Derbi senda with hacker motor
bionicon
Post by bionicon » Jun 09, 2017 2:41 pm
Hello everybody I want to share my latest project. Its not finisched yet but i have already 9 hours of drive-fun:) :D
Its made out a derbi senda with alu-frame adjusted to adapt the new motor and batterybox. The motor is the hacker Q150 -45 with 71 rpm/volt, a 14s lippo battery with 5kwh capacity. It works with the the hacker hst350 controller ,totall weight is about 85kg.
Till now its the most fast electric bike i ever did drive it hauls like crazy and cannot give full trottle yet(some settings must be adjusted.) Before i played with the idea to put that motor on a bicycle, but now it scares me :lol: I will make a short video soon, here some pics of the building:
(193.32 KiB) Downloaded 17 times
(239.96 KiB) Downloaded 17 times
(232.9 KiB) Downloaded 17 times
(220.91 KiB) Downloaded 17 times
(200.03 KiB) Downloaded 17 times
(239.23 KiB) Downloaded 17 times
(241.67 KiB) Downloaded 17 times
(194.43 KiB) Downloaded 17 times
(180.22 KiB) Downloaded 17 times
(212.76 KiB) Downloaded 17 times
endless 1.jpg (73.06 KiB) Viewed 294 times
endless 2.jpg (28.04 KiB) Viewed 1347 times
macribs
1 GW
1 GW
Re: Derbi senda with hacker motor
Post by macribs » Jun 09, 2017 10:15 pm
Cool to see the build process. As I said before. Fantastic build. I think you have a very special motor and controller combo. Insane power yet light as a feather.
Look forward to see videos.
jonnydrive
Post by jonnydrive » Aug 04, 2017 10:08 am
Wow!
simply awesome!
gogo
Post by gogo » Aug 04, 2017 5:14 pm
Looks fun. You might want to monitor for heat from eddy currents where the rotating motor magnets are close to the frame.
"A conclusion is the place where you got tired of thinking." -Steven Wright
litespeed
Post by litespeed » Aug 05, 2017 8:18 am
Excellent job and I'm also looking forward to video.
Tom
madin88
Post by madin88 » Aug 06, 2017 7:57 am
Great conversion^^
the "motor box" is a good idea to give that motor protection against dirt and water.
does the rotor show magnetism on the outside? if no, than there should not be a problem with additional losses as mentioned before.
there is almost nothing available about the haker stuff in the internet and you are the only person in ES i know who runs such drive system. please keep us updated.
- Votec V-FR frame / MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R -> approved as L1e moped and fully road legal in EU :)
- Vector white / MXUS 4T / 24" Hookworms / Adaptto Max-E / 22s11p 25R
bionicon
Post by bionicon » Aug 06, 2017 2:54 pm
thx everybody for the nice comments, gonna try to make a short video next weekend. Just finished a long weekend at the sea with the bike :D I did ride it everyday and the longest trip was arround 120km long(cell voltage was then 3.7 volt so not empty yet) this at a average speed of 40km/h.Top speed is arround 85km/h.
It has not the wheely -torque at take-of but accelerate fast, I will try to capture that with a video :lol:
macribs
1 GW
1 GW
Post by macribs » Aug 06, 2017 6:12 pm
Video. Nice. Your build is so clean and uncluttered. Really nice craftsmanship. And that color just makes it all look even better. Seems factory build.
bionicon
Post by bionicon » Aug 20, 2017 11:15 am
Here is a short video ,the only thing i am missing a bit is the starting-torque maybe i can get this better with adjustment the controller :wink:
https://www.youtube.com/watch?v=d05nyf3hOo8
TomBe
Post by TomBe » Oct 26, 2017 1:00 pm
Carl, this is awsome work!
I am realy excited reading your posts.
I also have custom motorbike but I used revolt motor.
Are you able to make some photos, showing front sprocket and whole chain transmision?
What is the distance betwen axle of the motor and axle of the swingarm?
bionicon
Post by bionicon » Oct 28, 2017 12:05 pm
tombe, pm send
madin88
Post by madin88 » Oct 29, 2017 5:15 am
I took the Hacker Q100 (38mm stator) on the shortlist for a middrive setup.
The problem (aside from the price :) ) i see is there is no axle coming out on the backside where a sprocket can be mounted to.
bionicon, how did you manage to install such on your Q150? On one photo i can see a small solid axle with another bearing.
A few more pics would be nice to see.
and how do you like the HST controller?
The small Herkules 5 seems to be AWESEOM from the specs. True FOC 4-quadrant control, hall sensor input etc etc. What a nice 2kW+ controller, but certainly out of my budget...
bionicon
Post by bionicon » Oct 29, 2017 5:50 am
Hey Madin, ik know the problem of the tiny axle it was first 8mm thick (too small) i drilled the 8mm to 12 mm thats better, but not the best solution i know .(the axle is at two places fasten with m8 screws and because i use regenaration also the power direction is at two sides whats hard on the screws)
This winter i gonna change direction of the motor and use the other side (there is also good bearing and it work like an inrunner)and use a 19mm axle direct bolt on the motor, maybe i use another extra bearing for support.
bionicon
Post by bionicon » Oct 29, 2017 6:25 am
(115.22 KiB) Downloaded 2 times
This is a picture of the 8mm axle
madin88
Post by madin88 » Oct 29, 2017 1:05 pm
8mm axle is truly a problem, and from the pics it looks like it has no support where it comes out of the motor.
https://www.hacker-motor-shop.com/hacke ... 89_b_2.JPG
It is an axle in an hollow axle which is only meant to center the prop think.
hmm..
If you would mount the motor backwards i guess you would need to change the mounting bracket and fabricate a bolt-on axle with additional support (similar as you did with the 8mm axle).
have you thought about fabricating an axle and attach it backwards to the prop adapter with a tight fit into the hollow shaft:
similar as Neu Motor offers for the 8057 type:
I would do it like this on the Q100.
bionicon
Post by bionicon » Oct 30, 2017 2:20 am
You can mount an custom axle at the propside thats what i am planning to do.Maybe supported with an extra bearing.
