SpaceKaseJase said:
The one reason I went with the "Uberscoot" style frame was the fact that it was sturdy, had two disc brakes, and dual suspension. I've taken mine to 32 mph with no fear of it falling apart. My controller is a Kelly 55a continuous. Would appreciate a picture of your battery and scooter setup for reference. I like the 3/8 hole idea. Is it for convenience?
I won't have the money to replace the batteries until around June, so I hope my current lipos hold up. At least I have time to consider options. If you could provide that battery link, it would be appreciated.
Btw, how did you know about the type of scooter I have? Was it mentioned in another post, or have you visited my modifiedelectricscooters.com blog? The site is now dead. Just curious.
The reason for the drilling was to bring the B+ and - out the top so I could quickly and easily connect the battery without having to deal with the tight mess of wires inside the controller "compartment" . With the Anderson plugs, it would have been a pain to connect it in there with such limited space and there really was no available space in the battery compartment at all. Anywhere i tried to put the connectors would have been a short waiting to happen. I made a grommet out of shrink tubing and hot glue where the controller wires exit. Also important to file the sharp edges ( Duh , I know. Better to mention it than not) . I bought mine for the same reasons you did. My main concerns were the calipers and headset , but they're doing fine so far. Im going to put real shocks on it soon and probably calipers and rotors .
The link to your battery pics are on Flicker , so your scooter was on there . I was curious how yours was set up . Totally dig the color scheme and the meter in the padding. That was a good idea. I lost the link to the website for the balance leads , but you can get them off Amazon pretty cheap . less than $10 for 10 of them I think.
https://www.amazon.com/CynKen-Terminal-Balance-Charger-Connector/dp/B06W2L5F2H/ref=sr_1_3?gclid=Cj0KCQiA-4nuBRCnARIsAHwyuPp-JR0zNFthmfQriDW7aSdoikIzxSlrqU0O7Og9-YXVOHXx88tGwAgaAuOtEALw_wcB&hvadid=341292103177&hvdev=c&hvlocphy=9032862&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=11844716837870470236&hvtargid=kwd-301582812120&hydadcr=24659_9648993&keywords=7s+balance+leads&qid=1573082191&sr=8-3
* Edit* I just realized that the Icharger 206b will only balance 6s . You could always split the pack into 2 groups of 6s and charge the remaining 2 groups separately. Either way , if your charger is fairly accurate , they should be very close.
Here is another supplier for leads. They have 2s - 6s leads very reasonably priced. https://www.racedayquads.com/products/2s-balance-lead-jst-xh-10pcs-2s1p-balance-connector-male-female-plug
The idea is to lay all of your parallel bus bars down first and do series connections last , so that you can easily remove the series bus bar right off the top to isolate your sections . Instead of soldering a bunch of heavy leads to charge these sections , the best bet would be to make a removable lead with ring terminals on the battery end. That way you can just remove a couple nuts and stick it on the next section to charge. All this probably seems a little bit of a pain , but considering what can happen if a bms fails , I don't have a problem taking a little extra time once a month to do it this way. A good bms is worth its weight in gold, but it also costs it's weight in gold. The cheap ones are straight up roulette .
https://flic.kr/p/2hGjknG
https://flic.kr/p/2hGfPYo
https://flic.kr/p/2hGjky3
