After a 6 month absence glad to be back and working inside for the winter...
This thread will follow the progress of a 1987 RM125 conversion...
The image above is how the bike looked when I recieved it earlier in the summer.
This is the easy part, stripping down the frame.
I really wanted to utilize the 6-speed tranny while dumping the ICE component to free-up space and drop a few pounds in the process.
The clutch basket "Drive" casting has been cut back and drilled to accomodate a 38 tooth drive sprocket that will be driven by the original MY1020 1200Watt motor.
The motor will be controlled be either a Ver 1.02c or V2.00 PicOx controller in it's stock winding, the motor will be re-wound in the new year either for higher RPM or torque depending on how the stock set-up will work. Ultimately I'm aiming for excellent hill climbing characteristics with a top speed of approx 30Km/h within the confines of 48V @ 75Amps peak.
The Dirt-E bike built last year has performed like a champ through the summer and has seen 100's of Km's logged by close to 20 different users... That build was based around a much older (heavier) bike with an even smaller MY1020 motor without any sort of transmission. The only complaint is that it tops out at 24Km on the flats and can't quite climb some of the steepest hills about the farm, though in all fairness it can cover the most common trails...
