kudos
I wonder if you could fit some HK lipo in there ?........
Kudos
Kudos
kudos said:I wonder if you could fit some HK lipo in there ?........
Kudos
voicecoils said:Test mounted the new pack today.
migueralliart said:If anyone else is interested in the shell only, a seller on aliexpress is selling them ;
http://www.aliexpress.com/item/white-color-packing-18650-cells-new-bottle-battery-case-electric-bike-battery-case-ebike-battery-case/1682864183.html
THey might start surfacing here and there. I wouldn't buy them with the packs in it from aliexpress as I don't trust battery packs from there.
Now one of those filled with 25R cells ... killer commuter pack.
migueralliart said:It seems that the max amount of cells you can fit in this case is 50 according to the layout I saw. That gives you;
10S5P
12S4P
14S3P
Note that there might be bigger enclosures as it is the case with the frog battery.
For small capacity and high discharge I would go with sony or samsungs.
teslanv said:Paul shows a 13S4P option on his page, in addition to a 10S5P set-up. - so it must be possible.
I would have to assume Paul spot welds the packs, so if you are building your own with the bare case, you'll have to plan on having the battery welding equipment or find someone who does.
Seems like it's way easier just to buy from Paul, unless you want a cell that he doesn't offer.
perhaps you could manually solder the cells together with plate or copper wire, although does anyone know what the clearances are for the cells? It may be too tight to have any significant build-up on the cell ends???nukezero said:teslanv said:Paul shows a 13S4P option on his page, in addition to a 10S5P set-up. - so it must be possible.
can you briefly explain what/why spot welding is and why it is needed to squeeze more cells? I thought I can just buy metal plates and solder it together within the packs and call it a day no?
teslanv said:perhaps you could manually solder the cells together with plate or copper wire, although does anyone know what the clearances are for the cells? It may be too tight to have any significant build-up on the cell ends???nukezero said:teslanv said:Paul shows a 13S4P option on his page, in addition to a 10S5P set-up. - so it must be possible.
teslanv said:Looks like there is a bit of clearance at the cell ends. It's hard to tell if it's soldered or spot welded though, with the shield cover in the way. The red wires on the top seem to go to each parallel groug, though. - Maybe not a difficult task to solder manually...
Anyone have a battery they want to tear apart and show us how it's done???
That might be a good solution. The key is to figure out how Paul Assembles his, and build yours the same.nukezero said:what if I order the batteries with tabs already spot welded? Then I just solder the other side to the bare flat top of the battery?
But then I wouldn't know how many batteries need to be tabbed and which aren't.
teslanv said:That might be a good solution. The key is to figure out how Paul Assembles his, and build yours the same.nukezero said:what if I order the batteries with tabs already spot welded? Then I just solder the other side to the bare flat top of the battery?
teslanv said:It's tempting to get something like this:
http://www.aliexpress.com/item/180p...sonic-NCR18650PD-18650-2900mAh/759290109.html
PLUS a few of these:
http://www.aliexpress.com/store/pro...se-ebike-battery-carry/637802_1600570969.html
That would net at about $400 per 11.6Ah 13S pack, and be THE best option for a Clean Bottle-Mount style battery...
Except I'd probably spend a day building each one, so once the value of my time is added, maybe more like $600 each.
lectriccycles.com sells a virtually identical set-up for $750. - His uses Panasonic NCR18650PF cells. http://lectriccycles.com/products/48v-downtube-mounted-battery
dogman said:I'm not a bit surprised to see the capacity is as promised at 1c. ( voicecoils) I'd like to see what you think of the sag at 2c. If it has little voltage sag under load at 2c, that would mean it should be able to run a 20 amps controller ok. Anything under 2v of sag would be pretty good I think. But 5v of sag would mean a larger capacity pack might be a good idea for the 750w kit.
Since you have the smaller capacity pack, it will be very interesting to see how it performs under a 2c load.
