Farfle's electromotard. Mk. 4
Show off your E-Scooter or Motorcycle creation here.
Bartimaeus
Re: Farfle's electromotard. Mk. 4
Post by Bartimaeus » May 21, 2013 12:25 pm
Team Farfle Website: http://www.farfleracing.com/
Team Farfle Facebook Page: https://www.facebook.com/TeamFarfleRacing
Farfle
Post by Farfle » May 30, 2013 12:01 am
The bike is making an odd noise... I think that the nose bearing(s) are taking a dump, so I may be replacing them in the near future. I'm thinking about machining a bearing into the sprocket, and literally putting four bearings end to end in the nosecone. So five bearings total in the motor.
Ill post pictures when I pull it apart
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 420A at 87v
Peak power out: 34 Hp and 105ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Bartimaeus
Post by Bartimaeus » Jun 02, 2013 11:26 am
Got an update from Farfle last night. He took the bike apart to paint the frame and found out there was about 6 oz. of water on the inside of the frame. Fortunately the protective oil coating from the factory was still on, so no rust on the inside. He also welded some more tubing onto the swingarm and is redoing the dropouts so they are shorter and thicker.
liveforphysics
Post by liveforphysics » Jun 02, 2013 12:38 pm
Nice looking drops!
Farfle
Post by Farfle » Jun 03, 2013 11:22 am
liveforphysics wrote:Nice looking drops!
Thanks man, its amazing how much time you can spend on building one silly set of parts :roll: .
A quick update on the last teardown and rebuild before we double the horsepower and head to refuel.
On the list of things to do is:
Rebuild the motor with bigger higher quality bearings on the chain side.
Trade to MSR regina 415H chain
Install a set of thermistors for the liquid cooling system.
Rebuild the dropouts with thicker higher quality steel - done
Replace the swingarm bearings.
Get all of the battery tie-down straps installed
Rebuild the controller mounts for the big Sevcon. -done
Remachine the inner hub to remove "mystery play" and relocate the sprocket outboard.
Install the rebuilt arduino liquid cooling system.
Add diagonal braces to the swingarm - done
Prep and paint the frame
It's a long list, but some of it is already done
The race bike:
24s5p 50c nano tech
Build to last...
h0tr0d
Post by h0tr0d » Jun 03, 2013 4:07 pm
Farfle wrote:Woot! 25 Bolt on horsepower!
That's the first time I see written "Bolt on" in a sentence referring to a Sevcon...
Thank you Justin! Life is so much sweeter with this forum... ;)
Farfle
Post by Farfle » Jun 03, 2013 4:13 pm
Yeahh, physically its a bolt on plug in. Software wise it couldn't be further than the truth.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Post by Farfle » Jun 05, 2013 12:58 am
The frame was dropped off to get sandblasted, and I got the motor rebuilt with a needle bearing, one large ball bearing and a small ball bearing on the drive side, and one new small bearing on the wire exit. It should be much more reliable now, as I only had about 2400miles on it before the old setup failed. Here's some pics of it primed and painted.
The race bike:
24s5p 50c nano tech
Build to last...
h0tr0d
Post by h0tr0d » Jun 05, 2013 6:38 am
Farfle wrote:Image
Will you watercool this someday?
Farfle
Post by Farfle » Jun 05, 2013 11:01 am
I may do a closed circuit cooling system in the future, but right now we have a new arduino controlled liquid sprayer, and about 3L of water onboard
The race bike:
24s5p 50c nano tech
Build to last...
h0tr0d
Post by h0tr0d » Jun 05, 2013 12:37 pm
Farfle wrote:I may do a closed circuit cooling system in the future, but right now we have a new arduino controlled liquid sprayer, and about 3L of water onboard
Any pics, schematics, code, parts list, etc??? :wink:
Farfle
Post by Farfle » Jun 05, 2013 12:52 pm
You would have to bug bartimaeus for the exact schematic, but this pic should give a rough idea of what's involved.
The race bike:
24s5p 50c nano tech
Build to last...
Bartimaeus
Post by Bartimaeus » Jun 05, 2013 12:56 pm
I'll try to get a thread started for it soon and share everything. As far as parts go though it's a 5v arduino pro mini from Sparkfun, an 8x2 character LCD, the Melexis MLX90614 IR temperature sensor (for getting the temp of the spinning case), a thermistor, and some indicating lights and a relay to control the pump, which started out as a hacked water pick but has been replaced with a pump Farfle found at a hobby shop that is used to put fuel into RC planes, although there are a lot of 12v liquid cooling pumps for computers that should also be suitable. The pump is run off of the BAMF power supply that Farfle got for driving his headlights.
Bartimaeus
Post by Bartimaeus » Jun 06, 2013 1:10 am
Farfle wanted me to share this, as he's exhausted from working on the bike. The frame has been sandblasted and painted, and what a pretty paint job:
Tinto
Post by Tinto » Jun 06, 2013 3:38 am
YES.
.: Giant AC-E GNG :: 48V :.
Bartimaeus
Post by Bartimaeus » Jun 06, 2013 3:15 pm
Here is an album with more photos from painting (also, this is on the Team Farfle Racing Facebook page. Shameless plug: you should go like it, Farfle and I take turns making sure it's updated, and most of the pictures will get posted there)
Album: https://www.facebook.com/media/set/?set ... 460&type=1
Team Main Page: https://www.facebook.com/TeamFarfleRacing
Also, bad self-picture of the race suit I'll be wearing with the bike:
Bartimaeus
Post by Bartimaeus » Jun 08, 2013 12:23 am
The battery pack is back in the frame, and Farfle is going to redo the wiring harness tomorrow.
Thud
Post by Thud » Jun 09, 2013 11:11 am
Looking good.
BUT....I just noticed, ridged foot pegs?
You can do better than that. You may feel it will never be an issue....but if one catches in a slide it guaranties a crash...& in a nasty crash if a bike ends up on top of a rider, he will want the most safety you can give him.
Any big race that may have a tech inspection will send you home.
get some......
rodgah
Post by rodgah » Jun 10, 2013 1:26 am
Thud wrote: ridged foot pegs?
yeah I agree, ive copped one to the chest before, I may not have been here if it had of been rigid.
Apart from that HELL YEAH! I want one.
Good Luck
Common Sense isn't so common........
Specialized BigHit
Electrapunk
Stinky
Farfle
Post by Farfle » Jun 10, 2013 1:49 am
Thud wrote:Looking good.
I agree with you, folding pegs give a ton of advantages, rider safety being key, AND ill need to have them to race, so they are getting done anyway.
But let me be the devils advocate for a sec, and list some pros of the non folding pegs.
First off, they protect the most vulnerable part of the bike, the axle wire exit, which sits in a horribly exposed place, and means a minimum of a few hours of downtime tearing into the motor.
Second off, the bike is REALLY tall and skinny, it has 15" of ground clearance, and the pegs are only 13" outside slider to outside slider, so I would be ticked pink if you could drag a peg, as I'm pretty sure a bar end will drag first.
All that being said, I'm picking up some cheap steel folding pegs and stealing the hardware off of them, as that's a day of machining silly little parts I would love to avoid.
Also, I got the new gearing machined. The motor now has a total of five bearings in it. :twisted: One 35x47x7 on the wire exit side, and then on the sprocket side it has a 25x47x12, a 25x32x16 needle roller, and then a pair of 25x37s, one of which is literally part of the sprocket. I think I am ready for the 101 ft/lb this beasty is going to make at the shaft. :twisted: :twisted: . Right now its geared 30-72 and rev limited to an indicated 104 MPH :twisted: :twisted: .
The race bike:
24s5p 50c nano tech
Build to last...
Whiplash
1 GW
1 GW
Post by Whiplash » Jun 12, 2013 9:40 pm
101 ft lbs!! That's like 200 at the tire holy crap! Niiiice!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Tinto
Post by Tinto » Jun 13, 2013 12:11 am
lean, mean and minimal.
Farfle
Post by Farfle » Jun 13, 2013 12:12 am
Woo! The paint was pretty close to the leathers! Got bartimaeus on the bike in gear and got the suspension sag all set up, and I don't think ill have to trade any of the springs. Just a little shim to take up the unused 5 or so mm that is default on 2003-5 kyb forks.
The racetech suspension bible has a great section on getting a bike "roughed" and has definitely reaffirmed that suspension is one of the darkest arts. :shock: :shock: :shock:
The race bike:
24s5p 50c nano tech
Build to last...
Whiplash
1 GW
1 GW
Post by Whiplash » Jun 13, 2013 8:11 am
So Farfle, when are you going after the "zero" market? This looks like good competition! I wish someone would market a true motard type bike like yours! I thought Brammo was going to but it seems they dropped the ball!
Farfle
Post by Farfle » Jun 18, 2013 3:00 pm
We got the bike on the dyno last night, and were able to eek out some more horsepower, but more importantly we doubled the low end torque, and shifted the peak horsepower back from 54mph to 45mph. Overall peak hp to the ground was 34 at 45 mph. 87v at 418A.
However while experimenting with its aerodynamic qualities on a truck loading ramp, we managed to shake a hall sensor loose, so we will be doing an emergency motor teardown when we get home later tonight.
The race bike:
24s5p 50c nano tech
Build to last...
