mwkeefer wrote:PPS: methods - Have you ever had a lipo puff or blow while in use on bike? If so, bad lipo? Electric failure cascade, swollen packs? Did you get hurt?
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
mwkeefer wrote:spike,
If you would be so kind as to post your current setup: motor type, drive type, speed controller type, desired top speed, average crusing speed, manor in which you intend to use (power only, throttle only or hybrid) and finally the range you would like to acheive. Be as specific as possible about your motor and ESC, if you have ratings such as kV (RPM of motor per 1V input) that would be helpful. What model / type of ESC are you using or if your not sure, where did it come from. Another item is budget, what are you planning to spend for the batts, chargers and power supplies. And yes cell level discharge LVC (low voltage cutout) is important because if you develop a bad lipo cell it will prevent over discharging a single cell thereby causing potential damage. That would save your pack (if you have the LVC wired to a power cutout - ebrake connector or such). Post what details of your intended setup you can and I will work out recommendations tonight. -Mike
Jeremy Harris wrote: but if I have quite a few cells paralleled up via the balance connectors I'm hoping that things should even out, allowing the standard wires to be used.
Jeremy
Users browsing this forum: DrkAngel, friendly1uk, Google [Bot], Mad Professor, migueralliart, zsnemeth and 14 guests
