NEM0 - <$1k Electric Dual Sport
Show off your E-Scooter or Motorcycle creation here.
Re: NEM0 - <$1k Electric Dual Sport
Postby Robomaniac » Mon Nov 02, 2009 10:12 pm
I really like what you did!
Can't wait for "NEM0 2 - >$1k Electric Dual Sport" :P
Robomaniac
Postby captainslug » Fri Jan 08, 2010 1:05 pm
Quick update after I took a long break from this project.
I would like to retest this bike at 60 volts, but first I need to install a much stronger freewheel.
I managed to grind down and remove the motor linking sprocket, found the previous destroyed freewheel, and remove it from the freewheel adapter.
So next I need to
1. Order this freewheel
http://sickbikeparts.com/catalog/produc ... ucts_id=62
2. Attach a sprocket to it at the right spacing
3. Install it on the freewheel adapter
4. Make a replacement motor-link sprocket
5. Reconnect chain drive
6. Swap out the battery charger
7. Reinstall 5th battery
captainslug
Postby captainslug » Wed Jan 20, 2010 1:08 pm
Good news: I found the original footpegs and thefront brake rotor in a box at work.
I reinstalled the rear foot-operated brake which will give me more control and safety. Especially when the roads are wet (when front brakes are almost useless).
Now I just need to buy a new freewheel and get the chain drive back together.
captainslug
Postby Thud » Wed Jan 20, 2010 3:08 pm
How did i miss this build?????
Very nicely done CS.
I read through a couple times looking for the doner chasis make. Is it some china import?
great job on the lighting & fit. I like everything about it.
get some......
Thud
Postby captainslug » Sat Feb 13, 2010 12:00 am
I've ordered a 2.65HP treadmill motor to be used as hopefully the last and final power plant for this project. Its rated for 2.1kw peak, 1.6kw constant @ 95VDC.
And here's what I eventually want the frame to look like. Whenever it is I can get around to painting it.
Thud wrote:I read through a couple times looking for the doner chasis make. Is it some china import?
A very chinese Xmotos XB-31XT.
captainslug
Postby captainslug » Tue Feb 16, 2010 7:49 pm
Motor arrived today. It's the perfect size, weight, and ratings. It also includes a hall effect switch for monitoring RPMs which will be very useful because I will need to use that in order to select the right gear reduction ratios.
I will test it at 60 volts with the controller tomorrow.
This motor spins so smoothly I'm contemplating not bothering with a freewheel. If I do ditch the freewheel I have the option of later adding motor braking of some kind (regenerative or not).
captainslug
Postby vanilla ice » Wed Feb 17, 2010 11:43 am
Sweeeet, how much was it?
75# ebike, 190# scooter, 370# motorcycle, 1900# car, 4900# truck..
vanilla ice
1.21 GW
1.21 GW
Postby j3tch1u » Wed Feb 17, 2010 2:12 pm
fantastic build--one of the best i've seen. you should take that to production!
j3tch1u
Postby captainslug » Thu Feb 18, 2010 11:38 am
Yesterday I removed the pair of motors and started work on designing the revised motor mount.
I'm waiting on a laser tachometer to arrive in the mail so I can measure the peak RPM of the motor at 60 volts. Then I can determine what reductions are needed.
The drive shaft of the motor unfortunately has a mix of imperial and metric dimensions. The tip is left-hand threaded 1/2-13, but the rest of it is 17mm.
I'm probably going to end up making a V-Belt pulley for it from scratch.
Edit: And now I have the motor mount finished.
vanilla ice wrote:Sweeeet, how much was it?
$90
Used treadmill motors are very easy to find at reasonable prices. This one was brand new and unused.
j3tch1u wrote:fantastic build--one of the best i've seen. you should take that to production!
Thank you very much.
captainslug
Postby captainslug » Fri Feb 19, 2010 9:15 am
Motor-mount finished and assembled. Can't do much else until I have a tachometer with which to measure the motor with.
However if the tap arrives in the mail today I will be able to finish the custom drive pulley.
captainslug
Postby Jay64 » Fri Feb 19, 2010 10:51 am
That right there is beeeautiful. Awesome work. Great build too man.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby captainslug » Fri Feb 19, 2010 4:41 pm
And now the custom pulley for the motor is done.
captainslug
Postby captainslug » Fri Feb 26, 2010 9:20 am
Laser tachometer arrived yesterday. At 60 volts the motor reaches a peak of 3600 RPM.
That's quite a bit faster than I was expecting. I will have to use two reductions to achieve a top speed of 40mph.
3.818 : 1 (41t : 11t)
1.4 : 1 (25t : 35t)
I won't have the option of using a belt at these speeds unless it's a timing belt. But those are just too expensive for me right now.
captainslug
Postby Tom Tom » Fri Feb 26, 2010 9:54 am
That bike is screaming for an Astro 3220 setup
Tom Tom
Postby torker » Fri Feb 26, 2010 12:24 pm
Captn, I read through all of this at one time or another but I was wondering. Did you test it @ 48 or 60 volts before the freewheel toasted? Looks good btw I love the fabrication.
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
torker
Postby captainslug » Fri Feb 26, 2010 1:00 pm
Tom Tom wrote:That bike is screaming for an Astro 3220 setup
Something I'll contemplate when I'm filthy rich.
torker wrote:Captn, I read through all of this at one time or another but I was wondering. Did you test it @ 48 or 60 volts before the freewheel toasted? Looks good btw I love the fabrication.
I tested the pair of motors at 60 volts and reached a top speed of 38mph. They got kind of warm though.
captainslug
Postby mwkeefer » Fri Feb 26, 2010 3:37 pm
That thing is SICK - very cool looking, a little under powered (my folding bike hits 4200w+) but very cool all the same!
-Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
mwkeefer
Postby torker » Fri Feb 26, 2010 3:39 pm
What is the reason for switching to the treadmill motor? Are you hoping to get more power out of one simplifying the setup? that bike does scream for an astro or mars/etek. I know about the thin wallet thing though :x
torker
Postby captainslug » Sat Feb 27, 2010 10:14 pm
The sprockets are ordered. Hopefully I can get the chain drive done within the next week.
And better still, a bunch of the guys at work (myself included) are pitching in to buy sand-blasting equipment.
Perfect timing since I that will be the final step in completing this project.
mwkeefer wrote:That thing is SICK - very cool looking, a little under powered (my folding bike hits 4200w+) but very cool all the same!
-Mike
Yeah, the peak for this particular motor @60 volts will be around only 3kw because of the cheap controller I'm using.
torker wrote:What is the reason for switching to the treadmill motor?
It's all-around a much more durable and powerful motor, which is also rated far above my intended voltage. If I want more speed later, I can simply up the voltage of the battery pack and controller to reach closer to what the motor is rated for.
Having a pair of motors was also a considerable amount of extra weight to add to this bike. The treadmill motor setup is 20 pounds lighter.
captainslug
Postby captainslug » Mon Mar 01, 2010 3:09 pm
Replaced the 4awg wires with aluminum bus bars.
captainslug
Postby captainslug » Thu Mar 11, 2010 8:44 pm
So a bunch of the guys at work pooled together to buy a sand-blasting cabinet. I ran out of work to do by about lunch time so I spent all afternoon and most of the evening using a grinders with brush wheels to strip the frame down to bare metal as much as I could, then used the sand-blaster to do touch ups in the difficult-to-reach spots. I then applied two coats of flat black Rustoleum.
The battery rack is also painted. I'll have more photos to share once the bike is back in one piece.
I apologize for not having any in-progress photos. But the work was really messy and labor intensive. I was afraid that if I stopped to take breathers and take some pictures I wouldn't have reached the point I wanted to be at by this evening.
captainslug
Postby captainslug » Thu Mar 11, 2010 9:37 pm
FrankG wrote:Hey Capt'n,
What controller are you using???
If it's a cheap YK-42x series changing a handfull of parts can take it to higher voltages...
Yep
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0452738030
captainslug
Postby captainslug » Fri Mar 12, 2010 3:18 pm
Here's the cleaned and painted battery rack I finished working on yesterday.
Reinstalled the electrical system, gauge console, front fender, and controls.
Vinyl dyed the fake exhaust hose black, and lengthened the wires for the turn signals so I could route them through it.
Seen inbetween the bushings is a set-screw collar I made which is flanked by thrust bearings. It makes sure that the axle doesn't slide in either direction.
I also installed the newer and stronger 22T freewheel on the adapter I freed from a previously destroyed freewheel.
I'm now simply waiting on parts to install the belt reduction.
captainslug
Postby captainslug » Tue Mar 30, 2010 3:54 pm
Bored out both pulleys, tapped one and on the other used a scroll saw to slowly cut a keyway into it.
I've ordered a belt, and parts to make a tensioner for the belt.
captainslug
Postby zap » Sat Apr 03, 2010 10:11 am
Very nice build captinslug.
Incredible perseverance on the project... it's amazing how much time something can take when you don't have a set of instructions in front of you eh? And you've done an excellent job of documenting the whole thing.
Good luck with the treadmill motor. I'm using a similar one on a pedal generator and they're nice motors, 1.5hp @ 100v.
Woody... a "5 speed" pusher/shopping cart
Woody doing what he does best!
A stock Currie E-Ride mtb
2 stock Currie E-Ride folders
A bit of a basket case Tres Terra Europa
zap
PreviousNext
Return to E-Scooter and Motorcycle Photos & Videos
Who is online
Users browsing this forum: No registered users and 3 guests
