morph999 wrote:How many dewalt packs would I need to get 15 mile range on 5303 hub motor? Assuming 36v? and then also assuming 72v?
Sorry, I only have Dewalts to play with. No plans on using any other packs since the Dewalt have been very reliable. I will be getting the Dewalt 28volt packs, and will verify if those will work.
Evereste38 wrote:Hello,
I'm try to use the 28V pack too, but I'm not able to activate the BMS with the 3 resistors like on the 36V pack.
I blew the fuse and shunt it by a external between the BAT- inside and the output Pin outside, ratter to dig into the pack to change the SMT fuse, does it a problem ?
Do you confirm your pack in 28V is working with the same resistor network ?
Thanks.
Users browsing this forum: Grey beard, Observator and 7 guests
