controlling meanwell with relay on 120VAC side - relays keep getting stuck closed!
andrew.box   100 W
Post by andrew.box » May 21 2019 9:13pm
Hey folks, I'm trying to drive a meanwell 12V 18A PSU, model S-250-12, using a standard type relay like one would use with arduino to switch the 120VAC mains to the power supply on and off. Not an SSR or anything, regular relay that goes 'click'. Well, I've had 3 relays now fail closed with this project which leaves the PSU and load turned on all the time, not what I want to do!
After the 2nd failed I figured it may be inrush current welding the contacts closed, relays are 10A rated and my load on the 12v side is only 5A but inrush maybe would be higher, so I put a 2 ohm 25A rated thermister in series with a leg of the AC mains between the relay and meanwell. But it happened again, I just found the relay stuck closed. I'm stuck on this as well, it can't be 3 bad relays at this point.
Anyone ever had this issue or have a better idea that me what's going on?
Full disclosure - this isn't being used as a charger in this project but rather to drive a 12v resistive heating element for an incubator for a DIY creature rearing setup, but I didn't know where else to turn and figured this may be useful to someone building an arduino controlled meanwell based charger someday. If it's too off topic feel free to remove.
RunForTheHills   100 W
Re: controlling meanwell with relay on 120VAC side - relays keep getting stuck closed!
Post by RunForTheHills » May 21 2019 9:26pm
Is the relay arcing? Did you put an ammeter on it to confirm the current? Another option is that you can get smartplugs dirt cheap these days and use IFTTT, SmartThings, Alexa, or a phone app to control it. This one is $10, but is also only 10A:
https://www.amazon.com/Assistant-Requir ... way&sr=8-4
john61ct   10 MW
Post by john61ct » May 21 2019 9:46pm
get better relays, rated for say 4x what you need.
And why not go SSR?
andrew.box   100 W
Post by andrew.box » May 21 2019 9:47pm
Not sure if it’s arcing. I don’t hear anything. This one is enclosed though inside a whole temp controller unit. I put an clamp style meter on it when I first built it and it was showing 5A on the DC side. I think there’s inrush because my workshop lights dim ever so slightly when the relay clicks closed. I’m guessing it’s a capacitor charging since the load itself isn’t really that big. 60-70w or so.
Thanks for the reply!
amberwolf   100 GW
Post by amberwolf » May 21 2019 9:50pm
if it's this one
https://www.mouser.com/ProductDetail/ME ... OuGg%3D%3D
then the spec sheet linked there says it's a 45 inrush current at 250vac, which means up to twice that for 115vac.
so you have to use a relay capable of at least 90a or it will arc while closing the contacts, and weld them together.
it's probably a lot easier to switch the output than the input.
if yours is not the same model, look up your model on mouser or meanwell's site, and verify the inrush current you'll have to deal with.
andrew.box   100 W
Post by andrew.box » May 21 2019 9:57pm
amberwolf wrote:
May 21 2019 9:50pm
if it's this one
Oh wow, yeah that’s probably the issue. So even with the 2 ohm thermistor you think it would draw more than 10A or so? Maybe the thermistor isn’t getting long enough to cool down, I guess that would do it.
Yeah, I’ll just build myself something to switch the 12v load side. I think that’s the way to go. I never noticed they have specs published for the inrush. Thanks a bunch! I guess I just naively assumed it was a few amps and nothing too extreme since they’re found so commonly in all kinds of devices.
Thanks again.
amberwolf   100 GW
Post by amberwolf » May 21 2019 10:19pm
andrew.box wrote:
May 21 2019 9:57pm
you'd have to calculate it based on the voltage you're running it on.
if it's 115vac, then 115v / 2ohm = 57.5a.
you'd also have ot look at the ntc / ptc 's specs to see how long it takes to heat up and become lower resistance, to see if that is as long or longer than the inrush current time will be, since the inrush will be slowed down and take longer due to the lower current flow.
then you have to get a relay that can handle the actual inrush current that's still present.
andrew.box   100 W
Post by andrew.box » May 21 2019 10:22pm
amberwolf wrote:
May 21 2019 10:19pm
andrew.box wrote:
May 21 2019 9:57pm
Ah, right. Just ohms law if voltage is in RMS. Been a while since I’ve done much circuits work. Forgot my basics. Yeah, 45A is still too high for the presumably 10A relay in that device. Will change tactics accordingly. Thanks for the help.
amberwolf   100 GW
Post by amberwolf » May 21 2019 10:31pm
andrew.box wrote:
May 21 2019 9:57pm
if you mean, the meanwells are found commonly (or rather, psus of various types similar to the meanwells), then yes, but they aren't being switched by relays in hardly any of them--that's a very rare thing.
almost always the dc side is switched, and usually it's done via a shutdown line, like on a computer, that simply "tells" the psu to stop outputting power.
unfrotunately your meanwell is one of the oens that doesn't have this option wired to the terminal block (dunno if it has it internally, but based on the block diagram in the spec sheet, if you can find the ovp section's optoisolator input, you could splice into that signal to control it's shutdown / power on without a big relay.
flippy   1 MW
Post by flippy » May 22 2019 3:52am
do you need actual isolation or do you just want to turn it off?
Lithium beats liquid dinosaurs.
andrew.box   100 W
Post by andrew.box » May 22 2019 7:12am
Good point Amberwolf.
And yes, I just want to turn it off. Not isolate.
flippy   1 MW
Post by flippy » May 22 2019 12:27pm
then just use a SCR.
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » May 22 2019 12:49pm
12V SPST relay sounds like the tool
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
billvon   100 MW
Post by billvon » May 22 2019 12:52pm
amberwolf wrote:
May 21 2019 9:50pm
Did you mean half? Actually it's more like a quarter due to the CV^2 factor. Keep in mind the input capacitance does not change when voltage does in a universal supply.
--bill von
fechter   100 GW
Post by fechter » May 22 2019 2:20pm
A SSR would work well for that application. The inrush of the capacitors charging draws enough current to weld the contacts.
andrew.box   100 W
Post by andrew.box » May 22 2019 5:23pm
fechter wrote:
May 22 2019 2:20pm
On the low voltage side, or even to switch the mains?
fechter   100 GW
Post by fechter » May 22 2019 9:39pm
andrew.box wrote:
May 22 2019 5:23pm
I'm thinking to switch the mains. The big AC ones can handle the inrush and they aren't super expensive.
bigmoose   100 MW
Post by bigmoose » May 22 2019 10:27pm
It's inrush. If you want to stay mechanical, I have used these definite purpose contactors from Automation Direct. Not too bad for imports and the price is pretty good. https://www.automationdirect.com/adc/sh ... contactors
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
andrew.box   100 W
Post by andrew.box » May 22 2019 10:31pm
fechter wrote:
May 22 2019 9:39pm
andrew.box wrote:
May 22 2019 5:23pm
Thanks, I'll look into it. Good option to have even if I just switch at the 12v for this project.
john61ct   10 MW
Post by john61ct » May 22 2019 10:40pm
I see some of those have a DC rating, only 0.25 A, as opposed to 40x the AC current.
Is DC switching under load really **that** much more stressful to mechanical relays?
amberwolf   100 GW
Post by amberwolf » May 22 2019 11:03pm
Yes, because under AC the voltage (causing the arc) drops to zero at the frequency of the AC.
DC never stops arcing, cuz it's DC, until the contacts are far enough apart that under that specific voltage the arc won't sustain.
But when the contacts are *closing*, then either one can weld the contacts closed and prevent breaking the circuit, if the arc current/temperature is high enough to cause the contacts to heat to molten temperature at the point of contact at the time they close.
john61ct   10 MW
Post by john61ct » May 23 2019 8:23am
So for this project https://endless-sphere.com/forums/viewt ... 9#p1444529
just focusing on the contactor bit, what would y'all recommend for 4Vdc
A. for initial experimenting at 10A maximum
B. later for production use, at 30-35A
Any potential derails about the rest of that thread's ideas should best get posted over there
