Farfle's electromotard. Mk. 4
Show off your E-Scooter or Motorcycle creation here.
rodgah
Re: Farfle's electromotard. Mk. 4
Post by rodgah » Jul 21, 2013 5:37 pm
you probably would of still bent steel bars anyway they are a lot weaker than tapered alloy bars, ive even bent a set smashing trees with bark busters.
The face book pics look good, see you got a gopro sticker on now....still no video yet :P
Common Sense isn't so common........
Specialized BigHit
Electrapunk
Stinky
Farfle
Post by Farfle » Jul 21, 2013 5:56 pm
We got some footage from bart's playsport. Its just a pita to edit it all together.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 420A at 87v
Peak power out: 34 Hp and 105ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Post by Farfle » Jul 22, 2013 9:23 pm
Finally got the footage from laguna seca hacked together. here ya go!
The race bike:
24s5p 50c nano tech
Build to last...
rodgah
Post by rodgah » Jul 23, 2013 3:20 am
thats awsome, was that with the new bigger controller? I see you lost all of your water pretty early on? It looks like it goes great anyway and love the multiple camera angles.
Specialized BigHit
Electrapunk
Stinky
Tinto
Post by Tinto » Jul 23, 2013 4:43 am
Wow. Scary stuff! Was that a bit too much throttle on cold tyres?
What is the next cooling solution?
I really should read your new motor thread...
.: Giant AC-E GNG :: 48V :.
triggeraa
Post by triggeraa » Jul 23, 2013 8:38 pm
Great footage. What were the motor temps like?
Farfle
Post by Farfle » Jul 23, 2013 8:42 pm
triggeraa wrote:Great footage. What were the motor temps like?
Motor temps were around 210-240C. The winding wire we are using is good to at least 270C (thermistor and IR thermometer double verified), double insulated polyamide winding wire is good stuff!
The race bike:
24s5p 50c nano tech
Build to last...
hillzofvalp
Post by hillzofvalp » Jul 23, 2013 11:37 pm
THat's really, really, really very hot. At that temperature, how fast does the heat transfer to magnets with no cooling? :shock:
Makes me think twice about my 125C peak winding readings..
Farfle
Post by Farfle » Jul 23, 2013 11:52 pm
As long as the motor is spinning and moving air, the heat does not transfer very quickly. We just can't let it sit and soak at that temp, so we keep it rolling, put it in the stand, and then idle it forward while hosing it with water.
The race bike:
24s5p 50c nano tech
Build to last...
hillzofvalp
Post by hillzofvalp » Jul 24, 2013 3:19 pm
YOu know, Farfle.. thinking about it more... don't you think that the winding enamel rating is for just the enamel with no external force? If it is heated, it probably softens at some point. if the windings are very tightly wound doesn't that sort of spread the enamel?
This is probably not true, but got me thinking. What are the conditions of that rating and what are the other things to consider?
Farfle
Post by Farfle » Jul 24, 2013 3:35 pm
Check out thus paper on winding wire ratings, and what they mean.
http://www.google.com/url?sa=t&source=w ... OC4q2Q-hGQ
The race bike:
24s5p 50c nano tech
Build to last...
Bartimaeus
Post by Bartimaeus » Sep 09, 2013 12:13 am
It's been a long time since anything has been posted here, just an update about the team website: there's now a new address that you can reach it at: http://www.farfleracing.com. I was also able to use the stencil cutter at my summer internship to make up some vinyl decals for the bike.
Team Farfle Website: http://www.farfleracing.com/
Team Farfle Facebook Page: https://www.facebook.com/TeamFarfleRacing
Farfle
Post by Farfle » Sep 11, 2013 12:00 am
While pulling out the rear axle to trade the track-slicks to the road tires, I found one of the bearings had failed in the weirdest way. The inner race split almost perfectly in half. radially :shock: :shock: .
I replaced it with a name brand bearing, and doublechecked the center support tube had not crushed. will see how it goes from there.
(And yes, one of the worn-out samsung cells Im using as a kickstand prop is attempting a thermal runaway lol)
The race bike:
24s5p 50c nano tech
Build to last...
adrian_sm
Post by adrian_sm » Sep 11, 2013 7:44 am
Farfle wrote:I found one of the bearings had failed in the weirdest way. The inner race split almost perfectly in half. radially :shock: :shock:
Too much axial load?
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
Build #??? ~21kg ~1500w Adrian's Bafang BPM Hardtail MTB Bafang BPM code12, 15s LiPo, ~40kph, ~30kms
rodgah
Post by rodgah » Sep 11, 2013 6:07 pm
axial load would of pushed the whole inner race through not half, I would say radial and maybe some contaminates making it lock and rub against the spacer.
Specialized BigHit
Electrapunk
Stinky
Farfle
Post by Farfle » Sep 25, 2013 11:45 am
rodgah wrote:axial load would of pushed the whole inner race through not half, I would say radial and maybe some contaminates making it lock and rub against the spacer.
When I took the rear hub apart, the inner spacer had crushed. I guess that's what happens when the bearing is overloaded axially, but not fully allowed to fail because the parts are captured.
Anywho, we are working on a project involving some filmwork, here's a shot:
The race bike:
24s5p 50c nano tech
Build to last...
Bluefang
Post by Bluefang » Oct 23, 2013 6:13 pm
Farfle, with your motor have you ever considered changing the drive side bearing to a roller type rather then ball? Also with your water dumps have you noticed any build up on the coils of salts or anything?
Building high powered electric vehicles.
http://www.facebook.com/ausemoto
Goldenmotor dealer in Queensland, Australia.
h0tr0d
Post by h0tr0d » Oct 23, 2013 7:31 pm
I agree with the "too much radial" and the roller bearing suggestion is the best.
Go for it Farfle!
Thank you Justin! Life is so much sweeter with this forum... ;)
Farfle
Post by Farfle » Oct 23, 2013 11:43 pm
I have actually added a roller bearing to the output side, the bearing that is failing is in the rear hub. In the output side is a large ball bearing a roller bearing and then the sprocket has its own small ball bearing as well.
The race bike:
24s5p 50c nano tech
Build to last...
Bartimaeus
Post by Bartimaeus » Oct 26, 2013 2:04 pm
Lots of updates due for the thread:
Farfle and I took the bike out for the last time this season at MAC track. Farfle was able to borrow a pair of leathers that fit him and was able to take the bike out on the track himself and did a good job of handling the bike.
We were also able to get some really important info about how the bike handles with different tires on. It's incredible how much of a difference it makes. We had been using these Dunlop racing tires, but the compound they are made of is too hard for Mk.4 to keep them warm except on super fast tracks like Laguna Seca. The result is that I spent a lot of time sliding out on the bike because the tires would cool down after a couple of laps around the track. We decided to try out the DOT tires that Farfle uses for commuting and found that while the rubber is better suited the profile of the tires didn't allow for as much leaning in the corners. One of the local supermoto guys we've gotten to know was awesome and donated a pair of rain tires to us and let us use his tire changing tools. These tires are super soft and have a profile that's in between the DOT tires and the Dunlops. The result was about 80-90% of what we would get out of the Dunlops, but all the time instead of for just the first couple of laps.
After the new tires were put on there was some chatter that was noticeable in the front, which was different because usually all of the problems came from the rear tire wanting to slide out. After talking with the supermoto guys we decided that the suspension setup might need to be changed. Farfle was able to take one of the gas bikes out for a few laps to see the difference in handling and suspension.
We came up with a lot of ideas about how to improve the suspension, which Farfle can detail later. All in all it was an excellent way to end the season.
hillzofvalp
Post by hillzofvalp » Oct 26, 2013 11:39 pm
Interesting. Cool setup... thinking maybe about a custom wheel build one of these days.
spinningmagnets
Post by spinningmagnets » Dec 01, 2013 12:10 pm
Similar builds, I'm just cross-posting so I can find them in the future:
https://endless-sphere.com/forums/viewto ... 12&t=55592
https://endless-sphere.com/forums/viewto ... 10&t=53977
parmenps
Post by parmenps » Feb 04, 2014 9:21 am
Where'd you get that saddle you use
Farfle
Post by Farfle » Feb 04, 2014 10:05 am
parmenps wrote:Where'd you get that saddle you use
The seat is from a kawasaki kx250F. You find them all over fleabay.
The race bike:
24s5p 50c nano tech
Build to last...
Tommy L
Post by Tommy L » Jan 18, 2015 10:54 am
This is so awesome!
Tommy L sends.....
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
https://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
