Hello fellas, I'm new to the forum. Long time Lurker, first post. I'm in the beginning stages of putting together a diy project.
Pics below.
EDIT** Added photos of the cell tear down now that I have them in hand.
Going with a standard 26 inch hub motor kit and planning on upgrading the controller.
The specs for the cells I'll use for this project are:
part: Eg20-1s10400-t1t2.
3.8 volts.
10,400mah (2 5200mah cells in a 1S2P setup with a board attached), 8 wire connector.
Made by TCL hyperpower.
I purchased these from a manufacturer liquidation auction, and have over 250 of them so I'll be using them however I can.
Can anyone tell me if that pcb looks like a built in BMS for each cell, and if I should keep it or try to remove them. Will use for ebike project, for my kayak trolling motor, and wherever I can find a use.
I appreciate any advice.
Thanks!
Lan
Pics below.
3.8 volts.
Thanks!
Lan
