NEM0 - <$1k Electric Dual Sport
Show off your E-Scooter or Motorcycle creation here.
Re: NEM0 - <$1k Electric Dual Sport
Postby captainslug » Fri Feb 26, 2010 1:00 pm
Tom Tom wrote:That bike is screaming for an Astro 3220 setup
Something I'll contemplate when I'm filthy rich.
torker wrote:Captn, I read through all of this at one time or another but I was wondering. Did you test it @ 48 or 60 volts before the freewheel toasted? Looks good btw I love the fabrication.
I tested the pair of motors at 60 volts and reached a top speed of 38mph. They got kind of warm though.
captainslug
Postby mwkeefer » Fri Feb 26, 2010 3:37 pm
That thing is SICK - very cool looking, a little under powered (my folding bike hits 4200w+) but very cool all the same!
-Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
mwkeefer
Postby torker » Fri Feb 26, 2010 3:39 pm
What is the reason for switching to the treadmill motor? Are you hoping to get more power out of one simplifying the setup? that bike does scream for an astro or mars/etek. I know about the thin wallet thing though :x
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
torker
Postby captainslug » Sat Feb 27, 2010 10:14 pm
The sprockets are ordered. Hopefully I can get the chain drive done within the next week.
And better still, a bunch of the guys at work (myself included) are pitching in to buy sand-blasting equipment.
Perfect timing since I that will be the final step in completing this project.
mwkeefer wrote:That thing is SICK - very cool looking, a little under powered (my folding bike hits 4200w+) but very cool all the same!
-Mike
Yeah, the peak for this particular motor @60 volts will be around only 3kw because of the cheap controller I'm using.
torker wrote:What is the reason for switching to the treadmill motor?
It's all-around a much more durable and powerful motor, which is also rated far above my intended voltage. If I want more speed later, I can simply up the voltage of the battery pack and controller to reach closer to what the motor is rated for.
Having a pair of motors was also a considerable amount of extra weight to add to this bike. The treadmill motor setup is 20 pounds lighter.
captainslug
Postby captainslug » Mon Mar 01, 2010 3:09 pm
Replaced the 4awg wires with aluminum bus bars.
captainslug
Postby captainslug » Thu Mar 11, 2010 8:44 pm
So a bunch of the guys at work pooled together to buy a sand-blasting cabinet. I ran out of work to do by about lunch time so I spent all afternoon and most of the evening using a grinders with brush wheels to strip the frame down to bare metal as much as I could, then used the sand-blaster to do touch ups in the difficult-to-reach spots. I then applied two coats of flat black Rustoleum.
The battery rack is also painted. I'll have more photos to share once the bike is back in one piece.
I apologize for not having any in-progress photos. But the work was really messy and labor intensive. I was afraid that if I stopped to take breathers and take some pictures I wouldn't have reached the point I wanted to be at by this evening.
captainslug
Postby captainslug » Thu Mar 11, 2010 9:37 pm
FrankG wrote:Hey Capt'n,
What controller are you using???
If it's a cheap YK-42x series changing a handfull of parts can take it to higher voltages...
Yep
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0452738030
captainslug
Postby captainslug » Fri Mar 12, 2010 3:18 pm
Here's the cleaned and painted battery rack I finished working on yesterday.
Reinstalled the electrical system, gauge console, front fender, and controls.
Vinyl dyed the fake exhaust hose black, and lengthened the wires for the turn signals so I could route them through it.
Seen inbetween the bushings is a set-screw collar I made which is flanked by thrust bearings. It makes sure that the axle doesn't slide in either direction.
I also installed the newer and stronger 22T freewheel on the adapter I freed from a previously destroyed freewheel.
I'm now simply waiting on parts to install the belt reduction.
captainslug
Postby captainslug » Tue Mar 30, 2010 3:54 pm
Bored out both pulleys, tapped one and on the other used a scroll saw to slowly cut a keyway into it.
I've ordered a belt, and parts to make a tensioner for the belt.
captainslug
Postby zap » Sat Apr 03, 2010 10:11 am
Very nice build captinslug.
Incredible perseverance on the project... it's amazing how much time something can take when you don't have a set of instructions in front of you eh? And you've done an excellent job of documenting the whole thing.
Good luck with the treadmill motor. I'm using a similar one on a pedal generator and they're nice motors, 1.5hp @ 100v.
Woody... a "5 speed" pusher/shopping cart
Woody doing what he does best!
A stock Currie E-Ride mtb
2 stock Currie E-Ride folders
A bit of a basket case Tres Terra Europa
zap
Postby TylerDurden » Sat Apr 03, 2010 10:31 am
Oh Yeah!.... Looking good.
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby captainslug » Tue Apr 06, 2010 7:59 am
First stage reduction is complete. The belt tensioner has a flanged sleeve bearing and pivots on the reduction axle.
captainslug
Postby captainslug » Sat Apr 10, 2010 1:23 pm
This treadmill motor unfortunately is complete garbage and started smoking under initial load testing.
captainslug
Postby Malcolm » Sat Apr 10, 2010 1:53 pm
This is one of the most stylish bikes on ES, so there's no way you should see it as a failure. Look on it instead as a major step on the path towards attainment of electric motorcycle nirvana. :)
Malcolm
Postby gwhy! » Sat Apr 10, 2010 2:11 pm
Malcolm wrote:This is one of the most stylish bikes on ES, so there's no way you should see it as a failure. Look on it instead as a major step on the path towards attainment of electric motorcycle nirvana. :)
Ditto...
Don't give up... just have a re-think.
gwhy!
Postby vanilla ice » Sat Apr 10, 2010 8:14 pm
Oh man that sucks about the treadmill motor. I was hoping that thing would work well. :(
75# ebike, 190# scooter, 370# motorcycle, 1900# car, 4900# truck..
vanilla ice
1.21 GW
1.21 GW
Postby TylerDurden » Sun Apr 11, 2010 9:33 am
Yeah, bummer... I was hoping to see a treadmill motor actually work. I guess they always sucked, always will.
The bike is awesome. One of those 12KW outrunners, or a pair of astros might be the ticket.
Have a Nice Day,
TD
TylerDurden
Postby TylerDurden » Sun Apr 11, 2010 5:54 pm
FrankG wrote:Thanks for documenting this bike to the point that you've taken it.
+1
For inspiration, or at least a pleasant distraction... check out widodo's thread on alternator conversion:
http://endless-sphere.com/forums/viewtopic.php?f=30&t=16328
Have a Nice Day,
TD
TylerDurden
Postby vanilla ice » Sun Apr 11, 2010 8:30 pm
Yea I was thinking that also.. the alternator thing goes with the low budget theme of this project. Seems extremely involved though.
vanilla ice
1.21 GW
1.21 GW
Postby captainslug » Sun Apr 11, 2010 10:02 pm
Well, looks like I'll take one last stab at this. I've ordered the motor I ORIGINALLY INTENDED TO USE. A MY1020 rated for 60-volts.
http://tncscooters.com/product.php?sku=106185
The only problem I had with the first motor was that it wasn't able to handle the higher RPMs that resulted from over-volting. It never had any issues with the loads placed on it otherwise.
I also have a plan for mounting it so that I can get rid of the belt tensioner.
captainslug
Postby captainslug » Mon Apr 12, 2010 7:31 am
If the single MY1020 rated @ 60 volts proves inadequate, then I have no affordable alternative to consider.
At that point this project will change hands to someone that can afford a more powerful drivetrain.
captainslug
Postby captainslug » Fri Apr 23, 2010 5:10 pm
Motor is installed. In order to get the pulley on the drive shaft of the motor I had to tap and bore opposite ends of its ID. The thread isn't a perfect match, but its good enough to keep it locked on tight.
The self-retracting extension cord reel fit nicely when wedged into the bottom of the frame. Which I'm very pleased about.
I made a replacement idler sprocket using a cheap freewheel, and an aluminum freewheel adapter from recumpence, which I lathed down a bit and then stuck a sleeve bearing inside of it.
And that's all I could get done today.
captainslug
Postby mdd0127 » Fri Apr 23, 2010 11:54 pm
Don't get discouraged. It's an awesome project, but at 200+ lbs, you're going to need 5-6kw to be reliable and interesting. It's just a fact of physics. If you still can't afford a decent motor by the time I get things really rolling, I'd be happy to donate a motor to your build. I'd start saving for lipos for sure. Again, very impressive build.
Turn it OFF!!!
Appocaloptimist! (thx Kiwi!)
mdd0127
Postby vanilla ice » Sat Apr 24, 2010 1:31 am
I still thinks its a neat little budget moped. The looks is what is throwing everybody off. If you think of it as a dirtbike that happens to have a moped plate, sure the performance isn't up to snuff. If you look at it as a moped that happens to have dirtbike looks, the performance of the original build already had it outperforming ice mopeds.. Any case I understand the desire for higher performance and I hope you find it!
vanilla ice
1.21 GW
1.21 GW
Postby Jay64 » Mon Apr 26, 2010 9:28 am
I hate to see the project end. I truely hope that you get it to work to your expectations. But if you decide to sell it, hit me up and let me know a price. I have a bunch of lithium batts, and a few high power motors. I am always looking for more chassis, and your build is an absolute beauty.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
PreviousNext
Return to E-Scooter and Motorcycle Photos & Videos
Who is online
Users browsing this forum: No registered users and 2 guests
