Husqvarna wre125
Show off your E-Scooter or Motorcycle creation here.
toula.tomas
1 W
1 W
Husqvarna wre125
Post by toula.tomas » Mar 14, 2017 6:08 pm
toula.tomas
1 W
1 W
Re: Husqvarna wre125
Post by toula.tomas » Mar 14, 2017 6:59 pm
toula.tomas
1 W
1 W
Post by toula.tomas » Mar 14, 2017 7:01 pm
toula.tomas
1 W
1 W
Post by toula.tomas » Mar 14, 2017 7:04 pm
toula.tomas
1 W
1 W
Post by toula.tomas » Mar 14, 2017 7:45 pm
fechter
Post by fechter » Mar 14, 2017 8:28 pm
Great work! That's pretty cool. I'm still trying to figure out how the gearbox works. Once you finish it, it should be obvious as the chains aren't installed yet.
What kind of batteries are those?
litespeed
Post by litespeed » Mar 15, 2017 6:59 am
Very nice!
Tom
gogo
Post by gogo » Mar 15, 2017 9:18 am
It looks like you removed the structural mounting point for the top of the shock, and haven't replaced it with anything suitable to bear that force.
"A conclusion is the place where you got tired of thinking." -Steven Wright
toula.tomas
1 W
1 W
Post by toula.tomas » Mar 16, 2017 3:08 pm
Batteri LTO 24x 16Ah
flat tire
Post by flat tire » Mar 16, 2017 7:56 pm
The new frame looks like it mounts up to the rear shock just fine.
This thing looks super badass how much power will you feed it?
Orange DH w/ Cyclone mid on 6kw
Gary Fisher w/ Leaf hub on 6kw
RC Lipo and domino throttles only!
toula.tomas
1 W
1 W
Post by toula.tomas » Mar 17, 2017 1:05 am
KLS7240D,24V-72V,350A SIN-WAVE
gogo
Post by gogo » Mar 17, 2017 10:25 am
flat tire wrote:The new frame looks like it mounts up to the rear shock just fine.
It'll mount up, but the structure has been removed from the mount. There was a big rigid triangle coming from the headstock and two side buttresses to take the side loads. He removed the big triangle, which is the primary structural element, and retained only the side buttresses. Now most of the shock force is pushing toward the headstock with nothing but the end of his battery box to bear that load. Failure is imminent.
toula.tomas
1 W
1 W
Post by toula.tomas » Mar 26, 2017 6:50 pm
wineboyrider
Post by wineboyrider » Mar 26, 2017 9:14 pm
Sweet!
fechter
Post by fechter » Mar 26, 2017 9:53 pm
Looks like fresh mud on those tires.
So how does it run?
glenn0010
Post by glenn0010 » Mar 27, 2017 7:07 am
Wow that looks Great, any videos?
toula.tomas
1 W
1 W
Post by toula.tomas » Mar 28, 2017 4:16 pm
still some adjustments. video filming.
Just2807
Post by Just2807 » Apr 01, 2017 2:50 pm
Pozor! Elektrika zarazna! hahahaha
Hurry up with filming pls :D
toula.tomas
1 W
1 W
Post by toula.tomas » Apr 08, 2017 12:05 pm
toula.tomas
1 W
1 W
Post by toula.tomas » Apr 08, 2017 2:10 pm
Upgrade battery 30xLTO
upgrade motor cooling
toula.tomas
1 W
1 W
Post by toula.tomas » Apr 08, 2017 2:13 pm
toula.tomas
1 W
1 W
Post by toula.tomas » Apr 08, 2017 2:21 pm
flat tire
Post by flat tire » Apr 08, 2017 2:30 pm
Really awesome build, man. Please post some video as soon as you can! You don't know anyone with a gopro you can borrow do you?
E-Chopper
1 W
1 W
Post by E-Chopper » Apr 22, 2017 2:16 am
Great work .
Greetings from Gmünd to Czech republic
"Thunder is good,Thunder is impressive;
but it is Lightning that does the work !
-Mark Twain
macribs
1 GW
1 GW
Post by macribs » May 31, 2017 7:32 pm
Did you make custom frame for this build, as you did with the bullet proof one?
