) Viewed 5575 times
Here is one of two packs, soldered and stretch wrapped:
- Finished Pack.jpg (51.42 KiB) Viewed 5576 times
